Mitsubishi Big screen Ws-65819 won't turn on
Discussion in 'Electronic Repair' started by showtime, Jan 15, 2005.
  1. showtime
    showtime Guest
    Green power light comes for a couple of seconds then goes off, Tv
    clicks but no picture or sound. I replaced blown fuses F9A04 & F9A05.
    Tv is about 2 years old. Any Suggestions?
    Mark
    #1
    1. Advertisements
  2. showtime
    Jerry G. Guest
    Re: Mitsubishi Big screen Ws-65819 won't turn on
    Most likely there is a failure in the power supply itself, or in the
    horiz scan amplifier, or high voltage section. A failure in the
    vertical amplifier can also cause an overload back to the powersupply
    as well, depending on the nature of the failure.
    I would suggest you call a service center to have your set serviced.
    Jerry G.
    Jerry G., Jan 15, 2005
    #2
    1. Advertisements
Similar Threads
  1. ironhorse ranch
    mitsubishi big screen t.v. model VS461RS
    ironhorse ranch, Dec 17, 2003, in forum: Electronic Repair
    531
    ironhorse ranch
    Dec 20, 2003
  2. Kris
    3
    2,747
    Leonard Caillouet
    Feb 18, 2004
  3. John Miller
    Magnavox TV won't turn off, then won't turn on
    John Miller, Apr 17, 2004, in forum: Electronic Repair
    3
    1,848
    John Miller
    Apr 17, 2004
  4. David
    892
    David
    Jan 12, 2006
  5. Pat
    967
    Sofie
    Sep 8, 2006
Loading...
