Make a latch (flip-flop) using two relays?
Discussion in 'General Electronics Chat' started by mank, Apr 14, 2011.
  1. mank
    mank
    Apr 14, 2011
    Had an interview today. There was a test. They wanted me to draw a diagram and this was what I was supposed to do:
    "Draw a latch (flip-flop) using two relays. Show inputs and outputs"
    I have never seen relays used in this way. I have been a Navy Electronics Technician and in the field for over 30 years.
    I just could not figure out how to do the 'toggle'.
    Anyone got any ideas?
    mank, Apr 14, 2011
    #1
    1. Advertisements
  2. mank
    19,596
    1,198
    Perhaps we should wait a few days, just in case...
    Here's some hints.
    1) can I wire a relay so that once power is applied, it latches on?
    2) how could I, with another relay closing, reset this?
    3) can I interconnect 2 of these together?
    I've never considered this either. I think the test was not so much about the flip-flop as how you think on your feet.
    I've posed questions of this nature to potential job applicants before. I was more interested in how they approached an unfamiliar problem, than how they solved it.
    (*steve*), Apr 14, 2011
    #2
    1. Advertisements
  3. mank
    Laplace VIP Member
    Apr 4, 2010
    1,184
    167
    Tombstone, Arizona
  4. mank
    19,596
    1,198
    But you can do it with just relays and switches.
    #4
  5. mank
    baileya
    Jan 31, 2013
    flip flop using two relays
    To answer the question on the flip flop using two relays, it can be done utilizing two timers , one timer to switch between the relays and the other timer to reset the circuit
    Start with one relay instantly energised , then timed off. Next switch on the other relay and provide a hold contact . The second timer is used to stop and reset the circuit allowing it to start the cycle all over again.
    I can draw out a circuit wiring diagram but not sure how to post the circuit on this site
    Cheers
    Arthur
    baileya, Jan 31, 2013
    #5
  6. mank
    Osmium
    Jan 28, 2013
    67
    17
    A lot of years ago, I made a flip-flop using two relays and two switches. I think I also had a light globe to show the state! Just like Steve says, think about it...
    --- Warning: Nostalgia piece...
    The school radio club used to get a lot of surplus telephone switching gear and other bits and pieces. Full of relays and all sorts. Kept us happy for ages! [btw our surplus gear was well and truly valve era. My first transistors to play with were OC45s and OC71s - and expensive!!]
    -Roy
    Osmium, Jan 31, 2013
    #6
  7. mank
    Lee Ssang
    Apr 18, 2016
    I think this link may answer your question:
    http://yamanashimasamune.blogspot.my/2016/04/flip-flop-or-bistable-latching-using.html
    Lee Ssang, Apr 18, 2016
    #7
  8. mank
    Colin Mitchell VIP Member
    Aug 31, 2014
    1,241
    290
    Look at this brilliant example:
    You short across the supply to turn the circuit off !!!!!
    Colin Mitchell, Apr 20, 2016
    #8
    1. Advertisements
Similar Threads
  1. Robert Monsen
    T flip-flop using opamps
    Robert Monsen, Aug 1, 2003, in forum: Electronic Design
    3
    1,619
    Robert Monsen
    Aug 1, 2003
  2. kuanmingtan@gmail.com
    How to using a JK flip-flop to build a 7 segment display ?
    kuanmingtan@gmail.com, Aug 30, 2006, in forum: Electronic Design
    10
    3,309
    vasile
    Sep 1, 2006
  3. Spehro Pefhany
    master-slave flip flop vs edge triggered flip flop.
    Spehro Pefhany, May 28, 2008, in forum: Electronic Design
    11
    3,948
  4. mag1979
    Help with counter using SR Flip Flop
    mag1979, Apr 8, 2011, in forum: Circuit Help
    768
    mag1979
    Apr 8, 2011
  5. handsomejackuk
    9
    1,819
    handsomejackuk
    Nov 14, 2011
Loading...
