How to pick the right transistor?
Discussion in 'Electronic Basics' started by JedOs86@gmail.com, Aug 12, 2006.
  1. Guest
    I have been trying to read up on formulas for selecting transistors. I
    am a bit math impaired, but not too badly. I am totally confused about
    what each tearm means. For instance the Ic and Hfe, I kind of
    understand them, but not enough to do my own calculations for my
    designs. I need an image with examples on picking the right base
    resistor for the transistor. If I could rate my confusion from 1 to 10
    , it would be around 8. Thanks to all in advance.
    , Aug 12, 2006
    #1
    1. Advertisements
  2. Jim Land Guest
    wrote in news:1155358462.361995.161140
    @i3g2000cwc.googlegroups.com:
    Picking transistors and values for components connected to them is an
    advanced electronics skill. Some people go to college and get an
    engineering degree to learn this.
    Best for you to start by building circuits already designed by someone
    else, using schematics you find in books or magazines or by Googling the
    Web. (LOTS of them are available! You can find a circuit to do just
    about anything you can think of.)
    Once you've built some circuits and find they don't work right off, and
    then got them working the way they're supposed to, you can start
    understanding how these circuits work and why the components have the
    values they do. You'll see why a certain transistor works well in a
    partcular kind of circuit, and can try using it in a similar circuit.
    And you can ask some intelligent questions about circuit design here.
    Jim Land, Aug 12, 2006
    #2
    1. Advertisements
  3. Guest
    My particular situation is that I need to find a transistor that can
    drive a 220mA load with a very high current gain, I was thinking maybe
    a darlington pair, but there is just too many too choose from.
    , Aug 12, 2006
    #3
  4. default Guest
    OK you have one paramater (current) and have some idea what gain you
    need, presumably you also know what voltage it has to stand off - then
    you'll just have to pick one of the hundreds that will work. As
    likely as not, there won't be one transistor that will work, but many.
    There probably won't be one that is clearly the best, unless your
    application is tough.
    What is the application?
    Don't rule out mosfets. They are voltage operated rather than current
    driven - hi input impedance translates to high gain since they take
    pico amperes to turn on. (but many require about four volts of bias
    to turn on if that is a concern) Very efficient in lots of
    applications.
    A mosfet that can switch 60 amps may have an "on" resistance of a few
    hundredths of an ohm so it won't drop much voltage. The trade off
    comes when you need to switch high voltage - then the "on" resistance
    for a HV part is higher. At some point it makes more sense to use a
    bipolar or an insulated gate bipolar (best of both worlds for some
    applications)
    ----== Posted via Newsfeeds.Com - Unlimited-Unrestricted-Secure Usenet News==----
    http://www.newsfeeds.com The #1 Newsgroup Service in the World! 120,000+ Newsgroups
    ----= East and West-Coast Server Farms - Total Privacy via Encryption =----
    default, Aug 12, 2006
    #4
  5. default Guest
    These are a few of the popular transistors for high gain NPN in small
    signal low voltage applications . . . Popular= common and low cost
    Check out the 2N7000
    It is a handy mosfet that can directly replace an NPN transistor in
    lots of applications - with lots of gain. TO92 case
    Takes about 4 volts to turn on with a few microamps of current -
    pulsed operation with 2 amps of drain current and it takes 8 volts to
    turn on
    http://www.fairchildsemi.com/pf/2N/2N7000.html\ (propaganda)
    http://www.fairchildsemi.com/ds/2N/2N7000.pdf (data sheet)
    From the propaganda:
    They can be used in most applications requiring up to 400mA DC and can
    deliver pulsed currents up to 2A. These products are particularly
    suited for low voltage, low current applications such as small servo
    motor control, power MOSFET gate drivers, and other switching
    applications.
    and they are very inexpensive
    The other old standby for high gain NPN is the MPSA13 darlington
    www.onsemi.com/pub/Collateral/MPSA13-D.PDF
    DC gain of 5,000+ collector current of 500 ma
    inexpensive and very common TO92 case
    #5
  6. Guest
    Thanks default, I will look at the links you offerd. You mentioned
    using MOSFETs, I may not be able to use these because I need to drive
    two different base(gate) with less than 25mA from a PIC Output signal
    that also goes through a voltage drop (due to a diode) to about 3.8v.
