how to connect light indicator
Discussion in 'General Electronics Chat' started by rajesh, Oct 30, 2012.
  1. rajesh
    rajesh
    Oct 30, 2012
    5
    I have a electric water heater (geyser) in India, but the two light indicator(one for power and other for heating) are burnt out and they were therefore removed and the wire were black taped.
    Those indicator connecting wire were placed parallel.
    I want to put back the indicator with neon lamp indicator but since they were removed I couldn't know if there were any resistor connected with the indicator.
    Can I use any neon lamp indicator and appropriate resistor.
    If I am right, the parallel connection will increase the current through the load(water heater).
    So how to connect the indicator and resistor.
    Water heater specification
    230 v, 50 hz
    input 2kw , capacity - 15 lit
    Thanks.
    #1
    1. Advertisements
  2. rajesh
    duke37 VIP Member
    Jan 9, 2011
    3,701
    333
    Derbyshire. UK
    Neon indicators usually go black rather than burn out.
    The small neon bulbs need a resistor in series, 270k or so. The higher the resistance, the less light but the longer they will last.
    Some neon bulbs come with a resistor built in, these will be labelled 250V.
    One should be connected across the power input and the other across the heater.
    The power consumption of the neons is minimal and will not affect the operation.
    duke37, Oct 30, 2012
    #2
    1. Advertisements
  3. rajesh
    rajesh
    Oct 30, 2012
    5
    Thanks for the reply.
    I used a small neon bulb that has built in resistor of 82k in series(i checked with multimeter, color gray-red-orange) across the power input. But it didn't glow. I had checked the wire hanging across the power input for connectivity also. The light glows well when I put directly on the wall-plug.
    Whats wrong, should i remove the resistor, or what resistor should i use.
    rajesh, Nov 1, 2012
    #3
  4. rajesh
    duke37 VIP Member
    Jan 9, 2011
    3,701
    333
    Derbyshire. UK
    You should not remove the resistor and if the bulb is designed for the voltage that you have the value should be OK. If you have bought a bulb for 110V, then the resistor should be at least doubled.
    If the bulb lights when connected directly to the mains, it is working. If it does not light elsewhere, then it is either not connected properly or there is no power there.
    A neon needs about 90V to strike.
    duke37, Nov 1, 2012
    #4
  5. rajesh
    rajesh
    Oct 30, 2012
    5
    I have attached the connection.
    I don't know I am not getting current at D, when the geyser is on. But the water is heating. I am getting current at C when it is heating and no current when the heating is off.
    I have connected power indicator at G & H and thermostat heating indicator at C & D and I do not get any light indication.
    I am connecting neon indicator and resistor (82K) in series. Power supply is 220 V.
    Thanks.
    rajesh, Nov 5, 2012
    #5
  6. rajesh
    duke37 VIP Member
    Jan 9, 2011
    3,701
    333
    Derbyshire. UK
    Power in, Fand G
    Heater on F and E
    The thermal overload has a wire going in and nothing comming out. Does the heater work?
    duke37, Nov 5, 2012
    #6
  7. rajesh
    rajesh
    Oct 30, 2012
    5
    Thanks you very much for the reply.
    Now, the heater is not working at all. It showing no current at C, sometimes it show but for few moments only, I suspect the temp regulator set to low as I have tempered it many times while removing & fitting the cover. I corrected but now its showing no current at all.
    I had to call the service center, lets see.
    rajesh, Nov 7, 2012
    #7
  8. rajesh
    rajesh
    Oct 30, 2012
    5
    For the indicator light it has wires at G&H and C& D only.
    rajesh, Nov 7, 2012
    #8
    1. Advertisements
Similar Threads
  1. mikem3
    12 volt indicator light
    mikem3, May 22, 2006, in forum: Electronic Design
    521
    John Fields
    May 22, 2006
  2. Keith
    Strobe light phone indicator
    Keith, Feb 21, 2004, in forum: Electronic Equipment
    3
    424
    Watson A.Name - \Watt Sun, the Dark Remover\
    Feb 29, 2004
  3. M.Joshi
    Light switch warning indicator
    M.Joshi, Dec 28, 2005, in forum: Electronic Repair
    27
    931
    Dave Plowman (News)
    Jan 5, 2006
  4. Impmon
    EPROM eraser- light on indicator?
    Impmon, Nov 1, 2006, in forum: Misc Electronics
    3
    632
    Baron
    Nov 1, 2006
  5. Ted Swirsky
    Where to find a few 120V indicator indicator lights?
    Ted Swirsky, Apr 18, 2006, in forum: Beginner Electronics
    5
    3,037
    petrus bitbyter
    Apr 21, 2006
Loading...
