led dimmer circuit
Discussion in 'Electronic Design' started by davesuejon@yahoo.co.uk, Jun 4, 2006.
  1. Guest
    i would like a simple circuit that could be used to dim a high
    brightness white led for installation inside a bird box for a colour
    camera. i don't want to scare the birds by a simple on / off . A
    gradule increase in brightness would be good. i have tried a resistor
    in series followed by another variable resistor which works to a degree
    but there comes a point when the brightness suddenly increases with a
    small turn of the pot. could anyone post a simple cicuit please ?
    , Jun 4, 2006
    #1
    1. Advertisements
  2. Nico Coesel
    Nico Coesel Guest
    The LED brightness depends on the current. It is easy to make a
    voltage to current converter with an opamp:
    http://www.allaboutcircuits.com/vol_3/chpt_8/7.html/conversion
    Substitute Rload by the LED.
    Reply to nico@nctdevpuntnl (punt=.)
    Bedrijven en winkels vindt U op www.adresboekje.nl
    Nico Coesel, Jun 4, 2006
    #2
    1. Advertisements
  3. mc
    mc Guest
    But there should also be no problem using resistors. What resistances are
    you using (fixed and variable) and is the variable one linear-taper or
    audio-taper?
    mc, Jun 4, 2006
    #3
  4. Don Bowey
    Don Bowey Guest
    On 6/4/06 6:41 AM, in article 1cCgg.4187$,
    > audio-taper?
    Resistors won't do the job. Post this on the basics board, or better yet,
    google for led dimmer. You need a circuit that varies the length of time
    the LED is fully powered, reducing it gradually to zero.
    This has been answered a jillion.5 times.
    Don Bowey, Jun 4, 2006
    #4
  5. Fred Bloggs
    Fred Bloggs Guest
    This will convert the variable resistor into a linear control over full
    off to on range, start out with 100 ohm pot fully CCW for LED off:
    View in a fixed-width font such as Courier.
    Fred Bloggs, Jun 4, 2006
    #5
  6. John Fields
    John Fields Guest
    On Sun, 04 Jun 2006 07:53:06 -0700, Don Bowey <>
    >> audio-taper?
    Sure they will: (View in Courier)
    +V
    [POT]<--[R]--[LED>]--+
    GND GND
    John Fields
    Professional Circuit Designer
    John Fields, Jun 4, 2006
    #6
  7. Pooh Bear
    Pooh Bear Guest
    > >> audio-taper?
    > +V
    > GND GND
    That's shockingly inefficient. you might at least have used a transistor.
    Graham
    Pooh Bear, Jun 4, 2006
    #7
  8. Fred Bloggs
    Fred Bloggs Guest
    This one might be a little easier, less battery drain and more readily
    available parts- use any small signal transistors- the variable resistor
    is totally linearized:
    #8
  9. Don Bowey
    Don Bowey Guest
    On 6/4/06 9:33 AM, in article ,
    >>> audio-taper?
    > +V
    > GND GND
    Well, sure if you don't care that it doesn't work well.
    You are becoming a regular troll.
    #9
  10. James Waldby
    James Waldby Guest
    Pooh Bear wrote:
    > John Fields wrote:
    > > ... Don Bowey ... wrote:
    > > > ..."mc" ... wrote:
    [>>>>>OP "davesuejon" wrote]
    > > +V
    > > GND GND
    Here's a "more-efficient" approach, in that all of the current
    used (except a few hundred uA) goes through the LED:
    .. VR
    .. +-------I O-----------+
    .. | A |
    .. | | R1
    .. Bat | | | |
    .. | | | D |
    .. | +---->R2 | |
    .. | +--+ Led
    .. | R3 |
    VR is a 3-terminal regulator, like LM317, although I used
    a LX8383, having a bunch on hand. I used: R1 = 11 ohms,
    R2 = 5K pot, R3 = 1K, D = a diode.
    -jiw
    James Waldby, Jun 4, 2006
    #10
  11. John Fields
    John Fields Guest
    On Sun, 04 Jun 2006 17:59:58 +0100, Pooh Bear
    >> >> audio-taper?
    >> +V
    >> GND GND
    The OP asked for simple, not for efficient. :)
    John Fields
    #11
  12. Nico Coesel
    Nico Coesel Guest
    >> audio-taper?
    PWM may cause interference when using a digital camera.
    #12
  13. Fred Bloggs
    Fred Bloggs Guest
    >>> +V
    >>> GND GND
    > . VR
    > . | A |
    > . | | R1
    > . Bat | | | |
    > . | | | D |
    > . | +---->R2 | |
    > . | +--+ Led
    > . | R3 |
    > -jiw
    How do you figure that? If the LED goes to 3.3V, you end up with
    3.3-0.7=2.3V across R3 for 2.3mA. And you need to make R1 more like 39
    ohms, since the LEDs do not like continuous operation at more than 30mA.
    Then because 'D' has an orientation, you might show it.
