is it possible to interface SPI to serial?
Discussion in 'Electronic Design' started by Michael Noone, Feb 1, 2005.
  1. Hi - I'm looking to connect an RF chip with an SPI interface
    (http://www.nordicsemi.no/index.cfm?obj=product&act=display&pro=83) to a
    computer through the serial port. Right now I'm just planning on putting a
    microcontroller that has both a uart and an spi interface between the
    computer and the chip - but are there any more elegant solutions? Thanks,
    Michael
    #1
    1. Advertisements
  2. Michael Noone
    Tim Wescott Guest
    > Michael
    Nope, that's probably the best. Look around, there should be some very
    small solutions. Don't overlook parts that have UARTs but no SPI -- SPI
    is easy to bit-bang. If you hold the baud rate down and you don't mind
    consuming lots of processor resources you can even bit-bang asynchronous
    serial; I believe that Microchip has app notes.
    Tim Wescott
    Wescott Design Services
    http://www.wescottdesign.com
    Tim Wescott, Feb 1, 2005
    #2
    1. Advertisements
  3. Michael Noone
    Wim Ton Guest
    "Michael Noone" <mnoone.uiuc.edu@127.0.0.1> wrote in message
    news:Xns95F09555824A3mnooneuiucedu127001@216.148.227.77...
    > Michael
    It is also possible to bit-bang the status lines of the serial port. You
    need level shifters/drives of course. It moves the programming effort from
    the uC to to PC's OS
    Wim
    Wim Ton, Feb 2, 2005
    #3
  4. Michael Noone
    Ron Guest
    Michael,
    Maxim makes a few chips specifically for spi-uart interfacing.
    max3100, max 3110, max3111
    the latter 2 come in pdip packages if you are doing this homebrew.
    super simple chips and have worked well for me.
    http://www.maxim-ic.com/quick_view2.cfm/qv_pk/1731/ln/
    Good luck
    Ron
    Ron, Feb 2, 2005
    #4
  5. Michael Noone
    Anders F Guest
    "Tim Wescott" <> wrote in message
    news:...
    a
    > > Michael
    I think they all have. And I know Texas has for the MSP430.
    /Anders
    > Tim Wescott
    Anders F, Feb 2, 2005
    #5
  6. "Wim Ton" <> wrote in message
    news:3t0Md.44952$...
    >> a
    >> putting a
    >> Thanks,
    >> Michael
    Look at the Maxim 3100 family. These are SPI interface UARTs, complete
    with the line drivers built in.
    Best Wishes
    Roger Hamlett, Feb 2, 2005
    #6
  7. "Ron" <> wrote in news:1107336802.610066.246010
    @z14g2000cwz.googlegroups.com:
    > Michael,
    > Good luck
    > Ron
    Ah - the max3110/3111 (http://www.maxim-
    ic.com/quick_view2.cfm/qv_pk/2052) look perfect for my needs. Thanks for
    the help!
    -Michael
    Michael Noone, Feb 3, 2005
    #7
  8. Michael Noone <mnoone.uiuc.edu@127.0.0.1> wrote in message news:<Xns95F282D8D58B0mnooneuiucedu127001@204.127.199.17>...
    > > Michael,
    > > Good luck
    > > Ron
    > the help!
    > -Michael
    I haven't looked too closely at the datasheets but I doubt, my guess
    is that both the RF and the MAX31xx is a SPI slave i.e. it won't work
    use a micro instead
    -Lasse
    Lasse Langwadt Christensen, Feb 4, 2005
    #8
    1. Advertisements
Similar Threads
  1. hpk@groups
    Serial communication between 2 PIC16F877 via I2C or SPI
    hpk@groups, Feb 9, 2004, in forum: General Electronics
    3,145
    ChronoFish
    Feb 9, 2004
  2. Joe Plane
    753
    Rich Grise
    Oct 20, 2003
  3. Joe Plane
    606
    Rich Grise
    Oct 20, 2003
  4. Adrian Hjelmslund
    Serial number rom ic, with spi or i2c interface?
    Adrian Hjelmslund, Jan 25, 2006, in forum: Electronic Design
    12
    2,912
    Adrian Hjelmslund
    Jan 26, 2006
  5. Joe Plane
    892
    Rich Grise
    Oct 20, 2003
Loading...
