How do you tune a multi-section helical bandpass filter?
Discussion in 'Electronic Design' started by mike, Apr 13, 2013.
  1. mike
    mike Guest
    A friend has asked me for help re-tuning a 4-section helical bandpass
    filter for the 2-meter ham band. It has no adjustments, so there
    won't be too many chances to recover from botched cutting.
    As I recall, there's considerable interaction between the sections.
    And since he's been bending on the resonators, the bandpass is
    quite out of whack. He wants to move it up 2 MHz. and restore
    the shape.
    A couple of decades ago, I had a procedure that involved measuring
    return loss.
    You disable (short out) all but the first resonator and set the dip
    of the curve here.
    Then enable the second section and put that dip there.
    So on till you get to the end.
    AS I recall, it got you very close in one pass.
    The second dip moved the first one, but the end result
    bandpass came out close to what you want.
    Problem is that I've misplaced the details of where "here"
    and "there" are. I've also misplaced much of my memory.
    Anybody remember the details of that technique?
    Or any technique that might be practical on a filter
    with
    no tuning adjustments and little chance to recover from
    mistakes?
    Thanks, mike
    mike, Apr 13, 2013
    #1
    1. Advertisements
  2. Jamie
    Jamie Guest
    > the shape.
    > return loss.
    > of the curve here.
    > with
    > mistakes?
    > Thanks, mike
    Service monitor? an all in one tool!
    Jamie
    Jamie, Apr 13, 2013
    #2
    1. Advertisements
  3. Joerg
    Joerg Guest
    > the shape.
    > return loss.
    > of the curve here.
    > with
    > mistakes?
    http://www.macomtech.com/static/PDFs/TechnicaArticles/Bandpass_Filter_tutorial2.pdf
    Design instructions but no tuning info per se. You could contact them
    and see if they have more. Then there is a book by Zverev. The best
    "McGyver style" alignment instruction I ever saw was in an ARRL handbook
    but I can't recall what year. You might want to ask in a ham radio group
    if someone still has it.
    http://www.rfcafe.com/references/electrical/helical-resonator.htm
    Not sure how far the Zverev book goes into tuning, I don't have it here.
    Regards, Joerg
    http://www.analogconsultants.com/
    Joerg, Apr 13, 2013
    #3
  4. Joerg
    Joerg Guest
    Jeff Liebermann wrote:
    > On Sat, 13 Apr 2013 08:08:48 -0700, Joerg <>
    > It does and thanks for jogging my failing memory. I it here.
    > "Handbook of Filter Synthesis" by Anatol I. Zverev. (1967)
    > 9.4 (P513 to 521) is on "Alignment of Helical Resonators" with
    > references to Dishal's method. It's too much to type here, but I can
    > scan the pages and post them if needed.
    > Google finds quite a few hits for Dishal's Method.
    In case Mike has IEEE library access:
    http://www.rfcurrent.com/wp-content/uploads/2010/12/Milton-Dishal-Publications-on-Filters.pdf
    Unfortunately I only have access to ultrasound and to aerospace
    publications.
    Regards, Joerg
    Joerg, Apr 13, 2013
    #4
  5. Joerg
    Joerg Guest
    >>> the shape.
    >>> return loss.
    >>> of the curve here.
    >>> with
    >>> mistakes?
    > Dishal's method. For high-Q filters, mistuned series sections look like
    > opens, and mistuned parallel sections look like shorts.
    > If you know what the resonant frequencies of the sections should be, you
    > can do that with a return loss bridge from each end.
    I tuned my last one using the "wet finger and a beer" method. Worked :)
    Regards, Joerg
    Joerg, Apr 13, 2013
    #5
  6. Guest
    > Is this out of a commercial radio?  If so, the maker and model please.
    > Perhaps a photo.  I can't imagine anyone shipping something like that
    > without tuning adjustments.
    > That's an understatement.  It's nothing but interactions.  Change one
    > thing and all the adjacent resonator tuning changes.
    > >the shape.
    > 2MHz / 146MHz = 1.4%
    > That should be easy without unwinding turns.
    > Any clue on the expected bandwidth?
    > >return loss.
    > >of the curve here.
