Microwave diode bad?
Discussion in 'Electronic Repair' started by Andrew Rossmann, Aug 28, 2011.
  1. I have an older, 1998 GE Microwave oven. By the LG parts inside,
    probably just a rebadged LG. Lately, it's tended to 'thunk' when the
    magnetron turns on. A few times, it started rapidly cycling. Once, I
    didn't stop it in time and it blew it's 20A fuse. Another time, just
    starting normally, it tripped a circuit breaker.
    I opened it up and checked. So far, the only obvious thing I can see is
    that the large diode between the transformer and ground may be open. I
    get infinite resistance in both directions. I assume there is nothing
    special about testing these types of diodes?
    It's an HVR-1X diode. This appears, based on some Googling, to be very
    common, and the HVR-1X3 seems to be a common replacement.
    Do the symptoms I describe seem to go with the way the microwave is
    acting? I'm not certain just what the true function of the diode is in
    this case (I know how a diode itself works). There is also what looks
    like a starter cap. It's rated at 1uF, and my meter says 1.15uF or so.
    Do you think it's worth trying to replace it? I did buy a replacement
    microwave, but regret it. It's basically the same, but has some issues I
    don't like (display too far back from front, so you have to squat down
    to see it while typing on the panel. Fan goes REAL fast when magnetron
    off, then seems to nearly die when it's on.)
    If there is a no_junk in my address, please REMOVE it before replying!
    All junk mail senders will be prosecuted to the fullest extent of the
    law!!
    http://home.comcast.net/~andyross
    #1
    1. Advertisements
  2. In article <>,
    says...
    very
    > That diode is spec'ed at having a large forward voltage drop (10-14
    > volts). I regular ohm meter will not provide a voltage that high and
    > will show open.
    Is there a simple setup I can create to test it?
    law!!
    #2
    1. Advertisements
  3. In article <-september.org>,
    andysnewsreply@no_junk.comcast.net says...
    > In article <>,
    > says...
    > very
    > > will show open.
    I guess I'll answer my own question! I used a 12V UPS battery I had
    (12.89V measured) and checked if I could measure voltage through it. The
    diode does work and measured about 9.5V.
    Any other ideas on what could cause the power surge when the magnetron
    is activated? The waveguide is clean. I removed the mica cover over it,
    and there was nothing inside.
    law!!
    #3
  4. Spamm Trappe
    Spamm Trappe Guest
    Re: Microwave oven diode bad?
    On Sun, 28 Aug 2011 10:55:50 -0400, Michael A. Terrell wrote:
    > There are not regular diodes. There are a stack of diodes, and have
    > a higher forward voltage drop.
    Since there obviously lacking, their ought to be continuing education
    classes where illiterates can improve they're language skills.
    Spamm Trappe, Aug 28, 2011
    #4
  5. Jamie
    Jamie Guest
    That diode you speak of can not be tested in a conventional DIODE test
    in a DMM. It has several single diodes in series to up the over all
    operating voltage, each one ~ 0.6 volt drop. Most basic diode modes in
    DMM will only cover up to 2/3 in series. Long story short, you need
    more voltage to be applied to the diode for a test. Some of us have
    HV variable supplies, some crude, some elegant, like mine :)
    A Varistate, HV transformer and HV probe works well to test these.
    Jugging from your description, my guess would be a bad magnetron, one
    that has an intermitting short.
    Jamie
    Jamie, Aug 28, 2011
    #5
  6. Jamie
    Jamie Guest
    >>In article <>,
    >> says...
    >>very
    >>>will show open.
    Doing a forward test on a HV diode does not mean it's good, you still
    could have a break down problem with HV entered.
    Jamie
    Jamie, Aug 28, 2011
    #6
  7. Jamie
    Jamie Guest
    Discussing such matters with MT is futile. Give it enough time, you'll
    also be editing your list.
    Jamie.
    Jamie, Aug 28, 2011
    #7
    1. Advertisements
Similar Threads
  1. Russ
    8
    811
  2. The Real Andy
    Bad Sony, Bad
    The Real Andy, Nov 10, 2005, in forum: Electronic Design
    4
    645
  3. Soyrunner
    Samsung Microwave & GE Microwave oven
    Soyrunner, Sep 20, 2004, in forum: Electronic Repair
    5
    1,985
    Sam Goldwasser
    Mar 15, 2005
  4. BigMike
    4
    685
    BigMike
    Jan 5, 2006
  5. The Dog
    Not bad... Not bad at all...
    The Dog, Feb 20, 2004, in forum: Home Power and Microgeneration
    3
    503
    William P.N. Smith
    Feb 21, 2004
Loading...
Share This Page
