Microwave oven
Discussion in 'Electronic Repair' started by Richard G. Gould, Oct 19, 2008.
  1. It appears that our microwave oven has lost cooking/heating power over the
    years. Is that possible: Can the magnetron put out less power as it ages?
    How can one test the heating power of a microwave oven: Perhaps by heating
    a known quantity of water to a desired rise in temperature over a prescribed
    time period? Are there any such measures for a microwave oven of a known
    original/rated power?
    Rick
    #1
    1. Advertisements
  2. Richard G. Gould
    Franc Zabkar Guest
    On Sun, 19 Oct 2008 02:22:41 GMT, "Richard G. Gould"
    <> put finger to keyboard and composed:
    >Rick
    Notes on the Troubleshooting and Repair of Microwave Ovens
    7.1) Testing the oven - the water heating test:
    http://www.repairfaq.org/REPAIR/F_micfaq4.html#MICFAQ_017
    - Franc Zabkar
    Please remove one 'i' from my address when replying by email.
    Franc Zabkar, Oct 19, 2008
    #2
    1. Advertisements
  3. Richard G. Gould
    GregS Guest
    >the
    >heating
    >prescribed
    >> It's not a magnetron, it's a klystron. It's a tube and tubes get weak.
    >> But more likely, one of the power sources has become weak.
    >I don't know where you get your information, but microwave ovens use
    >magentrons. A klystron is a rather different sort of microwave device. For
    >one thing, it's an amplifier, not an oscillator (unless you misalign it,
    >especially the B cavity).
    >I know about these things, because I used to install and align klystrons. I
    >could tell you a few "Jedi tricks".
    I suppose they still use Klystrons as deep space power amplifiers such as in Apollo missions.
    I think the standard power was 20 KW and made by Collins. A Hydrogen Maser
    was also used as a low noise amplifier and was used as the primary frequency
    standard, Cesium second. I just updated my learning from the web. A Cesium
    standard is basically a Xtal oscillator buffered with a atomic feedback loop and
    has poor short term stability. The Maser has the best short term stability and porr long term.
    greg
    GregS, Oct 23, 2008
    #3
  4. Richard G. Gould
    GregS Guest
    >> I suppose they still use klystrons as deep-space power amplifiers
    >The Apollo mission was not "deep space". Nevertheless, I installed several
    >Varian klystrons in NASA's STDN.
    Well the moon was a bit farther away. I don't remember what things
    were tracked by the maser. Maybe it was just a backup, but easily overloaded
    on strong signals. All the 3 main 85 foot MSFN/STDN stations had masers.
    After Apollo, ERTS or Landsat was the main preoccupation. Tracking the
    Alsep packages on the moon was also done for a VLBI experiment.
    After that the stations were also recording Helios orbiting the Sun, a
    very week signal. You really had to play with it to get phase lock.
    Here is a link to the NASA bible for the stations. Its a big file....
    http://zekfrivolous.com/nasa/NASA-SP-87.pdf
    greg
    GregS, Oct 24, 2008
    #4
  5. Richard G. Gould
    Arfa Daily Guest
    "Richard G. Gould" <> wrote in message
    news:RRwKk.2054$...
    > ages? How can one test the heating power of a microwave oven: Perhaps by
    > heating a known quantity of water to a desired rise in temperature over a
    > prescribed time period? Are there any such measures for a microwave oven
    > of a known original/rated power?
    > Rick
    The waveguide on the output of the mag (and it is a mag - ignore what
    clodhopper says below about it being a klystron) can become coated with
    resolidified vapourised grease and clag from the food that's been cooked in
    it - especially if it is a combination type that has a conventional oven in
    it as well. This can result in substantially reduced microwave cooking
    efficiency.
    Arfa
    Arfa Daily, Oct 24, 2008
    #5
  6. Richard G. Gould
    Turbo_Boss
    Oct 24, 2008
    Panama Republic of Panama
    Check this web site:
    .repairfaq.org/sam/micfaq.htm
    Turbo_Boss, Oct 24, 2008
    #6
  7. Richard G. Gould
    Baron Guest
    Ron Johnson wrote:
    > It is possible (IME) for magnetrons to lose power over time, sometimes
    > the antenna cap gets eroded away and sometimes you find cracks in one
    > of the magnets.
    > Ron
    Yes they do loose power over time ! It depends upon how fast the
    filament/cathode looses the ability to produce electrons. Often
    Thoriated Tungsten is used in the heater ! If it gets hammered it
    rapidly looses emission.
    Best Regards:
    Baron.
    Baron, Oct 25, 2008
    #7
  8. Richard G. Gould
    neon VIP Member
    Oct 21, 2006
    1,324
    FANTASTIC YOU TELL ME THIS AFTER I SPEND MONEY FOR A CESIUM ATOMIC CYNCH WATCH. Stupid thing misses a second every 20 millions years. wasted my money again.
    neon, Oct 26, 2008
    #8
    1. Advertisements
Similar Threads
  1. Jimmy
    Microwave oven transformers
    Jimmy, Jan 6, 2004, in forum: General Electronics
    4
    899
    Robert Baer
    Jan 8, 2004
  2. Soyrunner
    Samsung Microwave & GE Microwave oven
    Soyrunner, Sep 20, 2004, in forum: Electronic Repair
    5
    2,175
    Sam Goldwasser
    Mar 15, 2005
  3. Replies:
    15
    1,088
    jimmyjames
    May 23, 2005
  4. Replies:
    7
    903
  5. Replies:
    4
    2,257
Loading...
