Maximum RF output for a 2sc2879 transistor
Discussion in 'Electronic Design' started by Night Ranger, Dec 26, 2003.
  1. Night Ranger
    Night Ranger Guest
    #1
    1. Advertisements
  2. John Todd
    John Todd Guest
    On 25 Dec 2003 22:57:19 -0800, Night Ranger <> wrote:
    >I've was looking at the specs on the Toshiba 2sc2879 transistor,...
    >http://www.toshiba.com/taec/components/Datasheet/2SC2879.pdf
    > and it claims a 100 PEP output, yet several CB amplifier
    >manufacturers claim to be getting twice that or more out of their amps
    >in class B service.
    >See;
    >http://www.davemade.com
    >and
    >http://www.xforceamps.com
    >Are they full of shit, or can you really exceed the transistor design
    >specs by that amount without blowing the transistor?
    >-Thanks
    Maybe that Toshie spec is for a single transistor? Maybe the
    "class B" is two transistors push-pull?
    _______________________________________
    John E. Todd <>
    Note: Ensure correct polarity prior to connection.
    John Todd, Dec 26, 2003
    #2
    1. Advertisements
  3. Hi,
    >in class B service.
    In days of yore, transmitting tubes had two sets of
    ratings - CCS and ICAS. Under the first they would loaf
    along and hopefully last a while, whereas with the second
    they were run close to maximum and only meant to be used
    intermittently. Although here we are talking about
    transistors, I suspect these people are applying the same
    philosophy.
    However, note that the Toshiba spec (100W) for the
    2SC2879 is for a single device and the CB linears they are
    peddling, unless I've read their sites incorrectly, are
    using at least two. The power in/out graph per device does
    show a capability of up to 140W, although the IMD at 100W is
    -24dB and worsening. One of them also specs the PEP output
    output using a Bird peak-reading meter and quotes the
    continuous output in W(rms)?
    Having said all of that, I suppose that the amps would
    deliver as stated if you don't mind changing the output
    devices fairly often.
    Cheers - Joe
    Joe McElvenney, Dec 26, 2003
    #3
    1. Advertisements
Similar Threads
  1. Hallvard Tangeraas
    Creating line-level output from speaker output
    Hallvard Tangeraas, Apr 3, 2005, in forum: Electronic Basics
    12
    2,402
    Hallvard Tangeraas
    Apr 12, 2005
  2. Doc
    13
    888
  3. Manju
    15
    685
    Jamie
    Sep 9, 2006
  4. Myron Samila
    Pulsing LEDs to achieve maximum output?
    Myron Samila, Apr 16, 2004, in forum: Misc Electronics
    7
    446
    Myron Samila
    Apr 17, 2004
  5. amidis86
    Timing coil transistor output to transistor?
    amidis86, Sep 24, 2012, in forum: General Electronics Chat
    17
    1,376
    duke37
    Oct 1, 2012
Loading...
