Isolated, regulated, toroidal step down transformer AC power supply design.
Discussion in 'Hobby Electronics' started by Mark, Mar 26, 2007.
  1. Mark
    Mark Guest
    Can anybody point me to a good design of same.
    240 VAC in, 9 VAC out.
    Mark, Mar 26, 2007
    #1
    1. Advertisements
  2. Mark
    Phil Allison Guest
    "Mark"
    ** Huh ?
    What gobbledegook is this ?
    ....... Phil
    Phil Allison, Mar 26, 2007
    #2
    1. Advertisements
  3. Mark
    Mike Guest
    In article <4607c3d8$0$68247$>, says...
    The closest thing in terms of a transformer that will be able to
    provide 'some' regulation is a ferroresonant one. They were often
    used 20 or more years ago but declined more quickly when the UPS
    became cheaper.
    The yare good at supply regulation but bad for noise and bad for
    waveform distortion.
    You dont really want to design a ferroresonant in a toroid unless
    you want to spend a few weeks getting to grips with the material
    properties and all the magnetics calculations and building many
    prototypes.
    Far better you just get a good SMPS.
    But do you really need 9vac for your application or is that to feed
    something else that could utilse DC more efficiently ?
    or did phil write this so i can practice typing and get even more proficient ;)
    Regards
    Mike
    * VK/VL Commodore FuseRails that wont warp or melt with fuse failure indication
    and now with auto 10-15 min timer for engine illumination option.
    * VN, VP, VR Models with relay holder in progress.
    * Twin Tyres to suit most sedans, trikes and motorcycle sidecars
    http://niche.iinet.net.au
    Mike, Mar 26, 2007
    #3
  4. "Mark" <> wrote in message
    news:4607c3d8$0$68247$...
    **Why don't you tell us what you are trying to actually do, rather than
    telling us what you think you need?
    As you may have guessed, your request is difficult to satisfy.
    At a minimum, you need to tell us:
    * AC or DC
    * Maximum and minimum current requirements.
    Trevor Wilson
    www.rageaudio.com.au
    Posted via a free Usenet account from http://www.teranews.com
    Trevor Wilson, Mar 26, 2007
    #4
  5. Mark
    Mr.T Guest
    "Rudolf" <> wrote in message
    news:...
    > Uni assignment?
    Sounds more like primary school :)
    MrT.
    Mr.T, Mar 27, 2007
    #5
  6. Mark
    jasen Guest
    > news:...
    >> Uni assignment?
    He wants a transformer that regulates.
    Bye.
    Jasen
    jasen, Mar 27, 2007
    #6
  7. Mark
    Mark Guest
    I am trying to build a 240 VAC in (or even 110 VAC in, I really don't care)
    9 VAC out, regulated (to 9 VAC) , isolated (from transformer), step down
    transformer and AC power supply.
    Input fused (at about 2 amps) but I could adapt just about any design to
    about that current.
    There...but I think I already said it, didn't I ..Let's see?
    "Trevor Wilson" <> wrote in message
    news:46082321$0$16301$...
    .... yes, thats me.
    .......ah, I did.
    > * AC or DC
    > Trevor Wilson
    Mark, Mar 27, 2007
    #7
  8. Mark
    Phil Allison Guest
    PISS OFF TROLL !!!!!!!!!!!!!
    "Mark"
    ** BEWARE: Top posting fuckwit on loose !!
    > care) 9 VAC out, regulated (to 9 VAC) , isolated (from transformer), step
    > down transformer and AC power supply.
    ** Seeing as you are a COLOSSAL FUCKING MORON with ZERO
    ability to provide a intelligent specification
    - just what the **** s the application - eh ???
    > about that current.
    ** Err - is that 2 amps AC at 240 volts or 120 volts - FUCKWIT ??
    ** This UTTER ASS is either on an overdose of mild altering drugs
    - or damn well needs to be.
    ........ Phil
    Phil Allison, Mar 27, 2007
    #8
  9. Mark
    James Guest
    news:46090d62$0$24861$...
    > about that current.
    > ... yes, thats me.
    > ......ah, I did.
    >> * AC or DC
    >> Trevor Wilson
    What is the application?
    Do you need a regulated 9V RMS Sinewave output? What for?????
    James
    James, Mar 27, 2007
    #9
  10. Mark
    Phil Allison Guest
    "James"
    ** Forget it - " Mark " is an UTTER MORON with idea whatever of the
    meaning of the words he is using.
    Must be another ADHD fucked " ladder monkey " or some total FUCKWIT
    electrician.
