isopropyl alcohol leaves residue...
Discussion in 'Electronics Repair' started by auato, Nov 3, 2011.
  1. auato
    auato
    Feb 12, 2011
    5
    Hi all.
    I bought from RS Components some specific 99.7% isopropyl alcohol to clean some PCBs
    (link) ... but after the cleaning, remains a lot of residual traces (see pic)
    I use a generic brush with bristles cutted :confused:
    auato, Nov 3, 2011
    #1
    1. Advertisements
  2. OLIVE2222
    OLIVE2222 VIP Member
    Oct 2, 2011
    690
    A pcb mounting sub-contractor we are working with is using acetone after the soldering process.
    OLIVE2222, Nov 3, 2011
    #2
    1. Advertisements
  3. shrtrnd
    shrtrnd VIP Member
    Jan 15, 2010
    2,605
    Are you sure that's not dirt/dust from elsewhere on your board?
    That shouldn't have come out of an isopropyl container.
    You didn't melt some kind of conformal coating on the board with the alcohol, did you?
    I don't know, just doesn't make sense from simple isopropyl.
    shrtrnd, Nov 3, 2011
    #3
  4. daddles
    daddles VIP Member
    Jun 10, 2011
    443
    Find out if it's in the IPA: clean a mirror carefully, then put a few drops of the IPA on the mirror and let the thing dry. You shouldn't see any residue. If you do, you might want to get it analyzed at a local chem lab to find out what the impurities are.
    daddles, Nov 3, 2011
    #4
  5. auato
    auato
    Feb 12, 2011
    5
    It is very strange :confused: Maybe there is a coating that melts or there is dirty that I spread accidentally on the board as you say. But if I use the flux, the cleaning is good on the PCB and there are no residues. I am not aware about that mystery. The isopropyl container doesn't seem dirty.
    auato, Nov 3, 2011
    #5
  6. davelectronic
    davelectronic VIP Member
    Dec 13, 2010
    1,079
    The isopropyl alcohol might have dissolved some PCB chemical residue on the PCB, i soldered some new PP3 9 volt battery connections on some gear today, first time i opened it and there are patches of chemical residue on the board, your board looks like dust dirt etc ans the alcohol has spread it around, unless the batch you have is contaminated, best try the mirror test Jackorocko said try, one pass over a clean mirror with a clean applicator, brush or something, as the alcohol evaporates the residue will show, if not, tut tut your board was dirty and you dissolved the dirt, drown it and use a new brush, gently, not sure about acetone, ive worked in the GRP / CF trade molding and acetone is aggressive stuff, not sure on PCB, it might be ok, i don't do PCB production, oh don't drink any of the chemicals. LOL.
    Dave. :)
    davelectronic, Nov 3, 2011
    #6
  7. auato
    auato
    Feb 12, 2011
    5
    I tried to follow the trick of @daddles and @davelectronic by a little mirror. I believe my brush is dirty because if I leave evaporate the isopropyl, then I do not find any trace but if I spread the isopropyl with my brush, after drying, I can see a large opaque stain over the mirror
    Thanks for tip :)
    auato, Nov 4, 2011
    #7
  8. davelectronic
    Dec 13, 2010
    1,079
    isoprphyil alcohol
    OH, you wandered where that varnish / fence stain brush got to, OOP'S.
    Dave. :)
    PS. drown it in alcohol see if that removes it, or pressure washer, or washing machine, not a boil wash, keep look out for the misses, sorry only joking, no, drown it in alcohol, or white spirit then isoprophyil.
    Should be ok, or acetone as mentioned, oh and no more staining / varnishing / or french polishing your pcb's. :D
    davelectronic, Nov 5, 2011
    #8
  9. shrtrnd
    shrtrnd VIP Member
    Jan 15, 2010
    2,605
    Sounds to me like the problem has been found.
    Might be about time to buy a replacement brush.
    shrtrnd, Nov 5, 2011
    #9
  10. auato
    auato
    Feb 12, 2011
    5
    Hello mates.
    I confirm that my brushes were dirty :eek:
    Thanks all
    auato, Dec 4, 2011
    #10
  11. davelectronic
    Dec 13, 2010
    1,079
    Well its a mistake your not likely to repeat, keep a set of small brushes specifically for electronics cleaning, there not that expensive, ive even got a soft tooth brush in my box, no not for my teeth, but useful for intricate areas. :)
    davelectronic, Dec 4, 2011
    #11
    1. Advertisements
Similar Threads
  1. Rob
    8
    2,184
    Walter Harley
    Sep 27, 2003
  2. Z
    Have I got the correct Isopropyl Alcohol
    Z, May 16, 2004, in forum: Electronic Repair
    13
    886
    LASERandDVDfan
    May 18, 2004
  3. tempus fugit
    contact cleaner or isopropyl alcohol for tube contacts?
    tempus fugit, Oct 14, 2007, in forum: Electronic Basics
    3
    1,198
  4. Arfa Daily
    Re: Isopropyl Alcohol for Cleaning Flux
    Arfa Daily, Jul 26, 2010, in forum: Electronic Basics
    26
    2,115
    GregS
    Aug 2, 2010
  5. Arfa Daily
    Arfa Daily, Jul 26, 2010, in forum: Electronic Repair
    26
    2,182
    GregS
    Aug 2, 2010
Loading...
Share This Page
