LED SOUND PROJECT HELP
Discussion in 'Electronic Design' started by marxmith@gmail.com, Jun 10, 2008.
  1. Guest
    I'm working on a painting that I want to incorporate some electronics
    into. I want to have a button on the front of the painting that, when
    pressed, will play a 20 second audio clip as well as cause two LEDs to
    flash for the duration of the sound. I see that you sell a sound
    circuit that looks like it will work for my sound needs. Is there a
    way to tie that in with an led circuit that will cause the lights to
    blink only for the duration of the sound clip? It's important that
    only one button triggers both the sound and the lights; and that it
    automatically shuts off after the sound clip is over. Also, the
    brighter the two lights, the better. I have some rudimentary
    experience with soldering and and electronics projects, but I do not
    have the skills to simply and efficiently execute what I have
    described here. Any advice, instructions, and/or diagrams you have
    would be helpful.
    Thank you,
    Mark
    , Jun 10, 2008
    #1
    1. Advertisements
  2. Frank Buss Guest
    Who is "you"? You were posting to a newsgroup. See this article to learn
    more about newsgroups:
    http://en.wikipedia.org/wiki/Usenet_newsgroup
    > Is there a
    How do you want the LED to blink? Blining with the beat of the music, or
    just blinking? Which frequency and duty cycle?
    You could use one of those cheap MP3 players, attach a cheap PC active
    speaker to it and use the audio output of the MP3 player to control an LED
    (amplified with an op-amp). If one button click doesn't start the sound,
    you could translate it with a small microcontroller.
    Frank Buss,
    http://www.frank-buss.de, http://www.it4-systems.de
    Frank Buss, Jun 10, 2008
    #2
    1. Advertisements
Similar Threads
  1. Sound Modulated LED Project Help
    , May 3, 2006, in forum: Electronic Design
    22
    926
    Phil Allison
    May 4, 2006
  2. LED SOUND PROJECT HELP
    , Jun 10, 2008, in forum: Electronic Basics
    403
    Allen Bong
    Jun 11, 2008
  3. dynamis_dk
    LED's in PCB project - using different LED's
    dynamis_dk, Jan 27, 2010, in forum: General Electronics Chat
    8
    2,676
    dynamis_dk
    Feb 1, 2010
  4. wiganwez
    13
    1,522
    davenn
    Sep 20, 2011
  5. chris8477a
    LED sound to light project. Update
    chris8477a, Feb 14, 2012, in forum: Electronic Projects
    5
    2,163
    (*steve*)
    Feb 14, 2012
Loading...
