Mains wiring: GFCI won't fit in the box!
Discussion in 'Misc Electronics' started by DaveC, Dec 6, 2003.
  1. DaveC
    DaveC Guest
    Convinced my landlord to pay for a GFCI in each bathroom. Now I come to find
    that it won't fit.
    The box is a single gang switch-box size with conduit connections above and
    below. The box is deep enough, but the GFCI (being quite a bit fatter and
    taller than a regular outlet) collides with the conduit fasteners inside the
    opening. The most I can stuff the GFCI in the box is about half way.
    Is there any option other than ripping out the wall paneling and putting a
    larger box that will accommodate the GFCI outlet?
    This is a Levitron GFCI.
    DaveC
    This is an invalid return address
    Please reply in the news group
    DaveC, Dec 6, 2003
    #1
    1. Advertisements
  2. Yes, there is a spacer available that adds about 3/8" to the box...it
    actually protrudes from the wall, but it is meant for just this situation
    and looks good. I dunno who has them...possibly Home Depot or Lowes. fyi,
    the ones I have seen are ivory plastic in color. if 3/8" isnt enough you may
    be able to stack them....pick up some long 6-32 screws while you are at it.
    The other possibility is to install a Wiremold type extension box....they
    are 3/4" deep (or deeper).
    "DaveC" <> wrote in message
    news:...
    find
    > that it won't fit.
    and
    the
    > Thanks,
    > DaveC
    User 1.nospam, Dec 6, 2003
    #2
    1. Advertisements
  3. DaveC
    James Sweet Guest
    news:...
    find
    > that it won't fit.
    and
    the
    Another idea, is there an outlet elsewhere in the house that's electrically
    before the bathroom outlets on the same run? If so you could install the
    GFCI outlet there and it'll protect the bathroom outlets as well. The other
    option is a GFCI circuit breaker for the main service panel.
    James Sweet, Dec 6, 2003
    #3
  4. DaveC
    SQLit Guest
    news:...
    find
    > that it won't fit.
    and
    the
    > Thanks,
    > DaveC
    CONDUIT? What around the 1930's era? Do you have a ground wire?
    You could always cut a new box into the wall near the other one and put a
    blank plate on the original.
    Yikes that is hideous. Easiest bet is to use a wire mold box for the
    application.
    SQLit, Dec 6, 2003
    #4
  5. DaveC
    DaveC Guest
    On Sat, 6 Dec 2003 15:16:30 -0800, SQLit wrote
    (in message <irtAb.33412$9O5.312@fed1read06>):
    > application.
    No, I'd guess 60's. It's an apartment building, and the code disallows romex.
    No ground wire; the conduit serves that purpose. Otherwise, I'd consider
    taking off the conduit nuts and cutting down the threads of the couplers. But
    I can't do that... Well, I could, but don't want to. :)
    DaveC
    DaveC, Dec 6, 2003
    #5
  6. I have no idea, here in Greece we put a GFCI in the main distribution panel
    for the whole installation (up to 4x63 A for 380 V line-to-line voltage).Of
    course, if it won´t fit the only possible solution would be to install a
    larger box.BTW, how much does an outlet with GFCI cost?Here, we charge 100
    euro for a 4X40 (RCCB is typed on the box, which means Residual Current
    Circuit Breaker).I usually prefer Geyer (german)ABB or Siemens.
    Dimitris Tzortzakakis,Greece
    Ï DaveC <> Ýãñáøå óôï ìÞíõìá óõæÞôçóçò:
    find
    > that it won't fit.
    and
    the
    > Thanks,
    > DaveC
    Tzortzakakis Dimitrios, Dec 7, 2003
    #6
  7. DaveC
    James Sweet Guest
    "Tzortzakakis Dimitrios" <> wrote in
    message news:br06p2$96d$...
    panel
    voltage).Of
    100
    Here a GFCI outlet is about $10, a 20A GFCI breaker for the main panel is
    around $30.
    James Sweet, Dec 7, 2003
    #7
  8. DaveC
    Guest
    >that it won't fit.
    >Thanks,
    The easiest solution is a Wiremold extension box. It will stick out
    of the wall, about an inch or less, but sure beats tearing the place
    apart. They look good, and can be painted to match the walls.
    , Dec 8, 2003
    #8
  9. DaveC
    DaveC Guest
    On Sun, 7 Dec 2003 17:47:36 -0800, wrote
    (in message <>):
    I'm beginning to agree. I looked at regular plastic box extensions, but these
    create a gap between the wall and the plate.
    Wiremold seems to extend the box (so code is happy) and fill the gap between
    wall and plate (so owner is happy).
    DaveC
    DaveC, Dec 8, 2003
    #9
    1. Advertisements
Similar Threads
  1. DaveC
    DaveC, Dec 6, 2003, in forum: Electronic Repair
    8
    1,063
    DaveC
    Dec 8, 2003
  2. John Miller
    Magnavox TV won't turn off, then won't turn on
    John Miller, Apr 17, 2004, in forum: Electronic Repair
    3
    1,848
    John Miller
    Apr 17, 2004
  3. David
    891
    David
    Jan 12, 2006
  4. Robin Coutellier
    CAR WON'T START - ALARM WON'T DISARM
    Robin Coutellier, Jan 30, 2004, in forum: Security Alarms
    7
    4,198
    The Good Bohemian
    Jan 31, 2004
  5. DaveC
    DaveC, Dec 6, 2003, in forum: Electrical Engineering
    7
    411
    DaveC
    Dec 8, 2003
Loading...
