how to find equivalent transistor
Discussion in 'Hobby Electronics' started by TonyS, Sep 25, 2008.
  1. TonyS
    TonyS Guest
    I need to replace a 8050 transistor.
    I found the data sheet on the web but no source to buy one.
    (NPN TO92 IC 800mA 30V switching/audio, drives a siren pieco)
    What's a proper way to find an equivalent transistor that's actually available?
    Cheers
    Tony
    TonyS, Sep 25, 2008
    #1
    1. Advertisements
  2. Franc Zabkar
    Franc Zabkar Guest
    On Thu, 25 Sep 2008 13:53:40 +0800, TonyS <>
    put finger to keyboard and composed:
    >Hi,
    >Cheers
    >Tony
    These are just "jelly bean" general purpose transistors:
    http://www.datasheetarchive.com/pdf-datasheets/Datasheets-5/DSA-87957.pdf
    A BC337A looks like it might substitute for it:
    http://www.datasheetarchive.com/pdf-datasheets/Datasheets-12/DSA-228097.pdf
    Just be careful of the pinout. One is EBC, the other is CBE.
    - Franc Zabkar
    Please remove one 'i' from my address when replying by email.
    Franc Zabkar, Sep 25, 2008
    #2
    1. Advertisements
  3. TonyS
    TonyS Guest
    >> Hi,
    >> Cheers
    >> Tony
    Using some random NPNs from my junk box produced a lot of dead bodies though:)
    > - Franc Zabkar
    I can get a BC337 from Altronics. Will watch pinout:)
    Easier than I thought!
    Thanks!
    Tony
    TonyS, Sep 25, 2008
    #3
  4. Phil Allison
    Phil Allison Guest
    "TonyS"
    > available?
    ** There is no simple procedure for such a complex task - anyone who
    tells you there is a fool or a damn liar.
    ..... Phil
    Phil Allison, Sep 25, 2008
    #4
  5. TonyS
    TonyS Guest
    Phil Allison wrote:
    > "TonyS"
    >> available?
    > .... Phil
    You are right.
    When data sheets where still in books I used to have a book with tables that
    showed equivalent devices by different manufacturers. I was hoping that the web
    has something like this to offer.
    In this case hFE is important. The driving circuit is just 2*4069 inverters in
    parallel over 100 Ohms. The load is an unknown transformer.
    Tony
    TonyS, Sep 25, 2008
    #5
  6. ian field
    ian field Guest
    "TonyS" <> wrote in message
    news:48db2768$0$16041$...
    > Hi,
    > available?
    > Cheers
    > Tony
    The 8050 is a fairly good spec for a TO92 device, if a TO126 part will fit
    the available space it would be much easier to find a device that meets or
    exceeds the most important parameters.
    ian field, Sep 25, 2008
    #6
  7. TonyS
    TonyS Guest
    >> Hi,
    >> Cheers
    >> Tony
    > - Franc Zabkar
    Tried the BC337.
    Blew up after 20 seconds:)
    Was worth a try for $0.35
    Tony
    TonyS, Sep 27, 2008
    #7
  8. TonyS
    TonyS Guest
    >> Hi,
    >> available?
    >> Cheers
    >> Tony
    Found a good one in TO92, 2STX1360.
    http://www.st.com/stonline/products/literature/ds/11763.pdf
    Vce sat 150mV typ @ 2A.
    Don't know where to get it, apart from Digikey...
    There would be space for a larger package though, any suggestions?
    Already feeling a bit silly trying to fix the thing;-(
    Tony
    TonyS, Sep 27, 2008
    #8
  9. ian field
    ian field Guest
    news:48ddc4ee$0$16025$...
    >>> Hi,
    >>> available?
    >>> Cheers
    >>> Tony
    >> fit the available space it would be much easier to find a device that
    >> meets or exceeds the most important parameters.
    > Tony
    One thing to watch is the pin-out, the datasheet I found for the 8050
    (SS8050) shows centre pin base, the ST part and also the TO126 option I
    suggested both have centre pin collector, The TO92 or TO92L would be easier
    to bend the pins to fit than a TO126 but if you're never going to have to
    change the transistor again it might be worth cutting and patching the
    tracks.
    ian field, Sep 27, 2008
    #9
    1. Advertisements
Similar Threads
  1. R.Lewis
    transistor equivalent
    R.Lewis, Jan 7, 2005, in forum: Electronic Components
    1,151
    R.Lewis
    Jan 7, 2005
  2. kmillar
    3
    6,314
    Winfield Hill
    Apr 21, 2006
  3. Colin Stirling
    Equivalent or Equivalent Part Numbers for UHF Tuner
    Colin Stirling, Jul 20, 2003, in forum: Electronic Repair
    1,062
    Colin Stirling
    Jul 20, 2003
  4. Richard Principal
    Why do transistor equivalent do it
    Richard Principal, Nov 5, 2003, in forum: Electronic Repair
    679
    Richard Principal
    Nov 5, 2003
  5. Sunny
    Single transistor equivalent to ULN2803?
    Sunny, Dec 31, 2003, in forum: Electronic Repair
    667
    Sunny
    Dec 31, 2003
Loading...
Share This Page
