MIDI organ pedals
Discussion in 'Electronic Projects' started by christian10992, Jan 13, 2014.
  1. christian10992
    christian10992
    Jan 13, 2014
    4
    This is my first post, and I would like some help with a project I am working on. I am trying to convert a set of organ foot pedals into a midi controller.
    For the contacts, I'll be using momentary contact switches. If anyone has a recommendation for those, I'd appreciate it.
    The midi component will come from a midi controller that I gutted. Here's where I am having trouble. I haven't dealt with anything complicated in electronics before. I know how to solder basic stuff, but not much beyond that. Here is the PCB from the midi I'm using.
    [​IMG]
    [​IMG]
    [​IMG]
    So, my question is, how do I go about wiring the contacts into this board? Like, step by step?
    Sorry for such a noob question.
    #1
    1. Advertisements
  2. christian10992
    christian10992
    Jan 13, 2014
    4
    Each of the double circles corresponds to a key on the piano. I'll only be using switches for the first 13. And it looks like some are wired into series? I don't know. If you ask for a certain picture to help, I can make that happen.
    #2
    1. Advertisements
  3. christian10992
    davenn Moderator
    9,913
    1,005
    Sydney, Australia
    Hi there, welcome to the forums :)
    not quite series, but a matrix layout similar to this below....
    [​IMG]
    you can see on your one how there is a greyish material over the 1/2 circles. Its a conductive paste .... it would probably have to be scrapped off to get at the metal pad below it then you could solder to that pad
    cheers
    davenn, Jan 13, 2014
    #3
  4. christian10992
    christian10992
    Jan 13, 2014
    4
    Okay. Where the pads are are also sensors though. Velocity sensors. I would just have to scrape and solder where they connect and not do anything else? I'm just making sure I don't cause a short or anything.
    #4
  5. christian10992
    davenn Moderator
    9,913
    1,005
    Sydney, Australia
    I dont see any sensors, where are they ??
    #5
  6. christian10992
    christian10992
    Jan 13, 2014
    4
    They are under the conductive paste I guess. When you touch that area, it registers how hard you pressed and transmits the signal accordingly, similar to how a real piano would work.
    #6
  7. christian10992
    davenn Moderator
    9,913
    1,005
    Sydney, Australia
    dont think that would be sensors in the true meaning of the word
    I suspect that the conductive paste ( solid as it is) will give a change in resistance the harder the shorting pad is pushed across the 2 contacts
    #7
  8. christian10992
    KrisBlueNZ Sadly passed away in 2015 VIP Member
    Nov 28, 2011
    8,390
    1,254
    Wellington, New Zealand
    Touch-sensitive music keyboards detect the force applied to each key by measuring the time delay between when the first contact closes, and when the second contact closes.
    The harder you hit a key, the faster the key will move. As the key comes down, it presses two blister-like bits of carbon-coated rubbery plastic onto the two pads on the board, but one blister touches first. I think it's the back one that touches first.
    The microcontroller at the other end of the ribbon cable scans the contacts continuously. When two contacts on the same key close in order, it measures the time between the closures and uses this to calculate the key velocity.
    If you want your organ pedals to be touch-sensitive you will have to duplicate this behaviour, using two switches on each pedal. This could be a problem because standard switches (such as microswitches) suffer from contact bounce (Google it) and this could cause the microcontroller to misread them, causing unreliable behaviour. You will also need to get the delay between contact closures into the right range so that the microcontroller reports a reasonable range of touch velocities
    If you don't want velocity sensitivity for the pedals, you may be able to use a single contact of each key. It depends how the code in the scanning microcontroller deals with abnormal conditions. One keyboard I had would respond to the second contact closing without the first one closing by reporting maximum velocity; if yours works like that, you could go that way. You can test how the microcontroller behaves by manually pressing a carbon-coated blister onto each contact of a key in turn, and seeing whether it gives any consistent and useful result. I hope you can get something useful with a single contact closure; if not, you might be forced to use two switches per pedal, or a two-pole switch that can be connected across both sets of blister contacts to make it appear that they both closed at the same time.
    You may have some trouble soldering to the blister contact pads (and you may want to avoid spoiling them, too), but you can trace the tracks from the pads to the nearest diode or connector pin and solder to them instead.
    Each switch in your pedal assembly needs to be wired across the appropriate pair of blister contacts on the board. You don't need to use two separate wires for each switch; you can take advantage of the commoning that is already present on the circuit board to reduce the number of wires.
    You also need to minimise the capacitance of the connections to the switches, because they are being scanned constantly at a fairly fast rate. This means keeping wires as short as possible, and using good quality switches with good electrical isolation.
    Ideally, it would be best if you could manually transfer the movement of the pedals onto the existing plastic blisters, and keep the switch contacts on the board.
    Alternatively, you could build a complete replacement board - duplicate the connector and diodes onto your own circuit board, so you wouldn't need to modify the original board at all - just plug the ribbon cable into yours.
    KrisBlueNZ, Jan 13, 2014
    #8
    1. Advertisements
Similar Threads
  1. bg_ie@yahoo.com
    Digital control of analog pedals
    bg_ie@yahoo.com, Mar 8, 2006, in forum: Electronic Design
    657
    Walter Harley
    Mar 9, 2006
  2. Rid
    Zoom guitar pedals schematic Dim display
    Rid, Aug 9, 2003, in forum: Electronic Repair
    602
  3. Mad Scientist Jr
    1,412
  4. electronoobz
    help! How to put switch on DIY guitar pedals?
    electronoobz, Sep 25, 2012, in forum: General Electronics Chat
    9
    984
    electronoobz
    Sep 26, 2012
  5. itanc999
    Flaming Pipe Organ / Midi HT Spark Controller
    itanc999, Feb 23, 2014, in forum: Electronic Projects
    432
    itanc999
    Mar 3, 2014
Loading...