    > Well, I'm not sure this is the correct procedure, but when I was
    > making 902-928Mhz solid cavity duplexers, I put a reflection
    > coefficient bridge on the input (no network analyzer available) and
    > swept for lowest return loss and best looking sweep.  As I vaguely
    > recall, it was 5 sections, with a total of 9 adjustments for tuning
    > and coupling:
    > <http://www.qsl.net/n9zia/wireless/pics/rtrn_loss_bridge.png>
    > <http://www.qsl.net/n9zia/wireless/rtrn_loss-pics.html>
    > <http://www.eagle-1st.com/eagle1st.nsf/17100001!OpenFrameSet>
    > <http://www.eagle-1st.com/eagle1st.nsf/10201000!OpenFrameSet>
    > I might have shorted out downstream sections to reduce the display
    > clutter, but there were no provisions for that inside the cavity.  So,
    > you start at the input, tune until the curve looks best.  Move on to
    > the next stage, and tune again.  Because the insertion loss of the
    > first stage is presumably very low when it's properly tuned, the 2nd
    > stage will have a big effect on the pattern.  However, if the
    > insertion loss through the first stage is high for some reason, tuning
    > the 2nd stage will have minimal effect on the displayed pattern. After
    > you're done making the return loss look pretty, check the overall
    > response.  If the return loss looks good, the bandpass response will
    > also look good.  However, don't bother trying to tune it for best
    > bandpass response.  It just doesn't work, which is probably what your
    > friend is struggling with.
    > If you have access to the helical resonators, you can see which stage
    > is responsible for which dip by waving a ferrite or brass rod near the
    > coil.
    > Yep.  That's it.  Everything affects everything else, but when you're
    > done tuning for best looking return loss, the bandpass response will
    > magically be perfect.
    > Try googling for repeater cavity duplexer tuning procedures.  It's
    > very similar, except that you're tuning a notch instead of a peak,
    > with the added bonus of overly critical, white knuckle, adjustments.
    > <http://www.amtronix.com/duplexertuning.htm>
    > This Agilent app note looks interesting, but I don't have time to read
    > the whole thing:
    > <http://literature.agilent.com/litweb/pdf/5968-5328E.pdf>
    > >with
    > >mistakes?
    > A digital camera is your friend.  Take lots of photos so you at least
    > have a chance to put Humpty Dumpty back together again.
    I dunno if it counts as an official method, but I've used a spectrum
    analyzer+tracking generator. Each resonator makes a "bump" in the
    passband; you can locate any given bump by grossly mistuning it (with
    a hand-held cap, for example), and watching the bump jump back and
    forth. Tune, repeat.
    Cheers,
    James Arthur
    , Apr 14, 2013
    #6
  7. mike
    mike Guest
    >>> the shape.
    >>> return loss.
    >>> of the curve here.
    >>> with
    >>> mistakes?
    > Cheers
    > Phil Hobbs
    Thanks, guys for the inputs.
    Dishal's method was what I was looking for.
    I'd found the HP article very interesting. I'll try the time-domain
    stuff next time I get an opportunity.
    I'm trying to do this remotely with someone with limited equipment.
    We'll see how it goes... ;-)
    The filter is
    http://www.dci.ca/pdf/DCI-145-2H.pdf
    Thanks, again, mike
    mike, Apr 14, 2013
    #7
    > >>> the shape.
    > >>> return loss.
    > >>> of the curve here.
    > >>> with
    > >>> mistakes?
    > >>http://www.macomtech.com/static/PDFs/TechnicaArticles/Bandpass_Filter....
    > > Cheers
    > > Phil Hobbs
    > The filter ishttp://www.dci.ca/pdf/DCI-145-2H.pdf
    > Thanks, again, mike
    Yeah, the (Dishal) method is the classic one for coupled resonator
    filters.
    Vizmuller has a book on helical filters, if you want something in
    addition to the Zverev material.
    Simon S Aysdie, May 7, 2013
    #8
    1. Advertisements
Similar Threads
  1. Rheilly Phoull
    Receiver bandpass filter questions.
    Rheilly Phoull, Aug 16, 2004, in forum: Electronic Basics
    6
    1,800
    Rubicon
    Aug 18, 2004
  2. TRABEM
    Butterworth bandpass filter question
    TRABEM, Sep 11, 2005, in forum: Electronic Components
    6
    1,216
    maxfoo
    Sep 13, 2005
  3. Georgy Onishchukov
    High-Q Bandpass Filter for 10 GHz
    Georgy Onishchukov, Nov 22, 2005, in forum: Electronic Components
    485
    Georgy Onishchukov
    Nov 22, 2005
  4. Syd
    5
    2,418
    Paul E. Schoen
    Sep 7, 2007
  5. Skybuck Flying
    5
    1,150
    Jeremy Linton
    Oct 19, 2008
Loading...
Share This Page
