latching and holding current
Discussion in 'Electronic Basics' started by twiki, Feb 7, 2004.
  1. twiki
    twiki Guest
    In SCR devices, which difference between these two currents?
    twiki, Feb 7, 2004
    #1
    1. Advertisements
  2. CFoley1064
    CFoley1064 Guest
    >From: twiki
    >Date: 2/7/2004 4:53 PM Central Standard Time
    >Message-id: <>
    Latching current is another name for gate trigger current -- it's a measure of
    the minimum current you have to apply to the gate of an SCR to be guaranteed it
    will turn on (given that there's a minimum voltage between anode and cathode).
    Holding current is the specified minimum current that must be flowing from
    anode to cathode (with no gate current) and still be guaranteed that the SCR
    will not turn off.
    As an example, the latching (gate trigger) current for a 2N5062 (logic level
    SCR in TO-92 pkg) is 350 uA over the entire temp range, and the holding current
    is10 mA over temp.
    Good luck
    Chris
    CFoley1064, Feb 8, 2004
    #2
    1. Advertisements
  3. Jamie
    Jamie Guest
    latching is the required minimum current on the gate that should
    be used to turn it on.
    the holding current is the minimum current it can be reduced down
    to before it opens the path between the cathod and anode.
    usually there is also a minimum voltage rating due to diode
    cut off voltages internally.
    for example many scr's won't latch if the voltage across the
    anode and cathod is below 1.0, there are the higher power types that
    even have a much higher voltage drop out too.
    Jamie, Feb 8, 2004
    #3
    1. Advertisements
Similar Threads
  1. Scott S
    power supply with long holding time
    Scott S, Jul 3, 2003, in forum: General Electronics
    735
    Jerry Greenberg
    Jul 8, 2003
  2. Skybuck The Destroyer
    Evidence: CPU FAN spins harder while holding the POWER BUTTON/SWITCH.
    Skybuck The Destroyer, Jun 2, 2007, in forum: Electronic Design
    11
    643
    Pieter
    Oct 21, 2007
  3. Pete
    3
    703
    Bill Bowden
    Aug 21, 2003
  4. killingtime
    3
    870
    (*steve*)
    Nov 22, 2011
  5. Joerg
    63
    1,166
    Joerg
    Jul 24, 2012
Loading...
Share This Page
