Increasing Cable TV signal strength
Discussion in 'Electronic Repair' started by amdx, Feb 8, 2012.
  1. amdx
    amdx Guest
    Hi All,
    I'm on a boat, about 170ft from the utility post.
    Recently our cable company switched to the wonderful world of
    Digital TV. I got the new digital converter and had no picture.
    I took the box back and got a second box, still no picture. So now I
    suspect a weak signal and confirm that it is the cable length. The cable
    company came out and gave me a better cable than I had installed. At
    this point I have a picture but it is intermittent. The signal at the
    utility post has 3 outputs and had a four way splitter, I suggested the
    cable guy put in two 2 way splitters and give me the stronger (first) tap.
    That got my signal to work almost all the time. I'd like to get the
    signal to work 100% of the time.
    I don't has access to electricity at the utility post, so an amp is
    out. Although I could try an amp at the cable box end. Is that reasonable?
    I would run two cables if there was a way to make it increase signal
    strength.
    Getting anymore from the cable company is not an option.
    Any ideas to get a better signal?
    Mikek
    PS.
    When the signal fails it seems channel 41 is ok and above 42 it breaks up.
    Curious to know if there is an unusual frequency jump between those two
    digital channels.
    amdx, Feb 8, 2012
    #1
    1. Advertisements
  2. Ian Jackson
    Ian Jackson Guest
    In message <b7625$4f32c758$4b4c116f$>, amdx
    <> writes
    >Hi All,
    >cable company came out and gave me a better cable than I had installed.
    >At this point I have a picture but it is intermittent. The signal at
    >the utility post has 3 outputs and had a four way splitter, I suggested
    >the cable guy put in two 2 way splitters and give me the stronger
    >(first) tap.
    >reasonable?
    >strength.
    > Mikek
    >PS.
    >digital channels.
    Despite your long 170ft drop cable, were you getting good analogue
    signals before the change to digital? If so, it could be that something
    is not right. Normally, even if you have had only fairly mediocre
    analogues, the digitals are good.
    Otherwise....
    It sounds like your signals are just too weak. As things are, and if you
    can, the obvious fix would be to overcome the substantial loss of the
    170ft drop cable by fitting an amplifier at or near the utility post
    (not at your end), and power it with low voltage via the coax from your
    end (ie similar to a line-powered masthead antenna amplifier). However,
    you would need to consult with the cable company to see if they were OK
    with letting you do this. It could be that they might be able advise you
    on the most suitable amplifier to use. It's not rocket science, but you
    have to be a little careful not to break any of their rules and
    generally do anything they don't approve of.
    Ian
    Ian Jackson, Feb 8, 2012
    #2
    1. Advertisements
  3. mike
    mike Guest
    On 2/8/2012 11:00 AM, amdx wrote:
    > Hi All,
    > I don't has access to electricity at the utility post, so an amp is out.
    > strength.
    > Mikek
    > PS.
    > digital channels.
    Are you sure it's a signal strength problem?
    The cable guy should have been able to measure the signal at your cable box.
    Are the people using the other taps having problems?
    If you're on a boat, you might be at the end of the cable run.
    In that case, you might be able to get them to crank up the gain in their
    distribution amp.
    Power at the pole is not a problem. You can get amps that are powered
    through the signal cable to your cable box. Getting them to let you
    install it
    is another matter.
    You can get MUCH better wire, for a price.
    Signal strength is not the only problem with digital TV.
    Reflections in the system can confuse the decoder. Are there
    any unterminated cables on the other taps?
    I have OTA antenna digital TV. Plenty of signal, but reflections
    cause significant drop outs on some channels. More signal won't fix
    that. In fact, I have a variable attenuator to REDUCE signal strength.
    I tweak the signal level for fewest dropouts.
    Might be electrical noise coupled in thru the ground system.
    Bottom line is that you pay the cable company for TV reception.
    It's their responsibility to provide you with a watchable signal.
    You shouldn't have to tell them what to do. They should just FIX it!!
    mike, Feb 8, 2012
    #3
  4. amdx
    amdx Guest
    > <> writes
    >> Hi All,
    >> installed. At this point I have a picture but it is intermittent. The
    >> signal at the utility post has 3 outputs and had a four way splitter,
    >> I suggested the cable guy put in two 2 way splitters and give me the
    >> reasonable?