    So the MOSFETS, without a transistor amplifier, are out of the
    question.
    , Aug 12, 2006
    #6
  7. () writes:
    In hobby circles, generally a small selection are used. People pick
    what they are seeing in the other articles in the hobby magazines, and
    those types are reinforced by what the hobby outlets carry. So somehow
    decades ago, someone started using a 2N2222, and the hobby outlets decided
    to carry it (it being a recognizable device), which fueled it's use in
    further projects.
    So traditionally if someone was starting from scratch rather than copying
    an existing circuit, they'd go through the relatively short list of
    devices that could be bought easily, checking the specs if they didn't
    immediately notice one that stood out for their purpose, until they
    found something suitable. Sure, there were loads of other devices
    available, but maybe not in small quantities or without requiring lots
    of gyrations.
    I suppose that has changed with places like Mouser and Digikey, relatively
    accessible to the hobbyist but a fairly full line catalog.
    Michael
    Michael Black, Aug 12, 2006
    #7
    I would be looking for a transistor with an advertised maximum current
    3 to 10 times higher than such a requirement, since most transistors
    hit their peak current gain at 1/3 to 1/10th of maximum rated Ic
    (collector current). But if you need highest gain, you might look at
    transistors specifically designed with this characteristic, like the
    ones made by Zetex. You don't mention whether you need PNP or NPN,
    the highest collector voltage the device must withstand, whether you
    are switching 220 mA or linearly amplifying at that current, the
    signal frequency (or switching speed), how important low on state
    voltage drop is (if switching). But if you are switching, remember
    that darlingtons always drop at least 1.2 volts when on, whereas
    simple transistors might saturate down to a small fraction of a volt
    when on, lowering the on state losses.
    Here are a pair of random Zetex data sheets to give you some idea what
    you might find from them:
    http://www.zetex.com/3.0/pdf/ZTX718.pdf
    http://www.zetex.com/3.0/pdf/ZTX1049A.pdf
    a curve you should think about (for switching) are VCE(sat) (collector
    to emitter saturation voltage, with a specified ratio between
    collector current and base current up to 50/1 or a base current of 4.4
    mA for your load). Both these transistors keep the saturation voltage
    well below .1 volt at 220 mA and 4.4 mA base current. If you can
    tolerate a little more saturation voltage, you could use less base
    current.
    Also, look at the current gain curves versus collector voltage (Hfe
    vs. Ic) to see that the peak gain is well below rated maximum
    collector current.
    Digikey carries these and many more, and their search engine can be
    used to narrow down the choices by polarity, collector voltage and
    current ratings and package, before you dive into data sheets.
    http://www.digikey.com/
    John Popelish, Aug 12, 2006
    #8
  9. Eeyore Guest
    You choose a popular one !
    Easily recognised from the stock levels held by distributors like Mouser etc
    Graham
    Eeyore, Aug 12, 2006
    #9
    >question.
    At 25mA, the PIC outputs probably won't be 4.5V (assuming a 5V supply,
    about which I'm also not sure.) My guess is that they will be about
    25mA*70ohms or 1.75V less than your supply voltage before they meet
    your diode. (Actual impedance will vary some and you need to be aware
    that you cannot drive all pins at the same 25mA, as there is another
    spec that provides an absolute maximum [don't get too close to it]
    that limits the total port output.) Or were you thinking that it was
    a diode there in the PIC to explain the 3.8V output?
    Anyway, I think we understand the following:
    Drive signal: PIC output
    Number of circuits: 2
    Mode of operation: switch (unless I assume far too much here)
    Load current: 220mA
    Load impendance: unknown, but may have significant L, if relay
    Load voltage rail: unknown
    PIC Voltage rail: ??, but either 4.5V (calculated from your
    assumed diode drop and 3.8V mentioned) or
    else 5V (blindly assumed as "normal")
    Could you expand the above to provide more precise information? A
    highly inductive or highly capacitive load may require other caveats
    as compared to a purely resistive load. Also, are you planning on
    connecting the load between ground and the 'switch circuit' or between
    some power rail and the 'switch circuit'?
    Assuming the above doesn't stray too far from your situation, one note
    right now is that you should want to keep your PIC drive current as
    low as is reasonable, while being able to reliably drive the switch
    circuit. I'd target _much_ less than 25mA as reasonable, here.
