mini-melf diode color rings?
Discussion in 'Electronic Repair' started by francesco.messineo@gmail.com, Sep 20, 2006.
  1. Guest
    Hello folks,
    I need to know what kind of diode is an smd, mini-melf case, glass
    diode with black white and green
    color rings on it. I've tried to find a color code on the web but seems
    like these diodes aren't so common.
    Thanks in advance.
    Francesco IS0FKQ
    , Sep 20, 2006
    #1
    1. Advertisements
  2. Eeyore Guest
    wrote:
    > Hello folks,
    Truth is, if you totally don't know what it might be, you'll probably never find
    out.
    Graham
    Eeyore, Sep 21, 2006
    #2
    1. Advertisements
  3. Guest
    Eeyore ha scritto:
    > wrote:
    > > Hello folks,
    > out.
    I think it's a zener, I'm pretty sure as I measured other diodes marked
    as ZPDnn on
    the same board and all indeed are zeners.
    Regards
    Francesco IS0FKQ
    , Sep 21, 2006
    #3
  4. Franc Zabkar Guest
    On 21 Sep 2006 02:20:19 -0700, put finger
    to keyboard and composed:
    >Eeyore ha scritto:
    >> wrote:
    >> > Hello folks,
    >> out.
    >as ZPDnn on
    >Regards
    >Francesco IS0FKQ
    If you can determine the zener voltages of the other diodes, then you
    may be able to make some sense of the colour code.
    - Franc Zabkar
    Please remove one 'i' from my address when replying by email.
    Franc Zabkar, Sep 21, 2006
    #4
  5. Guest
    > >as ZPDnn on
    > >Regards
    > >Francesco IS0FKQ
    That's what I thought, unfortunately seems like there's no relation
    between colors
    and zener voltage. Probably the code just means it's a zener diode.
    Regards
    Francesco IS0FKQ
    , Sep 22, 2006
    #5
    1. Advertisements
Similar Threads
  1. blasterbill
    Mini-Melf and Quadro-Melf 4148 diode
    blasterbill, May 22, 2004, in forum: Electronic Components
    1,941
    Tim Wescott
    May 22, 2004
  2. Color rings on diode
    , Aug 19, 2005, in forum: Electronic Components
    9
    2,574
    Spehro Pefhany
    Aug 24, 2005
  3. Daniel Haude
    MELF or chip?
    Daniel Haude, Sep 25, 2003, in forum: Electronic Design
    14
    1,605
    red rover
    Sep 28, 2003
  4. Jacy
    SMD diodes Melf/Mini Melf series
    Jacy, Sep 4, 2009, in forum: Electronic Projects
    887
  5. SebaX75
    Read value of SMD diode (mini-melf)
    SebaX75, Feb 9, 2012, in forum: Datasheets, Schematics, Manuals and Parts
    58
    21,717
    SebaX75
    Jan 2, 2013
Loading...