    >> strength.
    >> Mikek
    >> PS.
    >> up.
    >> two digital channels.
    But, analog can be snowy but very watchable, digital an be pixalated
    and stuttering without no sound or often no picture at all.
    > Otherwise....
    I had not thought about a coax powered amp, Thanks.
    Mikek
    amdx, Feb 8, 2012
    #4
  5. amdx
    amdx Guest
    On 2/8/2012 2:36 PM, Fred Bloggs wrote:
    > On Feb 8, 2:00 pm, amdx<> wrote:
    >> Hi All,
    > That's about 10dB loss at midband for RG6.
    > That was just a 3dB boost.
    But that 3bd did get me a more consistent picture.
    amdx, Feb 8, 2012
    #5
  6. Ian Jackson
    Ian Jackson Guest
    In message <9a54a$4f32e7bc$4b4c116f$>, amdx
    <> writes
    >> <> writes
    >>> Hi All,
    >>> reasonable?
    >>> strength.
    >>> Mikek
    >>> PS.
    >>> up.
    You are quite correct. However, digital is generally capable of working
    to lower signal levels than analogue. It's amazing how rubbishy digital
    signals can be, yet still give perfect pictures - but don't expect
    miracles!
    >> Otherwise....
    > Mikek
    I see that several others have also suggested a coax-powered amplifier.
    [If the cable company can't give you more signal level, it's the only
    solution.] As suggested, they should be able to provide a suitable
    amplifier and power unit - or at least advise you what to use.
    Ian
    #6
  7. amdx
    amdx Guest
    On 2/8/2012 2:47 PM, Dave Platt wrote:
    > In article<b7625$4f32c758$4b4c116f$>,
    >> strength.
    > Adding an amp at the cable box isn't all that likely to work... you
    > can try it, but don't get your hopes up. Unless the amp has a
    > significantly lower "noise figure" than the RF front end in the cable
    > box, all you'll be doing is adding noise... the desired signal will be
    > stronger, but the noise will be stronger yet.
    > Something you could do, is add a single-port RF amplifier right at the
    > utility post splitter, where your tap comes off of the feed. You can
    > buy amplifiers of this sort which are designed to receive "phantom
    > power" through the coax cable... you'd install a "power injector" at
    > your boat, which feeds a DC voltage up the coax to the amplifier.
    > This is probably your best bet:
    > - It would amplify the signal before it's attenuated by the 170-foot
    > cable run.
    > - It won't require a power supply at the post... just at your
    > boat, where you already have power.
    > - It shouldn't interfere with the other taps on the
    > splitter, even when the amplifier is not receiving power from your boat.
    > You'd be looking for an "antenna mast" type of preamplifier. The
    > Channel Master 0068DSB or 7777, Winegard AP-8700 or AP-8275 or
    > HDP-269, AntennaCraft 10G212, or one of the Blonder Tongue Galaxy III
    > models might do the job for you. You'll probably want a "75 ohm in,
    > 75 ohm out" model, which would connect directly to the 75-ohm coax.
    Hey thanks for the part numbers, I'll look into these.
    Mikek
    amdx, Feb 8, 2012
    #7
  8. amdx
    amdx Guest
    On 2/8/2012 3:03 PM, Robert Macy wrote:
    > On Feb 8, 12:00 pm, amdx<> wrote:
    >> Hi All,
    >> strength.
    >> Mikek
    >> PS.
    >> digital channels.
    > see URL:
    > <http://www.dbsinstall.com/broadcast/vhf_uhf_freq_list.asp>
    That's helpful. however, I do receive channels up to 484!
    Dang, just noticed "Lesbo Euro Trash: Big Boobs" is on 502, but, it's
    pay per view. :)
    > 41 is 324 - 330MHz and 42 is 330-336 MHz
    > cables attenuate more at higher frequency.
    I thought there might be a bigger jump between 41 and 42
    because when 42 was pixelating 41 was always perfect.
    > By ALL means, if you're going to add an amplifier, add it at the
    > source location, not at the receiver location
    > Cheap, but good, ones are available from microcircuits. Can you buy a
    > line driver from your CATV company?
    > I suspect the 'better' cable is only marginally better. What is the
    > EXACT cable you're using? what is its attenuation per foot per MHz?