    Something on the order of just a few mA. I don't like the idea of
    just seeing the maximum spec of 25mA and merrily planning on using
    that as an option.
    Jon
    Jonathan Kirwan, Aug 12, 2006
    #10
  11. default Guest
    >question.
    Not trying to push mosfets - but I find they can do some interesting
    things at times and save stages of amplification - you have 25 ma of
    drive available from the pic, but because the mosfet only needs a
    microamp it may work because the voltage out will be higher for lower
    current loading.
    As some respondants already pointed out - you tend (should) use what
    everyone else uses. It is proven, it is in good supply, and is cheap
    - and the manufacturers get better at making them - the stated spec
    might be 60 volts, for instance, but you may find they all can go to
    better than 100 volts and keep working..
    Some good ones to use if you can:
    2N3906, TO92 PNP
    2N3904, TO92 NPN
    2N2222 . . . 2N2222A, TO18 metal, PN2222, TO92 NPN
    2N2102, TO5 metal NPN
    2N2905, TO5 metal PNP
    2N3055, ancient and ubiquitous for cheap NPN TO3 metal power device
    with a host of work alikes with better specs . . . 2N3771, 2N3772,
    2N3773
    2N7000 mosfet, TO92
    MPSA13, darlington, TO92 NPN
    TIPXXX TO220 - and other cases - large selection - both darlingtons
    and ordinary bipolar power devices Both Sexes
    IRFXXX TO220 ditto
    It does look like TO5 and TO3 transistors have/are gone/going out
    of favor for cheaper plastic parts Like the TO137, TO147, and TO220
    etc.. When in doubt buy the cheapest part that will work or see what
    others use.
    #11
  12. Guest
    > >question.
    > Load current: 220mA
    > that as an option.
    > Jon
    Thanks for replying. Using transistors, I was only planning on using at
    most 6mA of the 25mA. I dont have the actual spec sheet of the PIC, the
    guys I bought it from put a dot over the P/N of it. However they didnt
    say 25mA Max, they just said 25mA, so maybe it is a nominal output.
    The loads I am driving with the transistors arent large, probobly no
    more than a relay load, around 150mA. However I also wanted to drive a
    MOSFET from one of the transistors to turn on/off a 556 PWM circuit.
    I was thinking using the 2N4401, someone on another group suggested it
    to me. The thing is that I am not totally sure because I am a little
    weary about the math behind choosing a transistor.
    , Aug 12, 2006
    #12
  13. Jim Land Guest
    I bet you are not the first person in the world to want to interface a PIC.
    Have you looked for circuits that already do what you want to do?
    #13
  14. wrote:
    (snip)
    Lets take a look at the data sheet:
    http://www.onsemi.com/pub/Collateral/2N4401-D.PDF
    The collector saturation region graph on 6 shows that the collector
    saturation voltage falls below .6 volts for a base current of about a
    milliamp, and the DC gain curves show the gain falling only a little
    between 100 and 200 mA, so you can expect this sort of saturation
    voltage at 200 mA with about 2 mA of base current. If you can afford
    4 or 5 mA of base current, you should have some margin for a low gain
    transistor.
    John Popelish, Aug 13, 2006
    #14
    1. Advertisements
Similar Threads
  1. Yzordderex
    Please help me pick a diode
    Yzordderex, Oct 10, 2003, in forum: Electronic Design
    544
    Yzordderex
    Oct 11, 2003
  2. Mongrel Shark
    How do I find the right transistor?
    Mongrel Shark, Jun 6, 2012, in forum: Electronic Projects
    33
    1,815
    KrisBlueNZ
    Jun 8, 2012
  3. schean
    Help pick right hardware for project
    schean, Nov 8, 2012, in forum: Electronic Projects
    415
    schean
    Nov 8, 2012
  4. John Doe
    OT How does a bicycle turn right when leaned right?
    John Doe, Aug 18, 2013, in forum: Electronic Design
    17
    598
    josephkk
    Aug 24, 2013
  5. Raven Luni
    Transistor Switching: Am I Doing it Right?
    Raven Luni, Sep 7, 2013, in forum: General Electronics Chat
    3
    308
Loading...
