How many different size banana plugs are there?
Discussion in 'Electronic Design' started by Don Lancaster, Sep 17, 2007.
  1. What are their proper names?
    And where can I find their intended dimensions?
    As near as I can tell, a "regular" banana plug fits a 0.15 inch jack.
    What might be a "miniature" banana plug fits a 0.12 inch jack.
    What might be a "subminiature" banana plug fits an 0.10 inch jack.
    Such as on the Triplett 310 multimeter.
    And there are apparently "oversize" banana plugs that fit an 0.25 inch hole.
    Can anyone verify the proper names and exact sizes?
    Many thanks,
    Don Lancaster voice phone: (928)428-4073
    Synergetics 3860 West First Street Box 809 Thatcher, AZ 85552
    rss: http://www.tinaja.com/whtnu.xml email:
    Please visit my GURU's LAIR web site at http://www.tinaja.com
    #1
    1. Advertisements
    > hole.
    Bananaplus are either 4mm or 2mm as far as I know.
    Rene
    Ing.Buero R.Tschaggelar - http://www.ibrtses.com
    & commercial newsgroups - http://www.talkto.net
    Rene Tschaggelar, Sep 17, 2007
    #2
    1. Advertisements
  3. "Don Lancaster" <> wrote in message
    news:...
    > hole.
    There are four sizes you are likely to meet. Normally called 2mm, 4mm,
    0.1" & 1/8". The 4mm, would be your '0.15"' one, with the hole slightly
    larger than you are measuring. The 1/8", would be your '0.12"' one. The
    0.1" variety, has the socket 2.64mm in diameter (0.104"). This is commonly
    called 'mini banana', and will be what is on the Triplett meter.
    The 2mm variety tends to be used only on stuff from places like Germany,
    while the 1/8" version, was common on British kit, perhaps 40 years ago,
    and I haven't seen this on sale in recent times.
    There are quite a few odd 'custom' varieties around. For instance, here in
    the UK, there are Fluke meters, with non standard ones, that were supplied
    to (back in the old days), BT.
    Best Wishes
    Roger Hamlett, Sep 17, 2007
    #3
  4. Don Lancaster
    colin Guest
    "Roger Hamlett" <> wrote in message
    news:YVrHi.37259$...
    > news:...
    >> hole.
    I wonder why did they call them banana plugs ?
    I mean theyr not banana shaped,
    theyr not yellow, well ok maybe some of them are
    colin, Sep 17, 2007
    #4
  5. Don Lancaster
    Eeyore Guest
    What reason do you have for thinking they're specified in inches ?
    The only one I know that's called a banana plug (and it's very popular) is 4 mm.
    Graham
    Eeyore, Sep 17, 2007
    #5
  6. Don Lancaster
    Phil Allison Guest
    Phil Allison, Sep 17, 2007
    #6
  7. Don Lancaster
    Eeyore Guest
    The way some are constructed (notably Hirschmann), the contact spring is
    slightly banana shaped.
    Graham
    #7
  8. Don Lancaster
    mpm Guest
    > Many thanks,
    > rss:http://www.tinaja.com/whtnu.xml email:
    > Please visit my GURU's LAIR web site athttp://www.tinaja.com
    I have a few in inventory and would have to resort to measuring them,
    but that probably wouldn't help you very much.(?)
    I can tell you this: For dual plugs, there are definitely different
    hole spacings.
    The "familiar" Pamona-type dual plug has about 1" space post-to-post,
    but there's another size that's about 150% that spacing. I suspect
    this could be for a higher current banana plug (as they so seem to be
    "beefier"), but I can't swear to it.
    ITT-Pamona (or some spelling like that), might be a good place to
    Google for the datasheets, and hence size info. I think Tyco also
    makes them these days.., and probably a hundred Chinese outfits whose
    names I can't pronounce, let alone spell.
    EF Johnson also used to make these back in the 80's.
    Not sure if they still do, but might also be worth Googleing.
