How to determine if capacitor has gone bad ?
Discussion in 'General Electronics Chat' started by sizzle, Apr 21, 2012.
  1. sizzle
    sizzle
    Apr 19, 2012
    19
    I know the obvious way if radial is to check its top but can it be bad even if obvious difference hasn't come up yet ?
    #1
    1. Advertisements
  2. sizzle
    davenn Moderator
    9,687
    954
    Sydney, Australia
    Now I'm assuming you are mainly refering to electrolytic capacitors, yes, they can be bad without any outwardly visible signs.
    Electro caps will quite happily dry out without bulging. Its generally the ones that are in hi temperature situations that bulge and blow their top.
    so any over ~ 10 years of age that are in low temp enviroment couls easily be faulty and testing with a meter is you best option
    davenn, Apr 21, 2012
    #2
    1. Advertisements
  3. sizzle
    19,920
    1,282
    And to complicate matters, the same capacitor in two different circuits may be considered failed in one and perfectly OK in another.
    As an example, a filter capacitor in a switchmode power supply might be considered failed if it's ESR rises above an ohm. However, the same capacitor might be used in an audio circuit and be perfectly OK even if the ESR rose to 100 ohms.
    That means there's no simple test (other than for the most gross failures) that apply everywhere.
    (*steve*), Apr 22, 2012
    #3
  4. sizzle
    GreenGiant VIP Member
    Feb 9, 2012
    828
    5
    Massachusetts
    You want to test them out of circuit if you suspect they are bad
    I generally test in circuit and if they read close to what they are supposed to then I leave them, but if they are a little off I will pull them out and test that way
    But like steve said circuits vary, for example I was fixing a Bose surround sound which the LCD screen did not work at all, there were two 100uF caps, one read 89uF out of circuit and one read 90uF, replacing them with new ones fixed the screen, in some cases a slight difference can make all the difference
    GreenGiant, Apr 24, 2012
    #4
    1. Advertisements
Similar Threads
  1. SEB
    528
    CFoley1064
    Dec 12, 2004
  2. steevjanpan@hotmail.com
    HP 3456A multimeter ROMS gone bad
    steevjanpan@hotmail.com, Apr 20, 2005, in forum: Electronic Design
    18
    2,310
    snovotill@hotmail.com
    Apr 23, 2005
  3. VHarris
    Wall Transformer Gone Bad?
    VHarris, Nov 4, 2005, in forum: Electronic Design
    8
    493
  4. Joshua G Senecal
    Weller station gone bad--how to fix?
    Joshua G Senecal, Dec 18, 2003, in forum: Electronic Equipment
    24
    2,748
    Frank Dinger
    Dec 23, 2003
  5. Sasqui
    Vtech 2420 Cordless Phone Keypads Gone Bad
    Sasqui, Mar 19, 2006, in forum: Electronic Repair
    806
    Scott Lane
    Mar 20, 2006
Loading...
