Interfacing 5V -> 3.3V with just a serial resistor
Discussion in 'Electronic Design' started by JJ, Sep 21, 2006.
  1. JJ
    JJ Guest
    I would like to interface an IC with CMOS 5V output to an CMOS 3.3V
    input which can have max 3.3V+0.5V. The simplest method I can think of
    is using a serial resistor with value 5V-3.3V/Imax. But I don't see
    this method used a lot, specialy not with CMOS I/O. Can somebody please
    tell me why?
    Cheers,
    JJ
    JJ, Sep 21, 2006
    #1
    1. Advertisements
  2. Dave Boland
    Dave Boland Guest
    > tell me why?
    > Cheers,
    > JJ
    JJ,
    This idea is full of problems (in most cases). A better way
    is to interface the signals with 5 volt tolerant 3.3 volt
    logic device such as the LVX family. See link below.
    http://www.fairchildsemi.com/products/logic/lowvolt/#lcx
    Dave,
    Dave Boland, Sep 21, 2006
    #2
    1. Advertisements
  3. Paul Burke
    Paul Burke Guest
    > tell me why?
    This can lead to all sorts of problems, the biggest being that the 3.3V
    device can be powered from the 5V supply, via the clamp diodes. Since
    most regulators can't sink current, the "3.3V" zooms up to about 4V,
    with deleterious effects.
    Use a resistive divider (slow and current- hungry), resistor/zener
    (slow, expensive and current hungry), or a level- shifting IC like 74LVC
    series (fast and expensive).
    Paul Burke
    Paul Burke, Sep 21, 2006
    #3
  4. Eeyore
    Eeyore Guest
    > tell me why?
    You need parts with '5V tolerant' inputs e.g.
    http://focus.ti.com/docs/prod/folders/print/sn54lvc541a.html
    Graham
    Eeyore, Sep 21, 2006
    #4
  5. Eeyore
    Eeyore Guest
    > > tell me why?
    Are they actually that expensive ?
    I just checked 74LVC00 and 74HC00 on ti.com and there's only a couple of cents
    in it.
    Graham
    #5
  6. Guest
    > tell me why?
    > Cheers,
    > JJ
    The method works fine, but there are a few things to watch out for.
    With most devices, any attempts to drive more than Vdd +0.6 V will turn
    on a protection diode between the input pin and Vdd. This is fine, so
    long as the current is low (no more than a few mA) AND the power supply
    voltage of the low-voltage device will not be made to rise unacceptably
    by this extra current.
    If too high a current (usually >100mA) is driven into the protection
    diode, the chip may latch up and self destruct.
    All these problems are solved by using two resistors as a resistive
    divider.
    The final thing to look out for is the effect on the speed of the
    circuit. It will be slowed down in proportion to the series resistance
    and the stray capacitance plus the device input capacitance.
    John
    , Sep 21, 2006
    #6
  7. Eeyore
    Eeyore Guest
    > > tell me why?
    > divider.
    All very true which is why an LVC part makes more sense.
    Graham
    #7
  8. Guest
    You're interfacing a 5V microcontroller to a SD/MMC card?
    Use a voltage divider. It makes your three resistors into six
    resistors, but that's not too arduous.
    , Sep 21, 2006
    #8
  9. colin
    colin Guest
    "JJ" <> wrote in message
    news:...
    > tell me why?
    using Imax will cuase a lot of problems,
    use a lot lower current, definatly less than the minimum curent drawn by the
    3.3 rail,
    otherwise it will push the 3.3 rail up
    if its not fast enough use a small parallel capacitor,
    so that it forms a capacitave divider with the input/stray capacitance.
    Colin =^.^=
    colin, Sep 21, 2006
    #9
  10. JJ
    JJ Guest
    Thanks for the fast replies!
    I want actually to interface a 5V quadrature encoder with a XOR gate. I
    was planing to get a 5V tolerant gate, but our supplieres Farnell
    (http://at.farnell.com) and RS (http://www.rs-components.at) in Austria
    don't have those parts!! Really sad...;-(((
    > > tell me why?
    > > Cheers,
    > > JJ
    > divider.
    > John
    JJ, Sep 21, 2006
    #10
  11. Al Clark
    Al Clark Guest
    wrote in news:1158838538.163960.68360
    @b28g2000cwb.googlegroups.com:
    Since it is an encoder, and therefore probably slow, you can probably use
    the resistors.
    One trick is to use a 4 element resistor network instead of 3 resistors. If
    you parallel two of them for the series R, you will get a 2/3 divider (you
    have a spare R). This is often cheaper and perhaps smaller than using two
    discrete resistors since the labor cost more than the parts
    Al Clark
    Danville Signal Processing, Inc.
    Purveyors of Fine DSP Hardware and other Cool Stuff
    Available at http://www.danvillesignal.com
    Al Clark, Sep 21, 2006
    #11
  12. Noway2
    Noway2 Guest
    > > > tell me why?
    > in it.
    > Graham
    In my application, I used the 74LVC4245A. They are bidirectional 3.3V
    <--> 5.0V level transcievers. I think they cost about 0.90 in qty 1
    from digikey, and downwards of a 0.25 in typical production quantities.
    Noway2, Sep 21, 2006
    #12
  13. krw
    krw Guest
    In article <>,
    says...
    I've used IDT Quick Switches tin high speed applications. They're
    *FAST* (advertised as "zero delay").
    Application note for the level translators:
    http://www.idt.com/products/files/7530/AN_11.pdf
    > tell me why?
    It'll be slow, but it should work with CMOS.
    Keith
    krw, Sep 22, 2006
    #13
  14. Jim Thompson
    Jim Thompson Guest
    On Thu, 21 Sep 2006 22:22:57 -0400, krw <> wrote:
    >In article <>,
    > says...
    >> tell me why?
    The NPN/2-resistor scheme can be rearranged to do +5V to +3.3V
    translation.
    ...Jim Thompson
    | James E.Thompson, P.E. | mens |
    | Analog Innovations, Inc. | et |
    | Analog/Mixed-Signal ASIC's and Discrete Systems | manus |
    | Phoenix, Arizona Voice:(480)460-2350 | |
    | E-mail Address at Website Fax:(480)460-2142 | Brass Rat |
    | http://www.analog-innovations.com | 1962 |
    I love to cook with wine. Sometimes I even put it in the food.
    Jim Thompson, Sep 22, 2006
    #14
  15. Keith
    Keith Guest
    In article <>, To-Email-
    says...
    > >In article <>,
    > > says...
    > >> tell me why?
    > translation.
    The neat thing about the QuickSwitches is that they'll go both ways
    and *fast* (though from 3.3V->5V you may need a pullup, somewhat
    slowing things that direction).
    Keith
    Keith, Sep 22, 2006
    #15
    1. Advertisements
Similar Threads
  1. heirbrande
    1,047
    heirbrande
    Aug 22, 2003
  2. Robert Hedan
    re:Problems interfacing PIC UART to PC Serial Port
    Robert Hedan, Feb 19, 2005, in forum: General Electronics
    1,316
    Robert Hedan
    Feb 19, 2005
  3. Joe Plane
    746
    Rich Grise
    Oct 20, 2003
  4. Shashank
    Serial port interfacing
    Shashank, Dec 28, 2004, in forum: Electronic Components
    9
    468
    Tim Wescott
    Dec 29, 2004
  5. NK
    Serial Rs232 interfacing
    NK, Nov 22, 2004, in forum: Hobby Electronics
    3
    447
Loading...