    #13
  14. Fred Bloggs
    Fred Bloggs Guest
    yeah-right...
    #14
  15. James Waldby
    James Waldby Guest
    [...]> > > >>>> i have tried a resistor
    > > > +V
    > > > GND GND
    I forgot to show input and output capacitors for the VR -
    .. VR
    .. +---+---I O-----------+---+
    .. | | A | |
    .. | | | R1 |
    .. | | | +--+-D1-+ |
    .. Bat | | | | | |
    .. | | | | D2 | |
    .. | | +---->R2 | | |
    .. | | | | Led |
    .. | C1 R3 | C2
    Also, the circuit I posted before showed D2 but not D1; the
    circuit I tested included D1. D1+D2 = 1 dual-diode MMBD7000.
    D1 can be left out if R1 is made slightly larger.
    -jiw
    #15
  16. John Fields
    John Fields Guest
    On Sun, 04 Jun 2006 11:02:54 -0700, Don Bowey <>
    >> +V
    >> GND GND
    What do you mean? 0 mA into the LED at the bottom of the pot, 20mA
    at the top, and something between that as the pot gets rotated.
    Maybe not all that efficient, but who cares? The OP wants something
    simple, and it's just 3 parts.
    You and frog seem to think so. ;)
    John Fields
    #16
  17. James Waldby
    James Waldby Guest
    [see revision below]
    > > -jiw
    I think you're right, the loss would be a couple of mA rather than
    a few hundred uA. The 100 uA I was thinking of (by mistake) was the
    current in the Adjust pin of the VR.
    The circuit I built is shown more accurately in a post I made about
    the same time you were posting your comment, and still more accurately
    below. (My other post showed D1 and D2 but not D3, which was included
    to isolate multiple LED's)
    .. VR
    .. | | A | |
    .. | | | R1 |
    .. +| | | +--+-D1-+ |
    .. Bat | | | | | |
    .. -| | | | D2 | |
    .. | | +---->R2 | | | D1: |<
    .. | | | | LED |
    .. | | +--+ | | D2, D3: v
    .. | C1 R3 | C2 -
    .. | | D3 | |
    Here, the drop across D1-D3 is about 2V, so there would be
    1.3V across R3 (for a 3.3V LED), hence 1.3mA for R3=1K.
    To cut down that loss without D3 in the circuit, increase R3
    a bunch.
    You suggested 39 ohms for R1, vs the 11 ohms I used. With
    R2 slid to the D1 end, and 1.25 V at the A pin, and .65V
    across D1, there's .4 V on R1, or 36mA through it, so about
    34mA through the LED, a bit high. 15 ohms would limit LED
    current to 25mA; 39 ohms limits to 8mA. So 11 is too low
    and 39 too high, for the circuit above. With D1 not in there,
    your 39 limits LED current to about 30mA, so is good for the
    earlier circuit.
    Using D1 removes about .65V overhead from the LED current path,
    allowing the circuit to work on that much less battery voltage.
    -jiw
    #17
    > > +V
    > > GND GND
    > Graham
    Because transistors only light up ONCE? ;-)
    prove it.
    Member of DAV #85.
    Michael A. Terrell
    Central Florida
    Michael A. Terrell, Jun 4, 2006
    #18
  19. Don Bowey
    Don Bowey Guest
    On 6/4/06 11:22 AM, in article , "Nico
    >>> audio-taper?
    BFD. Lightning might be attracted to it too.
    Take your comment to the basics board.
    Don Bowey, Jun 5, 2006
    #19
  20. mc
    mc Guest
    >>>> are
    >>>> audio-taper?
    >>> yet,
    >>> time
    Will someone explain *why* resistors "won't do the job"?
    This is not a basic question. I am not the original poster. I understand
    about PWM and its advantages (saving power). But if an op-amp adjustable
    current source (which is not PWM) will do the job, surely so will a humble
    rheostat.
    Is there something strange about the current-vs-brightness relation of these
    LEDs?
    mc, Jun 5, 2006
    #20
    1. Advertisements
Similar Threads
  1. Gman
    27
    880
    ehsjr
    Sep 20, 2005
  2. andy
    luxeon led dimmer circuit
    andy, Oct 2, 2005, in forum: Electronic Basics
    9
    2,610
    redls1bird
    Oct 15, 2005
  3. Joel Moore
    Looking for opinions on LED dimmer circuit
    Joel Moore, Aug 27, 2005, in forum: Electronic Design
    24
    898
    Joel Moore
    Sep 8, 2005
  4. Question about PWM LED dimmer circuit
    , Jul 14, 2006, in forum: Electronic Design
    24
    2,304
    cpemma
    Jul 19, 2006
  5. Dungeon Dave
    12V LED dimmer/timing circuit advice required, please!
    Dungeon Dave, Dec 3, 2008, in forum: Electronic Design
    13
    2,170
    Preacher Kane
    Dec 7, 2008
Loading...