    -mpm
    mpm, Sep 17, 2007
    #8
  9. Don Lancaster
    mpm Guest
    > Many thanks,
    As for exact name: I believe the receptable end is called a "5-way
    binding post".
    (even though, I can come up with a lot more ways than that to connect
    to it! Ha!!)
    -mpm
    mpm, Sep 17, 2007
    #9
  10. Don Lancaster
    G Guest
    I call that the other plug. I pull out my old DEC patch cord sets, come in
    different colors, and I use the plugs from these when necessary. Thats all I
    know.
    greg
    >> Many thanks,
    >hole spacings.
    >-mpm
    G, Sep 17, 2007
    #10
  11. Don Lancaster
    JeffM Guest
    JeffM, Sep 17, 2007
    #11
  12. Don Lancaster
    Robert Baer Guest
    >>Many thanks,
    > hole spacings.
    > -mpm
    You are full of it.
    The (standard) Pomona banana pair spacing is 0.75 inches, *NOT* one
    inch!!
    This 3/4 spacing is seen on many DVMs and curve tracers (includes
    scope plugins).
    Use DigiKey, and get the datasheet for the Pomona 1269; *NO*
    dimensions are one inch!
    Robert Baer, Sep 18, 2007
    #12
  13. Don Lancaster
    Phil Hobbs Guest
    > Graham
    I suspect it's that the longitudinally split spring reminded someone of
    the way a banana peels.
    Cheers,
    Phil Hobbs
    Phil Hobbs, Sep 18, 2007
    #13
  14. Don Lancaster
    charrid Guest
    > >>Many thanks,
    > > hole spacings.
    > > -mpm
    > You are full of it.
    > inch!!
    > scope plugins).
    Right you are - 3/4 inch has been the banana pair spacing standard
    since I remember, maybe 50 years ago. Living in Europe, I wandered,
    why the pairs of electrical contacts, on all test equipment and even
    the public power network were spaced 19 mm and not the nice round 20
    or so. Then on moving to the US it hit me - 19mm is 3/4 inch! (well,
    ignore the 0.05mm). So who started it - Edison?, Westinghouse?...
    Rich
    charrid, Sep 19, 2007
    #14
  15. Don Lancaster
    colin Guest
    "Phil Hobbs" <> wrote in message
    news:dZPHi.2718$fz2.1704@trndny03...
    >> Graham
    oo I didnt think of that.
    there seems to be several different types with different spring arangements.
    in the electronics lab at school we used to have ones wich were basically a
    bunch of
    7 or so springy wires wich worked quite well
    Colin =^.^=
    colin, Sep 25, 2007
    #15
  16. Don Lancaster
    JeffM Guest
    >>>the contact spring is slightly banana shaped.
    >>reminded someone of the way a banana peels.
    >[which] were basically a bunch of 7 or so springy wires
    >[which] worked quite well
    > Colin =^.^=
    VERY well...and after seeing them once, I never saw them again
    --AND I never found a place to BUY any.
    JeffM, Sep 25, 2007
    #16
    1. Advertisements
Similar Threads
  1. Chris W
    Power Supply and banana plugs
    Chris W, Oct 30, 2005, in forum: Electronic Basics
    1,680
    John Fields
    Oct 31, 2005
  2. woodglass
    Where to purchase 3mm banana plugs in UK
    woodglass, Jul 20, 2006, in forum: Electronic Repair
    6
    1,305
  3. Kate Fights, I Cry
    Why 2 pin plugs? And why so many of them?
    Kate Fights, I Cry, May 7, 2005, in forum: Hobby Electronics
    16
    1,202
  4. woodglass
    3mm banana plugs
    woodglass, Jul 20, 2006, in forum: Electrical Engineering
    873
    woodglass
    Jul 20, 2006
  5. sizzle
    Why there is many different size of capasitors
    sizzle, Apr 19, 2012, in forum: General Electronics Chat
    8
    550
    shrtrnd
    Apr 20, 2012
Loading...