    > You can buy extremely low loss coax, but you may have to send in your
    > first born. Go to a local NRTL [EMC Test Lab] and see if they can
    > (are willing to) order a length for you.
    I think I'll try the amp, before spending for better cable.
    I think I just found a work around, The station I wanted, 42
    is repeated on 428 in HD and it doesn't pixelate when 42 does.
    The pixelating problem is rare, only a spall percentage of the time,
    but very annoying. Ah, the wonderful world if Digital TV.
    Mikek
    amdx, Feb 8, 2012
    #8
  9. amdx
    amdx Guest
    >> Hi All,
    >> tap.
    >> strength.
    >> Mikek
    >> PS.
    >> up.
    >> digital channels.
    Yes, it is the loss in the cable.
    > box.
    No other problems, I'm just way down the dock from them.
    > distribution amp.
    Next time they are around I'll ask.
    > install it
    > is another matter.
    Yes that is possible, There are transients in and out so sometimes the
    taps are used and sometimes not. I suppose I could make a bunch of 75
    ohm terminations, and put on a new one every time it's needed.
    However I never noticed a correlation between boats in and boats out.
    Ya, but no. It's in a marina and the marina has a deal with the cable
    company.
    At this point there is talk about putting up an antenna.
    The marina has ten cable boxes for transients that need to be plugged in
    and connected (I guess keep them updated). So it has become a hassle for
    the marina handle the boxes. I just want to lay low and not rock the boat.
    amdx, Feb 8, 2012
    #9
  10. Sal
    Sal Guest
    "amdx" <> wrote in message
    news:b7625$4f32c758$4b4c116f$...
    > Hi All,
    > Digital TV.
    < snip >
    I take respectful exception to that last sentence. My digital cable box is
    about 130 cable-feet from the pole. My signal is tapped enroute for digital
    telephone, tapped enroute for Internet and then split (by me) so I can feed
    analog signals via a disttribution amp serving bedrooms, kitchen and shack.
    I get enough from the pole tap to do the job.
    Somebody is treating you badly -- maybe the cable company, maybe the marina.
    Yes, the approach for you to buy and install an inline, remote-power amp at
    the pole is entirely valid, technically. However, that's not in keeping
    with reasonable expectations. You needn't roll over so easily. It's
    supposed to work.
    What -- Are you worried you might offend somebody? That "somebody" seems
    quite okay with kicking you in the ankle. Or elsewhere.
    "Sal"
    Sal, Feb 9, 2012
    #10
  11. Joerg
    Joerg Guest
    amdx wrote:
    > Hi All,
    Looks like the cable guys screwed up.
    a. They should be putting enough signal on that cable to overcome the loss.
    b. They should be able to measure the amplitude of pilot signals at your
    end of the cable and tell you how much above minimums they are.
    > strength.
    > Mikek
    > PS.
    > digital channels.
    If all else fails you may need an amp. What Fred means with drop amp is
    usually called a "mast preamplifier", like this:
    http://www.amazon.com/Uhf-Vhf-Anten...EQ/ref=sr_1_20?ie=UTF8&qid=1328748729&sr=8-20
    I don't know this particular one but essentially it should be
    weather-proof. It gets its DC voltage via the coax, from a wall wart
    that would plug in at your boat. So no need to run a power supply cable
    up there.
    Don't go for too much gain. This dreaded DTV falls apart rather easily
    on the slightest distortion or cross-modulation. Not sure if the above
    amp can handle that. You might need a more expensive one. Michael
    Terrell might know which ones are good. What matters is dynamic range.
    Also, make sure you have a perfect 75ohms match at your end. The cable
    box from the cable company should provide that. if you have Internet
    and/or phone through them as well check that connection so it doesn't
    cause reflections. On a boat at sea stuff can corrode quickly.
    Oh, and don't dare to watch that boobs channel while your wife's on the
    boat :)
    Regards, Joerg
    http://www.analogconsultants.com/
    Joerg, Feb 9, 2012
    #11
  12. amdx
    amdx Guest
    On 2/8/2012 5:41 PM, Jeff Liebermann wrote:
    > Ok, 200ft of coax. Presumably RG6a/u.
    >> Digital TV.
    > You have been assimilated. Resistance is futile.