    ........ Phil
    #10
  11. Mark
    Mark Guest
    Yes, I really do need 9 VAC for my application.
    Within the application, the 9 VAC is rectified, filtered, regulated (to +15
    VDC and -15 VDC) and then filtered again.
    So the input needs to be regulated to within about (+ or -) 1% 9 VAC.
    "Mike" <> wrote in message
    news:46081420$0$7449$...
    > says...
    > became cheaper.
    > prototypes.
    > proficient ;)
    > Regards
    > Mike
    > indication
    Mark, Mar 27, 2007
    #11
  12. Mark
    Mark Guest
    Yes.
    Say please.
    "James" <> wrote in message
    news:4609129b$...
    >> about that current.
    >> ... yes, thats me.
    >> ......ah, I did.
    >>> * AC or DC
    >>> Trevor Wilson
    > James
    Mark, Mar 27, 2007
    #12
  13. Mark
    Phil Allison Guest
    "Mark Isley = Utter FUCKWIT "
    ** BOLLOCKS you do !!
    > +15 VDC and -15 VDC) and then filtered again.
    ** This TOP POSTING, PITA DAMN FOOL
    has just gotta be a ADD fucked cable installer.
    What a bloody HOOT !!!!!!!
    Lets all keep this CRETIN on the fishing line as long as possible !!
    What entertainment !!
    ........... Phil
    #13
  14. Mark
    Phil Allison Guest
    "Mark Ilsley UTTER FUCKWIT "
    has just gotta be another ADD fucked cable installer !!!!
    Just like " Spanky" from Melbourne.
    What top entertainment !!
    ........... Phil
    #14
  15. Mark
    Mark Guest
    No, I think I want to regulate the output of the transformer.
    The output of any transformer is only proportional to the voltage of it's
    input. AFAIK, anyway.
    So if the volts in aren't nominal, nor is the voltage out.
    "jasen" <> wrote in message
    news:euapio$dak$-a-geek.org...
    >> news:...
    >>> Uni assignment?
    > Bye.
    > Jasen
    Mark, Mar 27, 2007
    #15
  16. Mark
    Phil Allison Guest
    "Mark Ilsley = UTTER FUCKWIT "
    ** ROTFLMAO - this is absolutely CLASSIC !!!
    ........... Phil
    #16
  17. Mark
    Mark Guest
    Re: PISS OFF TROLL !!!!!!!!!!!!!
    Doesn't matter a rats arse to my purpose.
    "Phil Allison" <> wrote in message
    news:...
    > "Mark"
    >> about that current.
    > ....... Phil
    Mark, Mar 27, 2007
    #17
  18. Mark
    Phil Allison Guest
    ** ROTFLMAO - this is absolutely bloody CLASSIC !!!
    Just like that " Spanky" moron from Melbourne.
    What a bloody HOOOT !!!!!!!
    ........... Phil
    #18
  19. Mark
    James Guest
    news:46091546$0$24867$...
    *** Thanks...thats the best laugh I've had for ages :)
    I'm sure a single 9Vac supply will give you amazingly clean +/-15V rails,
    you'd best make sure you get a 500W toroidal though, that'll help..
    PMSL
    James
    >> says...
    >> became cheaper.
    >> prototypes.
    >> proficient ;)
    >> Regards
    >> Mike
    >> indication
    James, Mar 27, 2007
    #19
  20. Mark
    Mark Guest
    Bullshit
    news:...
    > PMSL
    > James
    >>> says...
    >>> became cheaper.
    >>> prototypes.
    >>> proficient ;)
    >>> Regards
    >>> Mike
    >>> indication
    Mark, Mar 27, 2007
    #20
    1. Advertisements
Similar Threads
  1. kreed
    449
    kreed
    Apr 8, 2007
  2. using step-down transformer as step-up
    , Feb 11, 2009, in forum: Electronic Design
    21
    1,751
    Baron
    Feb 14, 2009
  3. MJHanagan
    Can a step-down transformer be used as a step-up transformer?
    MJHanagan, Apr 19, 2012, in forum: General Electronics Chat
    24
    2,826
  4. Laywah
    Step down 240v AC to 24v AC
    Laywah, Apr 7, 2015, in forum: Circuit Help
    7
    910
    Laywah
    Apr 8, 2015
  5. Stuart Hossack
    DC Power Supply - Choke for regulated power supply
    Stuart Hossack, Apr 2, 2016, in forum: Circuit Help
    9
    225
    Stuart Hossack
    Apr 4, 2016
Loading...
