Magnetron testing
Discussion in 'Electronic Repair' started by Blu3b3rrY, Aug 12, 2004.
  1. Blu3b3rrY
    Blu3b3rrY Guest
    Did magnetrons can be tested by simple ways? for example, using a
    Digital Multimeter
    How do I know if a magnetron is still good or defective?
    Is there an average measure o test between the magnetron's terminals
    That could be indicative of a failure?
    #1
    1. Advertisements
  2. (Blu3b3rrY) writes:
    > Digital Multimeter
    See the microwave oven repair guide at:
    http://repairfaq.ece.drexel.edu/REPAIR/
    --- sam | Sci.Electronics.Repair FAQ Mirror: http://repairfaq.ece.drexel.edu/
    Repair | Main Table of Contents: http://repairfaq.ece.drexel.edu/REPAIR/
    +Lasers | Sam's Laser FAQ: http://repairfaq.ece.drexel.edu/sam/lasersam.htm
    | Mirror Sites: http://repairfaq.ece.drexel.edu/REPAIR/F_mirror.html
    Note: These links are hopefully temporary until we can sort out the excessive
    traffic on Repairfaq.org.
    Important: Anything sent to the email address in the message header is ignored.
    To contact me, please use the feedback form on the S.E.R FAQ Web sites.
    Sam Goldwasser, Aug 12, 2004
    #2
    1. Advertisements
  3. Ken G.
    Ken G. Guest
    Its hard to tell on these new invertor ovens ..The tube can test totaly
    normal on an ohm meter but not work in the oven .
    Ken G., Aug 13, 2004
    #3
  4. (Ken G.) writes:
    Invertor power supply or not, this is true. Test the filament, test for
    shorts, closely examine for physical problems like cracked magnets.
    Beyond that, ruling out other causes and then going for a replacement
    is about the only safe option.
    Sam Goldwasser, Aug 13, 2004
    #4
  5. Art
    Art Guest
    Agreed, either it will or will not function. Open filament or shorts to the
    case tend to be common failures, cracked or broken magnets due to
    overheating or mechanical stress. Continuity check across the filaments for
    low reading and from filament leads to case for open.
    "Sam Goldwasser" <> wrote in message
    news:...
    > (Ken G.) writes:
    > | Mirror Sites:
    excessive
    ignored.
    Art, Aug 13, 2004
    #5
    1. Advertisements
Similar Threads
  1. Br Dan Izzo
    5
    2,059
    Captain Blammo
    Sep 8, 2004
  2. ian field
    MO magnetron xmitter
    ian field, Jul 27, 2006, in forum: Electronic Design
    445
    ian field
    Jul 28, 2006
  3. Max
    MAGNETRON 2M172AJ versus 2M167B
    Max, May 5, 2005, in forum: Electronic Repair
    5
    2,941
    Franc Zabkar
    May 8, 2005
  4. Why is a magnetron so costly
    , Sep 15, 2005, in forum: Electronic Repair
    8
    999
  5. nfman
    Testing Testing
    nfman, Aug 9, 2012, in forum: Off-Topic Members Lounge
    677
    (*steve*)
    Aug 9, 2012
Loading...
