ITI SX-V Alarm system
Discussion in 'Electronics Repair' started by beersly101, Dec 16, 2010.
  1. beersly101
    beersly101
    Dec 16, 2010
    3
    Hi guys, I have an older system that the alarm company that installed it says that they can't program it any more. The system is a ITI SX-V. The system still works fine but it's showing 91 on the CPU witch means the CPU battery is bad. So my question is will the system loose all its memory if I try to put a new battery in? What type battery? Do I really need a programmer to change programming or can I do it from the touch keypad?
    #1
    1. Advertisements
  2. beersly101
    20,129
    1,347
    1) possibly
    2) look first
    3) possibly
    We have occasionally had alarm system experts here, so someone may have a better answer. But you're wise to ask, because bad things are certainly a possibility.
    Generally speaking, I would consider changing the CPU battery while the power is on to minimise the risk of loss of data. I would be fairly confident that it's stored in non-volatile memory and that all you will lose is the date and time, but that is by no means certain.
    (*steve*), Dec 16, 2010
    #2
    1. Advertisements
  3. beersly101
    beersly101
    Dec 16, 2010
    3
    Thanks for the advice!
    #3
  4. beersly101
    busine9635
    Dec 19, 2010
    4
    Hello my name is jeff Pauldo
    The Sx-V is no longer Manufactured. It is getting harder and harder to get parts for something that is no longer manufactured. Most alarm Companies will try and upgrade your system to a more up to date system which is quiet costly. The SX-V will loose its memory if you change the battery when the power to the panel is completely gone. If that infacts happened you will then need a programer to program all your door sensors and motions back into the system. I would write down the make of the battery and go to radio shack or a battery company over the internet. Once you have the battery, change the battery with the power on. You should be good.
    Jeff
    JP Electronics & Surveillance
    busine9635, Dec 19, 2010
    #4
  5. beersly101
    beersly101
    Dec 16, 2010
    3
    Thanks Jeff, that's exactly what I will do. I was told that the system was programmed at a central station where they monitored it and I wouldn't even be able to program it if I had a hand held programmer. Is this true?
    Thanks Again
    Happy Holidays!
    beersly101, Dec 23, 2010
    #5
    1. Advertisements
Similar Threads
  1. Michael
    ITI SX-V Keypad needed
    Michael, Dec 19, 2003, in forum: Security Alarms
    616
    G. Morgan
    Dec 21, 2003
  2. Rich
    ITI/ADT Safewatch RF, SX-V
    Rich, Mar 3, 2004, in forum: Security Alarms
    688
  3. Bill
    15
    999
    Spehro Pefhany
    Aug 4, 2009
  4. gsun
    wireless Alarm issue - SX-V
    gsun, Aug 27, 2010, in forum: Electronics Repair
    6
    2,211
    Alex P.
    Jan 11, 2015
  5. max_torch
    V(rms) = V(ac) and V(ave) = V(dc), why?
    max_torch, Jul 27, 2014, in forum: General Electronics Chat
    9
    908
    Laplace
    Jul 28, 2014
Loading...
