LDR circuit ( Application of transistor as switch)
Discussion in 'Electronic Projects' started by vick5821, Jul 4, 2012.
  1. vick5821
    vick5821 VIP Member
    Jan 22, 2012
    700
    MALAYSIA
    Hey guys, I plan to make this simple circuit into a teaching aid for my secondary school teacher for them to let student understand better how LDR works and as an applicationof transistor as switch. So , I plan to make a DIY PCB for that. How am I able to design my circuit so as to easy measurement of the base current ? And what type of connector should I use so that the two point series in the circuit connected to an ammeter ?
    Attachment :
    [​IMG]
    #1
    1. Advertisements
  2. vick5821
    john monks VIP Member
    Mar 9, 2012
    693
    Richmond, California
    I'm afraid you will have to cut the circuit leading to the base and insert a microamp meter in the circuit. Looking at the circuit you may have to adjust the 100K resistor up or down the get the transistor to turn on at the right point.
    john monks, Jul 4, 2012
    #2
    1. Advertisements
  3. vick5821
    vick5821 VIP Member
    Jan 22, 2012
    700
    MALAYSIA
    Yayaya, cut at the leading to the base.then insert two header to be connected to ammeter right ?
    #3
  4. vick5821
    Mar 9, 2012
    693
    Yes sir.
    #4
  5. vick5821
    vick5821 VIP Member
    Jan 22, 2012
    700
    MALAYSIA
    what type of header?
    #5
  6. vick5821
    Mar 9, 2012
    693
    It mask no difference. I woud probably use banana jacks so that I could easily place a current meter in series with the bas and short out the banana jacks when no meter is in place.
    #6
  7. vick5821
    KrisBlueNZ Sadly passed away in 2015 VIP Member
    Nov 28, 2011
    8,390
    1,254
    Wellington, New Zealand
    It might be simpler to put the current shunt on the board and use a multimeter measuring voltage to display the current.
    For example if you choose a current shunt resistance of 1K, you put a 1K resistor in series with the base, with a 2-pin connector connected to the two ends of it. The circuit will work just the same whether or not the base current is being measured. Every microamp of base current will cause a millivolt of voltage drop across the resistor, which can be measured with a multimeter set to a voltage range.
    Another possibility would be to use a jack socket with a normally closed contact, so when nothing is plugged into it, the socket is shorted out and the circuit is complete. When you want to measure the current, you plug in a jack plug that is connected to a microammeter, and the action of plugging the plug into the socket breaks the short circuit and the base current flows through the milliammeter.
    I prefer the first suggestion though.
    KrisBlueNZ, Jul 5, 2012
    #7
  8. vick5821
    vick5821 VIP Member
    Jan 22, 2012
    700
    MALAYSIA
    you mean I put a resistor connected to the base ? and then I calculate the current based on theorectical value ?
    vick5821, Jul 5, 2012
    #8
  9. vick5821
    CDRIVE Hauling 10' pipe on a Trek Shift3 VIP Member
    May 8, 2012
    4,340
    533
    S. Florida USA
    Maybe they're not that common any longer but I'm sure they're still available. I'm speaking of Probe Jacks, also called Pin Jacks. Your DMM probes plug directly into them. Also, have you considered placing a 1K in series with the base and measuring the voltage drop instead of current? This way the circuit will work with or without the meter connected. A 1K resistor will give you a direct uA to mV conversion. Example 52uA will read 52mV. Just connect the jacks to opposite ends of the resistor.
    CDRIVE, Jul 5, 2012
    #9
  10. vick5821
    vick5821 VIP Member
    Jan 22, 2012
    700
    MALAYSIA
    Ya, now I get the idea. then I think I do not need the connector for the ammeter anymore. But I think I should make it easy to measure the voltage for the 1K resistor right ? Any easy implement method ? I plan to make this in quantity
    #10
  11. vick5821
    May 8, 2012
    4,340
    533
    S. Florida USA
    Looks like we doubled.
    CDRIVE, Jul 5, 2012
    #11
  12. vick5821
    vick5821 VIP Member
    Jan 22, 2012
    700
    MALAYSIA
    Eagle file :
    [​IMG]
    Havent finalised yet. Still need to think what to add to make this product better
    #12
  13. vick5821
    May 8, 2012
    4,340
    533
    S. Florida USA
    I don't know what your resources are in Malaysia but Digikey will carry the Pin Jacks that I mentioned.
    CDRIVE, Jul 5, 2012
    #13
  14. vick5821
    vick5821 VIP Member
    Jan 22, 2012
    700
    MALAYSIA
    Can I have a look perhaps ? Maybe I can purchase it ? Thank you
    #14
  15. vick5821
    CocaCola VIP Member
    Apr 7, 2012
    3,636
    Gurnee, Illinois - USA - North America - Planet Ea
    Why not just get a panel mount analog ammeter (about $4 on Ebay) and make it part of the circuit? You could get a digital one for nearly the same cost, but will need an external power supply to run it...
    CocaCola, Jul 5, 2012
    #15
  16. vick5821
    vick5821 VIP Member
    Jan 22, 2012
    700
    MALAYSIA
    Can you provide me with link ? but I dont think measuring the current is a better way since the current will be very very small indeed
    #16
  17. vick5821
    CocaCola VIP Member
    Apr 7, 2012
    3,636
    Ebay search for "ammeter", selected lowest price first and you should get pages of them for about $4-$5 delivered... Pick one of the appropriate rating...
    #17
  18. vick5821
    vick5821 VIP Member
    Jan 22, 2012
    700
    MALAYSIA
    #18
  19. vick5821
    vick5821 VIP Member
    Jan 22, 2012
    700
    MALAYSIA
    Some of the digital one do not need extra power supply :)
    #19
  20. vick5821
    CocaCola VIP Member
    Apr 7, 2012
    3,636
    You might want to double check your findings, digital ones have displays that need to be driven, thus they need a power source...
    #20
    1. Advertisements
Similar Threads
  1. LRCR
    1,515
  2. LRCR
    466
  3. LRCR
    448
  4. LRCR
    602
  5. Fahmi88
    LDR, Transistor, and Electromagnet
    Fahmi88, Oct 10, 2015, in forum: Circuit Help
    12
    575
    Martaine2005
    Oct 14, 2015
Loading...
