Load cells / Sensitivity
Discussion in 'Electronic Design' started by Efthimios, Feb 3, 2008.
  1. Efthimios
    Efthimios Guest
    In the specs the load cells sensitivity is given "mV/V" ex: 2mV/V.
    How this is translated to force sensitivity, for example: mV/grf?
    #1
    1. Advertisements
  2. hrh1818
    hrh1818 Guest
    On Feb 3, 1:35 pm, Efthimios <> wrote:
    > Hi,
    A load cell sensitivity is stated in terms of its rated full scale
    load. An equation for the output would be:
    Eout = (Sensitivity/Full scale load) * (Excitation Voltage) * (Applied
    Force.)
    Example Sensitivity = 2mv/V, Full Scale Load = 5 Kg, Excitation
    Voltage = 10 Volts DC, Applied Load = 2.5 Kg
    Eout = (2/5)* 10*2.5
    Eout = 10 mV DC
    Howard
    hrh1818, Feb 4, 2008
    #2
    1. Advertisements
  3. Efthimios
    Efthimios Guest
    > > Hi,
    > Force.)
    > Eout = 10 mV DC
    > Howard
    Thanks Haward for the info.
    Do you know if load cells/force sensors can pick up vibrations of up
    to 1kHz? I can not find in the specs of the cells any info.
    Efthimios
    Efthimios, Feb 4, 2008
    #3
  4. hrh1818
    hrh1818 Guest
    > > > Hi,
    > > Force.)
    > > Eout = 10 mV DC
    > > Howard
    > Efthimios
    Two comments. A Google search on "load cell frequency response"
    turned up several links to companies who said they make load cells
    with a high frequency response. Only one mentioned an actual number.
    That was Honeywell who said their Sensotec Model 11 can have a
    frequency response up to 58 kilo hertz. Load ranges vary from 150
    grams to 1000 lbs. I expect only load cells at the 150 gram end of
    the range can achieve a 58 kilo hertz frequency response and there is
    a drop off of the frequency response as the size of the load cell is
    increased.
    Howard
    #4
    1. Advertisements
Similar Threads
  1. Enzo
    load cells
    Enzo, Aug 18, 2005, in forum: Electronic Design
    4
    615
    John Fields
    Aug 18, 2005
  2. Enzo
    Load cells
    Enzo, Aug 19, 2005, in forum: Electronic Design
    442
    Paul Burke
    Aug 19, 2005
  3. SHIRLEY ANDERSON
    new concept in solar cells: ambient solar cells....
    SHIRLEY ANDERSON, Jan 21, 2004, in forum: Photovoltaics
    558
    Scott Willing
    Jan 21, 2004
  4. Jason Crowell
    Concentrator Cells vs Conventional Cells
    Jason Crowell, Mar 7, 2004, in forum: Photovoltaics
    560
    Anthony Matonak
    Mar 7, 2004
  5. lodevaduh
    673
    55pilot
    Mar 9, 2010
Loading...
Share This Page
