microcontroller for FFT
Discussion in 'Electronic Design' started by Matt Warnock, Jan 31, 2004.
  1. Matt Warnock
    Matt Warnock Guest
    I'm looking for a microcontroller that can sample audio and do a FFT for
    freq 400hz->4khz. I need the fund freq and the amplitude. What is a good
    processor to look at?
    #1
    1. Advertisements
  2. Matt Warnock
    Mark Little Guest
    There are other factors that will determine what suits your requirements.
    For example, what dynamic range are you looking for? Some microcontrollers
    have built-in A/D converters but they may or may not provide the dynmaic
    range that you require. Also, the frequency resolution that you require will
    influence what you need. The finer you want to make the resolution of the
    spectral estimates, the more memory you will require.
    If you describe your project people may be able to give appropriate
    suggestions.
    regards,
    Mark
    "Matt Warnock" <> wrote in message
    news:...
    Mark Little, Jan 31, 2004
    #2
    1. Advertisements
  3. Matt Warnock
    onestone Guest
    If you need to do this in real time I would suggest using a DSP, or an
    ARM. You can do it on a micro, but at 8000 samples a second you have
    just 125 usecs to run the calculation, many low end DSP's can't handle
    that. As Mark said it also depends on the resolution you require. More
    resolution = more RAM required, and of course more calculations. If you
    don't need real time the MSP430 has a built in 12 bit A/D, for decent
    dynamic range, and a 16 bit architecture, including multiplier for MACS
    operations. It can readily handle a 128 bin FFT, and there is sample
    code available for this.
    Cheers
    Al
    onestone, Jan 31, 2004
    #3
  4. It depends of course on the number of points needed... A low range
    microcontroller can do but you will need at least enough on-chip RAM to
    store the FFT buffer. For exemple on my own PIC'Spectrum design (published
    in '99 in Circuit Cellar) I used a PIC17C756 to :
    - Acquire in real time an audio signal at 16Ksps
    - Calculate the FFT of the signal, using a 256 points 16-bits fixed point
    FFT. This FFT itself took around 40ms
    - Generate in real time the FFT spectrum on a VGA display using
    software-generated video
    By the way I've now ported this original FFT routine on the 18F family, this
    code is available on a royalty-base. Contact me at if
    interested.
    Friendly yours,
    Robert Lacoste - ALCIOM : The mixed signals experts
    http://www.alciom.com
    "Matt Warnock" <> a écrit dans le message de
    news:...
    Robert Lacoste, Jan 31, 2004
    #4
  5. Matt Warnock
    Tim Shoppa Guest
    "Matt Warnock" <> wrote in message news:<>...
    You say you need an FFT... and then you say that you need fundamental
    frequency and amplitude. Those requirements aren't necessarily
    contradictory, BUT keep in mind that a FFT of 100000 points is in
    itself 100000 numbers (actually 200000 with phase information), and
    picking the two quantities out of the FFT isn't necessarily easier
    than picking them out of the time series.
    If all you really need is the fundamental frequency and amplitude, and
    the "fundamental" is clean and dominant, a frequency counter and a
    lock-in amplifier will get you there far more elegantly. Doing those
    functions in a low-end microcontroller is very feasible.
    Tim.
    Tim Shoppa, Jan 31, 2004
    #5
  6. Matt Warnock
    Ian Buckner Guest
    "Tim Shoppa" <> wrote in message
    news:...
    news:<>...
    FFT for
    is a good
    fundamental
    and
    those
    > Tim.
    Further, if you know what the fundamental frequency is,
    you could use a variant of the Goertzel algorithm, or a DFT
    of just the few frequency bins you are interested in.
    Regards
    Ian
    Ian Buckner, Feb 2, 2004
    #6
  7. Reminds me of the misguided effort to make submarine decoys with digital
    synthesis methods. They realized that you absolutely had to use analog back
    then, as any decent FFT would reveal the quantizing frequency of a
    synthesized wave and know it was no more than a decoy.
    And even today, that is probably still true- for some things, analog is
    still the best way to go.
    Cheers!
    Chip Shults
    Sir Charles W. Shults III, Feb 2, 2004
    #7
  8. Silicon Labs (Cygnal) has a FFT for one of their ~100 mHz 8051
    derivative processors on their web site in Keil C. it does a 5 kHz max
    input fft and dumps it to the serial port, gets its data from a 8 or
    12 bit dac on chip. I'd also look at Analog Devices DSPs. The
    development board it runs on is ~150$.
    See: http://www.silabs.com/products/pdf/an142rev1_1.pdf
    Steve Roberts
    Steve Roberts, Feb 2, 2004
    #8
  9. Matt Warnock
    Tim Wescott Guest
    TI, Motorola and Analog Devices all have good 16-bit DSPs, and I like them
    all equally well. I usually end up selecting by how well it's going to fit
    into the board.
    Tim Wescott
    Wescott Design Services
    http://www.wescottdesign.com
    "Steve Roberts" <> wrote in message
    news:...
    > Steve Roberts
    Tim Wescott, Feb 3, 2004
    #9
    1. Advertisements
Similar Threads
  1. Matt Warnock
    Matt Warnock, Jan 31, 2004, in forum: Electronic Basics
    8
    1,487
    Tim Wescott
    Feb 3, 2004
  2. Max Fazio
    FFT analysis : how to?
    Max Fazio, May 8, 2006, in forum: Electronic Components
    3
    1,069
    Lostgallifreyan
    May 8, 2006
  3. boki
    516
  4. joeyla
    Not the FFT ! (Audio Spectrum)
    joeyla, Sep 14, 2004, in forum: Electronic Design
    8
    502
    joeyla
    Sep 19, 2004
  5. Joerg
    Good FFT routines for sound card?
    Joerg, Jul 27, 2005, in forum: Electronic Design
    17
    723
    Joerg
    Aug 1, 2005
Loading...
