How convert three-phase power to single-phase?
Discussion in 'Electrical Engineering' started by nntp.ext.ray.com, Aug 6, 2004.
  1. Hi,
    We're just moving into some new office space, and among the things that we
    inherited was some three-phase power. I haven't actually seen what the
    outlets look like, because the person who knows where it is isn't in this
    week, but I was kind of curious if there's any way that we can utilize any
    of that? We're a typical office environment, and all of our equipment
    (workstations, servers, etc.) are single-phase.
    To go from the three-phase power to single-phase, is it simply a matter of
    creating three single-phase outputs from the one three-phase (i.e.,
    A+neutral, B+neutral, and C+neutral), and then we can just plug
    (independent) equipment into each of the 3 single-phase outputs?
    Also, if we do that, from a power standpoint, do we end up with each of the
    single-phase outputs just being 1/3 of the power rating for the original
    three-phase power?
    As often happens, I'm probably asking what might seem like dumb/naive
    questions, but I'm really glad to have found this NG :)!
    Jim
    #1
    1. Advertisements
  2. nntp.ext.ray.com
    SQLit Guest
    "nntp.ext.ray.com" <> wrote in message
    news:TENQc.2$...
    > Hi,
    the
    > three-phase power?
    > Jim
    Your questions could be answered easily once the voltage is known.
    277-480, 120-208, 120-240, 377-600 these are all pretty common in north
    America.
    SQLit, Aug 6, 2004
    #2
    1. Advertisements
  3. nntp.ext.ray.com
    ohaya Guest
    > Larger UPS systems use three-phase power to keep the batteries charged
    > and power the DC to AC conversion. Some can be had that then produce
    > only single-phase, but most of them produce three phase back out. But
    > that's not a big deal as they can all be had with 120 volts.
    > It depends on what kind of three phase power you have. If you have what
    > is known as "208Y/120" then what you describe gets you 120 volts. But
    > if you have "240 delta center tapped", then A+N and C+N gets you 120 volts
    > but B+N gets you 208 volts. With 208Y/120, A+B or B+C or C+A gets you
    > 208 volts, while with 240 delta, A+B or B+C or C+A gets you 240 volts.
    > You could have another three phase system or voltage, in which case you
    > likely have a transformer or three changing the voltage so you can get
    > something at 120 volts. The power coming in from the electric company
    > could be in "480Y/277", "600Y/347" (primarily in Canada), "480 delta",
    > or some others. You would have multiple fuse boxes or breaker panels
    > to support the high and low voltage circuits in these cases.
    > If you have no transformers, you're probably getting one of the first
    > two I described. In some locations you might be getting "216Y/125" or
    > "220Y/127".
    > | three-phase power?
    > The way you just described, yes. A phase-to-phase connection, which gets
    > a different voltage, could have a higher capacity, since it is using two
    > of the phases and thus gets a higehr voltage with no reduction in current
    > (unless something else uses up some of the capacity).
    > If you have 208Y/120, you will most likely have circuits distributed over
    > the three phases in a circuit breaker panel designed to interleave the
    > three phases at every 3rd row. A 1-pole breaker gets 120 volts at the
    > phase it is plugged in to. A 2-pole breaker gets 208 volts (this would
    > have been 240 volts if it were single phase), but can be used with 120
    > volt loads. A 3-pole breaker gets the full three phases.
    > Whatever the amperage rating of a breaker is, you get that much power at
    > each of the poles/wires coming from it, however many that is. So if you
    > have a 20 amp 1-pole breaker, it can provide 2400 watts to 120 volt loads.
    > If you have a 20 amp 2-pole breaker, it can provide 4800 watts total to
    > 2 sets of 120 volt loads, or 4156 watts to 208 volt loads. A 20-amp
    > 3-pole breaker would let you have a total of 7200 watts for 3 sets of
    > 120 volt loads. 3 sets of 208 volt loads could use up to 4156 watts
    > each as long as the total of 2 does not exceed 4800 watts and the total
    > of all 3 does not exceed 7200 watts. And of course it can supply a real
    > three phase load up to 7200 watts. Electrical codes generally require
    > planned loads to not exceed 80% of capacity, so derate the above figures
    > to determine what you could plan for.