    > Something is wrong. The nominal signal from the cable drop is suppose
    > to be 0dBm. If there's a splitter involved, they like to crank it up
    > to about 10dBm. Your 200ft of RG6a/u will drop the signal from
    > between 4dB at the low end, to about 6dB at the high end. Your set
    > top box is suppose to operate with a 10dB margin. If you would kindly
    > disclose the maker and model, it might be possible to find the specs.
    > Typically, you'll have at least 10dB margin. Even with 200ft of coax,
    > you should have 4 to 6dB margin.
    Now remember the problem is quite intermittent, but seems to be
    happening almost daily for short periods.
    > Drag your cable box and TV over to the splitter and try it on the
    > incoming drop. If that works, move to the ports on the splitter. Make
    > sure that the unused ports are terminated properly. If that doesn't
    > work, call your unfriendly cable company and ask them why they don't
    > have sufficient level to operate your set top box without the 200ft
    > cable. If it does work, find a 200ft RG6a/u cable that isn't
    > saturated with water. Try to get some compressing fittings instead of
    > the crappy crimp type.
    There should be no water in the cable, it's only a couple of months
    old and both ends have crimp on connectors and are located in a box or boat.
    > Your unspecified cable set top box may also have some user accessible
    > diagnostics which include per channel signal levels. You may want to
    > check those.
    It does have diagnostics, I'm not sure if it is each channel though.
    But I can get some info out of the box. I'll be there Friday and I'll
    get that info and the model of the cable set top box.
    > I'm not familiar with Knology, but I suspect they do the same thing as
    > Comcast. With Comcast, the lower 72 channels are still analog in my
    > area. If so, you can probably plug your TV directly into the cable,
    > set the TV for cable frequencies, not broadcast, and see if that still
    > plays.
    I'm using Comcast at the boat. We are lucky here (I think) in that
    we have a choice of two cable companies.
    > Hint: Troubleshoot by substitution.
    > Drivel: I spent about an hour troubleshooting my TV distribution
    > system, only to find a brand new Type F "barrel" connector, with no
    > center connections. That which is most obviously correct, beyond any
    > need of checking, is usually the problem.
    Drivel is good.
    amdx, Feb 9, 2012
    #12
  13. amdx
    amdx Guest
    On 2/8/2012 6:38 PM, Jeff Liebermann wrote:
    > On Wed, 08 Feb 2012 15:41:08 -0800, Jeff Liebermann<>
    > Some better numbers for RG6a/u:
    > Freq Atten
    > MHz -dB
    > 10 0.8
    > 50 1.4
    > 100 2.9
    > 200 4.3
    > 400 6.4
    > 1000 11.0
    > The CATV band is approximately 50 to 800MHz. With 200ft of cable, you
    > should see 2.8 to 16dB of loss. While there may be problem at the
    > high channels, all the lower channels should work.
    Any idea where channel 428 would be in that frequency range?
    That's a duplicate of 4,2 but in HD, and it works when 42 doesn't.
    > The 4 way splitter has a loss of about -7dB.
    Just a point. I may not have made it clear. I had the tech put in two
    2way splitters and connect me to the first one. Hoping to gain 3db.
    (or 4) and it did make a difference.
    > Picking a random set top box:
    > <http://www.zoran.com/IMG/pdf/Simplify_NextGen_STBs_Solutions.pdf>
    > See Page 3. Sensitivity is -18dBm for 256QAM and -24dBm 64QAM.
    > At the low end, you have 0dBm in, 7dB loss in the splitter, 2.8dB loss
    > in the coax, resulting in -9.8dBm to the box. That's much more than
    > the -18dBm/-24dBm needed.
    > However, at the high end, things are not so wonderful. 0dbm in, 7dB
    > loss in the splitter, and 16dB loss in the coax, which delivers
    > -23dBm. That's 1dB of margin, which is not very good. Still, it
    > should work on the lower channels.
    amdx, Feb 9, 2012
    #13
  14. amdx
    amdx Guest
    On 2/8/2012 7:01 PM, Joerg wrote:
    > amdx wrote:
    >> Hi All,
    >> strength.
    >> Mikek
    >> PS.
    >> digital channels.
    > up there.
    > boat :)
    Been trying to think of something funny to say about that...
