How can I make a USB-Female to USB-Female cable?
Discussion in 'General Electronics Chat' started by omarbasha, Dec 19, 2011.
  1. omarbasha
    omarbasha
    Dec 19, 2011
    4
    Hello, what I'm trying to do is to make a cable that ends both sides with a USB-Female out of two cables that end with USB-Male from a side and a Female from the other side.. I have tried to cut both cables halves and reached the 4 wires inside then I tried to connect same wire colors with each other but what I found was that the first cable had Black - Green - Yellow - Blue inside and the other had Black - Green - Yellow - Brown.. So, I connected Black-Black, Green-Green, Yellow-Yellow and Blue-Brown and then I connected my phone which has Android OS from a side and a USB stick from the other side but it didn't work :( also tried with iPhone 4 and it didn't :( ..
    I also tried to connect a USB mouse but nothing worked.. Is there something wrong with the wiring? or do you have another method that I should try??
    Please!!! I suck at soldering so please don't tell me to solder, connecting wires will do it :)
    Your help is really appreciated and thanks in advance!! tc :D
    #1
    1. Advertisements
  2. omarbasha
    19,930
    1,286
    That's your problem right there.
    It just aint goinna work. Kinda like connecting 2 mice togther -- what do you expect to happen?
    (*steve*), Dec 19, 2011
    #2
    1. Advertisements
  3. omarbasha
    omarbasha
    Dec 19, 2011
    4
    Yeah, but I have seen online something like gender changer where you connect it to change the Male into Female.. And that's what I'm trying to do. So is there any possible way of doing it??
    #3
  4. omarbasha
    davelectronic VIP Member
    Dec 13, 2010
    1,079
    11
    UK . South east.
    Hi there. normaly there is a block in between the cable in and outs of the retail units you can purchase, i think this contains a circuit that isolates the two pairs of data lines, one usb moded lead is fine, so long as power demands are not exceded, but two bus lines connected will not work, i would make two seperate cables and use a usb hub for multiple usb connections.
    davelectronic, Dec 19, 2011
    #4
  5. omarbasha
    omarbasha
    Dec 19, 2011
    4
    OK, I have found that the problem was with the two cables, they weren't for data they were only for power.. So I will try different cables and report back.. And I have a question, about that block, should the new cable that has F-F ends contain that block? or should I get rid of it and cut before it?
    #5
  6. omarbasha
    Dec 13, 2010
    1,079
    11
    UK . South east.
    Pictures of what you plan to chop off before you do is an idea, i cant work out were your cut will be. :)
    #6
  7. omarbasha
    19,930
    1,286
    You do understand what you're doing, right?
    The female end of a normal type-A USB connector is supposed to provide power and also signals from a PC (or other controller) TO the device that you plug in.
    A female to female cable will connect 2 slave devices, each expecting power and control signals to be present on the cable, but neither providing it.
    If you have a device that can somehow act as either a master or a slave, then it is non-standard, and the wiring of the cable (especially the D+ and D- connections) may be straight or crossed over (who knows?).
    Your first step should be to determine that your device (what is it -- make and model) is "special" and that what you want to do is possible. Then try to determine if special connectors are required (I had a device which could operate as either master or slave, but it had a "special" connector with an extra pin). If you need a special connector, then no amount of wiring of normal connectors will do.
    #7
  8. omarbasha
    omarbasha
    Dec 19, 2011
    4
    Oh! Thank you very much I didn't know that.. I'm a noob :D so thanks again.. but now I'm trying to do a Micro USB to USB Female cable.. Is that possible? I've seen some people online doing it and according to what you are saying I think it should work.. Right? :)
    omarbasha, Dec 20, 2011
    #8
  9. omarbasha
    Windadct
    May 25, 2011
    24
    Hello Omarbasha:
    I have used "my cable mart" on line store for pretty much every type of cable I need - I just looked and did not see a Female to Female cable ( I believe you are not legally allowed to marry a female to a female (;-) )
    But they do seem to have some gender changers - you may also find a USB wall plate which may go female to female.
    Cheers,
    Paul
    Windadct, Dec 21, 2011
    #9
    1. Advertisements
Similar Threads
  1. William E Miller
    † Any suppliers of LCD glass pins?
    William E Miller, Mar 25, 2007, in forum: Electronic Components
    3
    517
    zwsdotcom@gmail.com
    Mar 27, 2007
  2. admin@ng2000.com
    Bulletin Board — Clubs (San Antonio Express-News)
    admin@ng2000.com, Feb 19, 2007, in forum: Misc Electronics
    557
    admin@ng2000.com
    Feb 19, 2007
  3. Drew Cutter
    6
    470
    Steve Spence
    Sep 14, 2005
  4. Don McKenzie
    Godzilla lives underneath Japan.
    Don McKenzie, Mar 14, 2011, in forum: Hobby Electronics
    26
    1,168
    jones
    Mar 27, 2011
  5. vick5821
    USB converter B type female to A type female
    vick5821, Aug 10, 2012, in forum: Electronic Projects
    30
    1,818
    gorgon
    Aug 11, 2012
Loading...
