lowest volume setting too loud
Discussion in 'Electronic Basics' started by Rick Martin, Jan 7, 2004.
  1. Rick Martin
    Rick Martin Guest
    Hello All,
    Hopefully this is an easy question for you electronics wizzes.
    I bought a mini stereo system/dvd player that I am happy with except for the
    volume. Even on the very lowest setting, it is too loud. Is there any kind
    of device that I can put inline between the outputs and the speakers that
    would "step down" the wattage making it to the speaker? And if they would
    cost a buck-a-piece at Radio Shack, that would be nice too;)
    Thanks in advance,
    -Rick
    0110100101100110001000000111100101101111011101010010000001100011011000010110
    1110001
    0000001110010011001010110000101100100001000000111010001101000011010010111001
    1001011
    0000100000011110010110111101110101001000000111001001100101011000010110110001
    1011000
    1111001001000000110000101110010011001010010000001100001001000000111010001100
    1010110
    00110110100001101110011011110010000001100111011001010110010101101011
    #1
    1. Advertisements
  2. Rick Martin wrote:
    > Hello All,
    > Thanks in advance,
    > -Rick
    If it is that poorly designed I would take it back and demand my
    money back. There is no reason to keep garbage like this. It just
    encourages the manufacturers to build lower and lower quality garbage.
    We now return you to our normally scheduled programming.
    Take a look at this little cutie! ;-)
    http://home.earthlink.net/~mike.terrell/photos.html
    Michael A. Terrell
    Central Florida
    Michael A. Terrell, Jan 7, 2004
    #2
    1. Advertisements
  3. Rick Martin
    Grumpy OM Guest
    "Rick Martin" <> wrote in message news:<UEIKb.241$>...
    > Hello All,
    > Thanks in advance,
    > -Rick
    Rick,
    Something wrong there. The volume control should take it down to
    zero. Suggest you take it back from wence it came.
    Grumpy
    Grumpy OM, Jan 7, 2004
    #3
  4. Rick Martin
    Rick Martin Guest
    It does take it down to zero. Zero has no sound and the next setting (1) is
    too loud. It was $59 and has cd/dvd/am/fm and is just for the bedroom.
    Don't want to spend alot for a bedroom system and thought that I might be
    able to add some cheap resistors. But I'm not exactly sure how resistors
    work. I'm thinking that they have a max output, but more intput is
    converted to heat in which case they wouldn't serve my purpose. Is my
    thinking correct? Maybe it's not worth all of the trouble and I should just
    dampen the sound some other way or take it back, but I thought the post was
    worth a try and that there might be some fairly easy way to step down the
    wattage on the way to the speakers which would give me lower volume while
    keeping the functionality of the volume control.
    Thanks anyway.
    "Grumpy OM" <> wrote in message
    news:...
    > > Hello All,
    the
    kind
    that
    would
    > > Thanks in advance,
    > > -Rick
    > Rick,
    > Grumpy
    Rick Martin, Jan 8, 2004
    #4
  5. Rick Martin
    Steve Guest
    He may be talking about a step incremented volume control in which the
    first step above zero (silence) is too loud for his application.
    I had this once on a Grundig TV. In the dead quiet of night the TV
    was quite loud, but one increment down was silence. Made it hard to
    watch late night TV without disturbing the house mates.
    It was less of a problem when I got the satellite receiver, as it had
    it's own volume control as well. Perhaps Ricks new DVD player has a
    volume control?
    Try an L-pad of the appropriate wattage rating;
    http://www.lashen.com/vendors/csispeco/Installation/L-Pads.asp
    niftydog
    Steve, Jan 8, 2004
    #5
  6. Rick Martin
    Rick Martin Guest
    Exactly! Thanks for a real answer. I ended up going to radio shack and
    getting basically what you recommend. Works perfectly. Now I can listen to
    some quiet music while going to sleep.
    "Steve" <> wrote in message
    news:...
    > volume control?
    > niftydog
    Rick Martin, Jan 9, 2004
    #6
    1. Advertisements
Similar Threads
  1. Joe D
    Sony Wega minimum volume still too loud
    Joe D, Dec 15, 2004, in forum: Electronic Repair
    11
    912
    Joe D
    Dec 24, 2004
  2. rgt
    TV Volume Too Loud
    rgt, Dec 16, 2004, in forum: Electronic Repair
    5
    1,435
    Fred McKenzie
    Dec 19, 2004
  3. Jacques Carrier
    Jacques Carrier, Dec 17, 2004, in forum: Electronic Repair
    487
    Jacques Carrier
    Dec 17, 2004
  4. lowest leakage, lowest Vf diode?
    , Apr 24, 2007, in forum: Electronic Design
    21
    1,468
  5. Jeroni Paul
    SABA CT9810 volume too loud
    Jeroni Paul, Aug 17, 2008, in forum: Electronic Repair
    5
    821
    Jeroni Paul
    Aug 18, 2008
Loading...