    Best I got is, she would say, "mine look better than those!
    amdx, Feb 9, 2012
    #14
  15. Joerg
    Joerg Guest
    >> Freq Atten
    >> MHz -dB
    >> 10 0.8
    >> 50 1.4
    >> 100 2.9
    >> 200 4.3
    >> 400 6.4
    >> 1000 11.0
    I believe that's entirely up to the cable company, you'd have to ask an
    engineer there.
    http://en.wikipedia.org/wiki/Digital_cable
    Quote "For example, a cable company might call channel 5-1 "channel 732"
    and channel 5-2 "channel 733"".
    Where does the other leg of that splitter go to? And is that end
    properly terminated?
    Regards, Joerg
    Joerg, Feb 9, 2012
    #15
  16. On 2/8/12 7:27 PM, Sal wrote:
    > "amdx"<> wrote in message
    >> Hi All,
    >> Digital TV.
    > < snip>
    I respectfully agree! 8^)
    I don't know exactly how it's done now, but when I worked in the Cable
    industry many moons ago, we had a lot of adjustment we could make. Even
    more, we had variable by frequency attenuators so we could ensure that a
    flat signal showed up. There was a lot of signal at the amplifiers, and
    if we really needed more oomph, we could put in a distribution amp.
    Another amp was really rare.
    > supposed to work.
    Yeah, there is something wrong there. For as much as people hate
    Comcast, when I had cable internet put in, they replaced all the cable
    from the pole to the house, and a lot inside the house. I did talk them
    out of replacing the new cable I had put in, but insisted on putting new
    connectors on them. The measured all the levels and set them high enough
    that I'd be able to add more televisions if I liked.
    Time to call the cable company and tell them you want your MTV.
    - 73 de Mike N3LI -
    Michael Coslo, Feb 9, 2012
    #16
  17. Sal
    Sal Guest
    "Michael Coslo" <> wrote in message
    news:jgvb3o$jg4c$...
    < snip >
    No way to know from here, but they may not be able to add another amp.
    While I was looking for something else, I lurched into this page:
    <http://www.cisco.com/en/US/products/hw/cable/ps2217/products_white_paper0900aecd800fc94c.shtml>
    While its intended audience is Internet modem designers, the noise
    discussions are informative with regard to other signals, too.
    My point: When you try stringing too many amps in line, the signal-to-noise
    ratio (SNR) eventually becomes unacceptable. (Remember the acceptable SNRs
    cited for 256 QAM and 64 QAM.)
    "Sal"
    Sal, Feb 9, 2012
    #17
  18. Sal
    Sal Guest
    "Sal" <> wrote in message news:jgvoub$fet$...
    > signal-to-noise ratio (SNR) eventually becomes unacceptable. (Remember
    > the acceptable SNRs cited for 256 QAM and 64 QAM.)
    > "Sal"
    Sorry. I should have said carrier to noise ratio (CNR), not SNR. SNR
    applies to post-detection signals. i joined the digital world late in life.
    "Sal"
    Sal, Feb 9, 2012
    #18
  19. Ian Jackson
    Ian Jackson Guest
    In message <>, Jeff Liebermann
    <> writes
    >to about 10dBm.
    Careful! Don't get your dBm mixed up with your dBmV. There's around 48dB
    difference! 0dBm is a massive 48dBmV. That would certainly make most
    set-top boxes wake up and pay attention!
    Ian
    Ian Jackson, Feb 9, 2012
    #19
  20. amdx
    amdx Guest
    >>> Freq Atten
    >>> MHz -dB
    >>> 10 0.8
    >>> 50 1.4
    >>> 100 2.9
    >>> 200 4.3
    >>> 400 6.4
    >>> 1000 11.0
    > engineer there.
    They go to two other outlets, that are used for transient boaters.
    sometimes they are used and sometimes they sit unterminated.
    I have not seen my problem better or worse when boats are in or out.
    But I have several 75 ohm F connector terminations. It's worth a try.
    Mikek
    amdx, Feb 9, 2012
    #20
    1. Advertisements
Similar Threads
  1. mike
    12
    4,155
  2. Replies:
    590
  3. Test cable TV input signal strength?
    , Jun 25, 2005, in forum: Electronic Repair
    6
    648
  4. Jack
    568
  5. amdx
    amdx, Feb 8, 2012, in forum: Electronic Design
    131
    2,147
    josephkk
    Feb 21, 2012
Loading...
Share This Page
