How to measure Pulse Current?
Discussion in 'Electronic Equipment' started by GSiu, Jul 9, 2006.
  1. GSiu
    GSiu Guest
    Is there any suggestion how to measure Pulse current up to 10KA and
    pulse wide below 10mA?
    GSiu, Jul 9, 2006
    #1
    1. Advertisements
  2. Jim Yanik
    Jim Yanik Guest
    "GSiu" <> wrote in
    news::
    below 10ma,a clip-on P6021,P6022(AC)current probe,or a TM500/AM503/A6302
    system,DC-50 Mhz BW. The AM503/A6303 probe measures high currents (IIRC,up
    to 100's of A),but not 10,000A.
    you may need some sort of current transformer for those really high
    currents.
    Jim Yanik
    jyanik
    at
    kua.net
    Jim Yanik, Jul 9, 2006
    #2
    1. Advertisements
  3. Robert Baer
    Robert Baer Guest
    Jim Yanik wrote:
    > "GSiu" <> wrote in
    > news::
    > currents.
    *All* of those probes are current transformers...
    At 10,000 amps one would have a problem in preventing saturation; the
    secondary winding resistance probably cause enough IR drop that the
    current would be low enough so that the current (amps) times turns (=
    ampere-turns) would reflect back to the primary (of one turn) so that
    the net core flux would be excessive.
    Now, it might be done with a *large* core and (relatively) large
    diameter wire (to reduce that IR drop)...
    So, start with a turns ratio of (say) 10,000 to 1, meaning the
    secondary has 10,000 turns.
    For insignificant IR drop, the secondary should be no smaller than #20.
    From that, figure out the cross-sectional area taken for 10,000
    wires, thenmathematically "spread" it out over a torus (if that is the
    shape of the core) or rectangle (if "C" or "E" type core).
    That should give you a rough idea as to the minimum core size (will
    need to be larger due to insulation, etc).
    Robert Baer, Jul 9, 2006
    #3
  4. Jim Yanik
    Jim Yanik Guest
    Robert Baer <> wrote in
    news:4r3sg.2197$:
    > Jim Yanik wrote:
    >> "GSiu" <> wrote in
    >> news::
    >> TM500/AM503/A6302 system,DC-50 Mhz BW. The AM503/A6303 probe measures
    >> high currents (IIRC,up to 100's of A),but not 10,000A.
    >> currents.
    The AM503 probes are Hall-effect devices -with- a current transformer for
    hi-freq response.
    And they still are PROBES(based on transformers,yes.)
    ,not a stand-alone transformer.
    They also can be slipped over a conductor and not have to be hard-wired
    into the circuit.
    Jim Yanik
    jyanik
    at
    kua.net
    #4
  5. Jamie
    Jamie Guest
    CT..
    Current Transformer.
    you simply pass the load through
    it., the terminals give you a ratio..
    something like a 500:1 comes to mind.
    also there is the concern of the pulse
    width time your looking for ?
    also you have Tranducers that can convert
    to 4..20, voltage or digitial output etc..
    Real Programmers Do things like this.
    http://webpages.charter.net/jamie_5
    Jamie, Jul 9, 2006
    #5
  6. Robert Baer
    Robert Baer Guest
    > news:4r3sg.2197$:
    >>Jim Yanik wrote:
    >>>"GSiu" <> wrote in
    >>>news::
    >>>currents.
    > hi-freq response.
    > into the circuit.
    I believe this is the first time that "stand-alone" was mentioned...
    Robert Baer, Jul 10, 2006
    #6
  7. In article <UYhsg.6490$>,
    Robert Baer <> wrote:
    > > news:4r3sg.2197$:
    > >>Jim Yanik wrote:
    > >>>"GSiu" <> wrote in
    > >>>news::
    Rogowski coil?
    John McMillan, Jul 10, 2006
    #7
  8. Robert Baer
    Robert Baer Guest
    >>>news:4r3sg.2197$:
    >>>>Jim Yanik wrote:
    >>>>>"GSiu" <> wrote in
    >>>>>news::
    > Rogowski coil?
    Wow! Used Google to find out what that was, and the first hit, the
    PDF is very illuminating and useful.
    #8
  9. In article <yczsg.5621$>,
    > > Rogowski coil?
    I had a summer job at Culham lab years back and we used to make
    these things out of stripped Hackethal delay cable. I don't
    suppose you can still get Hackethal or anything like it.
    Last year I built myself a tiny Rogowski coil by soldering eight surface
    mount inductors into an octagon. It worked too!
    John McMillan, Jul 14, 2006
    #9
    1. Advertisements
Similar Threads
  1. Tibur Waltson
    Using AC current meter to measure DC current?
    Tibur Waltson, Dec 30, 2003, in forum: Electronic Basics
    2,169
    ddwyer
    Dec 31, 2003
  2. DBM
    Guranteed pulse/no pulse on 555 power-on
    DBM, Oct 22, 2003, in forum: Electronic Design
    3
    1,279
  3. stevo
    12
    1,646
  4. Terry
    Long pulse to short pulse
    Terry, Oct 26, 2004, in forum: Electronic Design
    11
    1,184
    Fred Bloggs
    Oct 27, 2004
  5. Guest
    973
    Si Ballenger
    Oct 13, 2004
Loading...
Share This Page
