JVC I'Art TV : Model AV-32F702 : Opinions on fixing or replacing welcomed.
Discussion in 'Electronic Repair' started by Kazushi, Jul 31, 2006.
  1. Kazushi
    Kazushi Guest
    Hello:
    I'm an RF Engineering Technologist (specializing in antenna designs)
    and I'm not experienced in consumer electronics repair, specifically
    with respect to televisions.
    I have a JVC I'Art Standard Flat CRT TV Model AV-32F702 that was
    manufactured in September 2001 (Serial 14633437) and this is case:
    1. I turn on the TV and within the normal 1-to-2 seconds, the picture
    appears, but everything has a faint green haze. All settings for color
    and tint are normal.
    2. The faint green haze is persistent, and after 10 minutes of
    continuous operation, I begin to see 12/13/14 faint green lines,
    tracing diagonally across the screen, and these lines are more visible
    during dark scenes.
    3. After another 30-to-40 minutes of continuous operation, the green
    lines that were faint become brighter and are clearly visible during
    all scenes.
    4. Within moments of seeing brighter green trace lines, the picture
    changes from the green haze with bright green lines to a dark
    blue-purple fog with spectacular neon-bright wide green diagonal trace
    and horizontal retrace patterns flashing randomly in the blue-purple
    fog.
    5. At this point, the real picture appears for milliseconds at a time,
    audio is normal, and the blue-purple fog and neon green flashing
    continues unabated.
    6. Turning the set off, waiting for 30-60 seconds, and turning the set
    back on no longer resolves the problem (it used to, although
    temporarily, but, now 30-40 minutes of operation is the absolute
    limit).
    7. This issue has been progressive and has reached such a persistent
    level that I'm thinking that replacement may be better than repair.
    8. The case was tolerable for awhile because it was only a very subtle
    problem, but, over the past two weeks, the pace of the progression has
    accelerated and now the situation clearly requires a decision.
    I would welcome some thoughts from the subject matter experts in this
    group.
    One of my co-workers believes that the set is suffering from a
    grid-cathode short circuit that changes from an intermittent short to a
    harder short circuit once the TV has warmed up a little.
    Is there a serious problem with the green gun?
    Cheers,
    Stephen
    #1
    1. Advertisements
  2. Kazushi
    b Guest
    Kazushi wrote:
    > Hello:
    > during dark scenes.
    > all scenes.
    > fog.
    > continues unabated.
    > limit).
    > group.
    > Cheers,
    > Stephen
    FIRST check for bad soldering on crt neck board.
    then, change rgb fiter capacitor usually 10uF 250v or so.
    possibly the rgb o/p chip and see if its feeder resistors have changed
    in value.
    lastly suspect the tube!
    You may have to isolate the heater filaments as per the FAQ.
    -Ben.
    b, Aug 1, 2006
    #2
    1. Advertisements
  3. Kazushi
    Guest
    Kazushi wrote:
    > Hello:
    > during dark scenes.
    > all scenes.
    > fog.
    > continues unabated.
    > limit).
    > group.
    > Cheers,
    > Stephen
    You might be able to find the help you need at www.repairfaq.org if you
    chose to try and fix it.
    A proper diagnosis will require some careful measurements a the crt
    socket while the set is running in the fault condition. While the
    picture tube could be suspect, all other causes should be checked
    first.
    Otherwise, post your location and someone might be willing to keep it
    out of the landfill for you. If no takers here, call and see if a
    small local shop would be willing to haul it away at no charge for you.
    , Aug 1, 2006
    #3
    1. Advertisements
Similar Threads
  1. Doug Johnson
    Stop-Clock Circuit, Assistance Welcomed!
    Doug Johnson, Jun 1, 2004, in forum: Electronic Design
    8
    399
    Activ8
    Jun 2, 2004
  2. Bob Hide
    434
    Bob Hide
    Oct 17, 2003
  3. Ted Mahler
    JVC GRD72 ski cam hardware mod? Opinions?
    Ted Mahler, Feb 16, 2006, in forum: Electronic Repair
    5
    447
    Ted Mahler
    Feb 17, 2006
  4. Replies:
    1,859
  5. jmaarroyo
    15
    2,013
    jmaarroyo
    Jun 25, 2011
Loading...