    > There are PDUs (power distribution units, or power strips) for computer
    > rack cabinets that plug into a three phase receptacle and provide three
    > sets of 120 volt outlets. If everything is rated 20 amps, you'd have
    > that 20 amps three times (16 amps maximum planned usage on each set).
    > You might want to check what you can, or are, doing with a UPS, before
    > jumping into how power is fed to your computers.
    > You're well ahead of most. The first big step is knowing you needed to
    > ask.
    > Try to find out what kind of three phase power it is, and the voltages,
    > so we can focus on your real options. Also, if you can, find out what
    > type(s) and size(s) of circuit breaker panel(s) you have.
    > One important thing to remember is that in a situation outside of an
    > owner-occupied single family house, virtually every jurisdiction does
    > require using the services of a licensed electrician to do any work.
    > People here can give you hints, advice, general direction, and explain
    > your options. But wiring the building is not a do-it-yourself project;
    > not even changing out a receptacle or light switch.
    Phil and SQLit,
    I'll have to get more details that you mentioned from someone else who
    isn't at the office today. Will post back next week sometime.
    And Phil, it's not my intention to do any of the actual wiring or
    whatever, I'm mainly trying to gain an understanding so I can be a
    little more knowledgeable about what our options might be.
    Thanks, and have a great weekend!
    Jim
    ohaya, Aug 6, 2004
    #3
  4. nntp.ext.ray.com
    Miles Guest
    "ohaya" <> wrote in message news:...
    matter of
    Depending on your jurisdiction (I don't think you said what country you're
    in, which sometimes makes a big difference) this could well be illegal. It
    may happen on construction sites with special splitter boards, but is
    probably not at all appropriate for an office environment. Systems of
    supply and protective arrangements (fuses, CBs etc) that may be safe and
    legal in one environment may not be, in another.
    volts
    The voltages and the way phase, neutral and earth wiring is arranged is also
    important. Your best solution is to call an electrician to check this out
    with certainty. Only then will you be sure that what you want to do is both
    safe and legal in your particular region.
    of the
    original
    > > | three-phase power?
    1/3 of the "power" rating yes, but exactly the same "current" rating. Which
    of these were you meaning?
    Newsgroups are not a safe place to be asking these sorts of questions unless
    you are already very knowledgeable about electrical distribution and safety.
    This is good advice, but you could still end up getting the wrong advice
    because the information you provide may be incomplete or even wrong, despite
    your own best efforts. Your comment about asking "someone who isn't at the
    office today" gives me considerable concern.
    If you get the wrong advice because the advisors don't have the full or
    accurate picture, it could cost you a whole lot more than just getting in an
    electrician to look at it in the first place. Any advice you get on here
    can only be based on what you tell people here, which is likely to be
    incomplete, and may be inaccurate if the people that you're talking to don't
    know as much as you thought they did.
    Electrical safety is too important to leave to chance. Sorry if this sounds
    negative, but for this sort of thing you need an electrician not a
    Newsgroup.
    My thoughts fwiw.
    Moving into a new office is always a great experience, starting from scratch
    is a great way of getting things organised in ways that you probably
    couldn't justify changing in an existing office. Good luck with your
    project. Hope it goes really well for you.
    Miles, Aug 7, 2004
    #4
    1. Advertisements
Similar Threads
  1. 3T39
    can a three phase motor work on single phase?
    3T39, Sep 29, 2006, in forum: Electronic Repair
    10
    2,639
    Homer J Simpson
    Sep 30, 2006
  2. max
    4
    2,461
    Spehro Pefhany
    Jul 23, 2007
  3. Ulysses
    240VAC single phase from three-phase?
    Ulysses, Mar 29, 2010, in forum: Home Power and Microgeneration
    25
    8,966
    Ulysses
    Apr 15, 2010
  4. dec335
    3,020
    dec335
    Oct 12, 2010
  5. kane
    three phase to single phase connections
    kane, Feb 25, 2013, in forum: General Electronics Chat
    586
Loading...
