How to tell whether a jack is mono or stereo on a scheme
Discussion in 'General Electronics Chat' started by electronoobz, Sep 6, 2012.
  1. electronoobz
    electronoobz VIP Member
    Jan 14, 2012
    226
    i saw a pre amp scheme.. pls tell if it is stereo or mono
    [​IMG]
    [​IMG]
    and what is the difference between this two
    and what kind of jack was used for output? is it mono??
    #1
    1. Advertisements
  2. electronoobz
    19,592
    1,198
    Well, both are mono. Although you could build two of them and then you could do stereo.
    There is no output jack shown. You can use whatever you want.
    The amplifiers are different in many respects as well.
    The input jack shown in the top schematic is odd to say the least.
    (*steve*), Sep 6, 2012
    #2
    1. Advertisements
  3. electronoobz
    5,834
    797
    Germany-Europe-Earth-Sol System-Milky Way-Laniakea
    My guess:
    The input jack is used for a dual purpose:
    - input an audio signal: tip=audio, ring=ground
    - switch for power: only when a plug is inserted the -pole of the 9V batttery is connected to ground.
    Thus the amplifier will draw current from the battery only if a plug is inserted. Looks reasonably clever to me.
    Harald Kapp, Sep 6, 2012
    #3
  4. electronoobz
    Jan 14, 2012
    226
    what kind of input jack is used on the 2nd photo
    electronoobz, Sep 8, 2012
    #4
  5. electronoobz
    CocaCola VIP Member
    Apr 7, 2012
    3,636
    Gurnee, Illinois - USA - North America - Planet Ea
    None... It's just two terminations...
    CocaCola, Sep 8, 2012
    #5
  6. electronoobz
    CocaCola VIP Member
    Apr 7, 2012
    3,636
    Yep, that would be my guess as well...
    #6
  7. electronoobz
    Jan 14, 2012
    226
    what do you mean? is it a mono jack?
    i know the first one i know it's a stereo cause it has 3 pin.. but on the 2nd one im not sure about it.. is it a mono?
    #7
  8. electronoobz
    CocaCola VIP Member
    Apr 7, 2012
    3,636
    Steve already answered that in the first sentence of the first reply...
    It's actually a switched mono input, not stereo... It's just a clever way of switching ground so you don't need an on/off switch...
    ** Edit here is the type of jack used in the first schematic, they are called "Isolated Make Circuit" jacks, they are used in audio all the time, like it effects peddles for guitars so that no separate on/off switch is needed, it's off until plugged in...
    http://www.switchcraft.com/Drawings/13_cd.pdf
    #8
  9. electronoobz
    Jan 14, 2012
    226
    what is that? can i just use a simple mono jack?
    #9
  10. electronoobz
    CocaCola VIP Member
    Apr 7, 2012
    3,636
    Read my post I told you what it was... Yes you can use a regular mono jack you will just need to short the ground or switch on/off by another means...
    #10
  11. electronoobz
    Jan 14, 2012
    226
    how would i short it im new to this kind if thing sorry
    #11
  12. electronoobz
    19,592
    1,198
    Oops, the following helps you figure out if the socket is mono or stereo. Dir a plug, just look at it. Three connections = stereo, 2 = mono.
    A mono plug plugged into a mono socket will have one connection of the socket connected to one connection of the plug, and another connection on the socket connected to the other connection of the plug. Any other connections on the socket are usually some form of switching, often opening when a plug is connected.
    A mono plug connected to a stereo socket will have 2 connections on the socket connected to the tip of the plug, and another connected to the other connector of the plug. Again, any other connections are likely to be switch contacts.
    A stereo plug in a mono socket will almost always have only two of the connections on the plug connected through to the socket. The ring will not be connected. If it is connected, it will be connected to the same connection as the tip. Again, there may be other switch contacts.
    A stereo plug in a stereo socket will have three separate connections from the plug to the socket, with possibly some switch contacts.
    (*steve*), Sep 8, 2012
    #12
  13. electronoobz
    markbool
    Jul 5, 2012
    New Delhi
    This is a switched mono jack not stereo. Actually A switched mono jack, as a switch built into it that can be used to turn something on and off when the jack has something plugged into it.
    markbool, Sep 11, 2012
    #13
  14. electronoobz
    Jan 14, 2012
    226
    can i just connect the mono jack without switching it like connecting the tip to where it should be and the sleeve to the ground?
    if not then i really need a noob friendly guide on how to switch it.. sorry..
    anyway, may i know the main differences between those two preamp??
    which one is better??
    electronoobz, Sep 11, 2012
    #14
  15. electronoobz
    Jan 14, 2012
    226
    wait now i know what you guys are talking about...
    what i want to do now is to know how would i do this thing..
    i now understand what you guys trying to say.. thanks alot.!!!
    #15
  16. electronoobz
    Jan 14, 2012
    226
    will it work if will connect the tip to the sleeve?? i dont know where to buy a mono jack with that kind of pinouts so what im trying to do now is to find another way hahaha lol
    electronoobz, Sep 16, 2012
    #16
  17. electronoobz
    CocaCola VIP Member
    Apr 7, 2012
    3,636
    Nope that would short it out... I told you want to do in post #10...
    CocaCola, Sep 16, 2012
    #17
  18. electronoobz
    Jan 14, 2012
    226
    how would i short the ground then?
    #18
  19. electronoobz
    CocaCola VIP Member
    Apr 7, 2012
    3,636
    Add the red connection...
      File size:
      22.7 KB
      152
    #19
  20. electronoobz
    Jan 14, 2012
    226
    wait.. is that a mono jack with a 3 pin?? sorry for a very noob question..
    i only have two pin mono jack the tip and sleeve only.. and i think the scheme used 3 pin although i get your point there im still a bit confused cause it has 3 connections
    the one that goes to the battery to the cap and the last one to the ground
    electronoobz, Sep 17, 2012
    #20
    1. Advertisements
Similar Threads
  1. Thaqalain
    1,312
    Thaqalain
    Jul 31, 2005
  2. Jon
    Stereo and mono out the same jack?
    Jon, Feb 14, 2004, in forum: Electronic Design
    20
    812
  3. t.hoehler
    Does anyone know whether Jack Darr is still alive?
    t.hoehler, Jul 12, 2003, in forum: Electronic Repair
    5
    892
    Tweetldee
    Jul 15, 2003
  4. crusher300@yahoo.com
    Adding external input jack (stereo to mono)
    crusher300@yahoo.com, Aug 13, 2007, in forum: Electronic Basics
    1,273
    Bob Masta
    Aug 14, 2007
  5. whiterabbit
    Audio - mono to dual mono
    whiterabbit, Mar 8, 2014, in forum: Circuit Help
    8
    894
    whiterabbit
    Mar 14, 2014
Loading...
