How to reprogram china DVD EEprom?
Discussion in 'Electronics Repair' started by Comnics, Aug 30, 2012.
  1. Comnics
    Comnics
    Feb 12, 2012
    20
    philippines
    anyone can help me? how to reprogram china DVD EEprom. many DVD's i encountered the problem is corrupted EEPROM.
    #1
    1. Advertisements
  2. Comnics
    CocaCola VIP Member
    Apr 7, 2012
    3,636
    Gurnee, Illinois - USA - North America - Planet Ea
    On some devices you might even be able to do it by inserting a DVD that contains a new firmware flash...
    If not you get an EEPROM programmer that is compatible with whatever EEPROM chip is in the player and get a good dump or copy of the data that is supposed to be on said chip and reflash it... The Willem programmer is one of the more popular universal programmers for doing this at the hobbyist level... On some players you might be able to do it externally with a JTAG or JTAG like port but that would require you having compatible JTAG or JTAG like interface software that might not be available to the public for any particular device...
    CocaCola, Aug 30, 2012
    #2
    1. Advertisements
  3. Comnics
    Timescope
    Aug 30, 2012
    43
    A TopWin programmer is also very easy to use and connects to a computer with a usb cable. You would need to find the same model DVD player that is working, remove the eeprom and insert it into the programmer, copy the code using the TopWin software then insert your corrupted ic (if it is still working) into the programmer, erase it, then write the data to it. If your ic is dead, try EN25T80 made by EON.
    Timescope
    Timescope, Aug 30, 2012
    #3
    1. Advertisements
Similar Threads
  1. Brad
    919
    The_Emporium
    Oct 27, 2005
  2. Pearlslater@gmail.com
    looking for someone to reprogram eprom Los Angeles
    Pearlslater@gmail.com, Dec 1, 2007, in forum: Electronic Basics
    414
    John Fields
    Dec 5, 2007
  3. Janet Gilmore
    reprogram alarm co phone number via-30pse vista-10se
    Janet Gilmore, Sep 15, 2006, in forum: Security Alarms
    1,227
    Bob Worthy
    Sep 15, 2006
  4. Alan
    Need help on reprogram a Faraday MPC 2000
    Alan, Mar 29, 2007, in forum: Security Alarms
    612
  5. Bruce in alaska
    Re: Digital Yacht AIT250 - reprogram MMSI ?
    Bruce in alaska, Aug 26, 2009, in forum: Boat Electronics
    1,978
Loading...
