JVC horizontal lines
Discussion in 'Electronics Repair' started by wefixem, Feb 12, 2011.
  1. wefixem
    wefixem
    Feb 12, 2011
    6
    I have a JVC AV32D302 CRT television. Lately we have been experiencing horizontal lines at the top section of our screen coming down about 3 - 4 inches. The picture is fine but that section is sometimes distorted.
    I have been told it could be the vertical filter capacitors or the vertical chip but I can not identify them on the circuit board nor are they identified in the service manual or the parts manual.
    Any suggestions would be appreciated.
    #1
    1. Advertisements
  2. wefixem
    Resqueline
    Jul 31, 2009
    2,847
    When the vertical deflection is not quite able to recoil back up to the top of the screen fast enough (before the picture starts again) then there's usually a capacitor at fault.
    It's usually a big (2200uF) electrolytic capacitor around the vertical deflection IC/ drive. In Nokia's it could even be a small 0.1uF plastic capacitor being worn out instead.
    Please provide a link to an online manual/diagram if you are unable to locate the parts in question.
    Resqueline, Feb 13, 2011
    #2
    1. Advertisements
  3. wefixem
    wefixem
    Feb 12, 2011
    6
    Thanks for the info. Any other suggestions on how to get the files to you? They are too large for this forum.
    wefixem, Feb 13, 2011
    #3
  4. wefixem
    20,143
    1,353
    (*steve*), Feb 13, 2011
    #4
  5. wefixem
    wefixem
    Feb 12, 2011
    6
    I know you are trying to help and I appreciate it. The files I have are pdf and they don't seem to fit the format on imageshack. Any other suggestions?
    #5
  6. wefixem
    wefixem
    Feb 12, 2011
    6
    Here is the link where I got the files from but they are zipped. If you hafe any trouble let me know. The parts manual, schematics and owners manual are included in this zip file. You can download and view for free.http://www.eserviceinfo.com/download.php?fileid=11175
    #6
  7. wefixem
    Resqueline
    Jul 31, 2009
    2,847
    If you follow the wiring from the vertical deflection yoke (on page 7) you'll see that it leads to IC421 and C428 (2200uF 25V). Try replacing that capacitor first.
    If that doesn't cure it then try replacing C424 (100uF 35V) and C425 (470uF 35V).
    Resqueline, Feb 14, 2011
    #7
  8. wefixem
    wefixem
    Feb 12, 2011
    6
    Thank you. I will be trying this very soon and follow up with the results.
    wefixem, Feb 14, 2011
    #8
  9. wefixem
    20,143
    1,353
    That's was probably the best method :)
    For PDF files too large to upload that you can't find on the net, there is always http://pdfcast.org/
    (But I'm straying from the subject now.)
    (*steve*), Feb 14, 2011
    #9
  10. wefixem
    wefixem
    Feb 12, 2011
    6
    Thanks Steve. I will have to keep that in mind for the future.
    #10
    1. Advertisements
Similar Threads
  1. Samir
    Horizontal scan lines seen on TV
    Samir, Dec 28, 2003, in forum: General Electronics
    4
    1,542
    Samir
    Jan 5, 2004
  2. socialism001@yahoo.com
    Sony 27" TV - Horizontal Lines
    socialism001@yahoo.com, May 8, 2005, in forum: Electronic Basics
    610
  3. Travis
    Sony KV-35S42 TV -- Horizontal Lines
    Travis, Aug 20, 2003, in forum: Electronic Repair
    3
    612
    Travis
    Aug 21, 2003
  4. Samir
    Samir, Dec 28, 2003, in forum: Electronic Repair
    7
    885
    Samir
    Jan 5, 2004
  5. bryansullivan@gmail.com
    JVC TELEVISION REPAIR HELP-White lines on JVC 32" AV-32f702
    bryansullivan@gmail.com, Oct 29, 2007, in forum: Misc Electronics
    1,970
    randyfromm@gmail.com
    Nov 2, 2007
Loading...
