home-brew vswr meter
Discussion in 'Electronic Basics' started by tom, Mar 18, 2005.
  1. tom
    tom Guest
    How minimal of circuit would be required to tell the difference between
    whether a load was inductively reactive or capacitively reactive at
    frequencies between 100mhz and 200mhz, and in the 5 to 100 watts range? A
    home made VSWR meter, for someone who doesn't have access to a store-bought
    one, basically.
    tom, Mar 18, 2005
    #1
    1. Advertisements
  2. tom
    Active8 Guest
    > one, basically.
    A VSWR meter won't tell you that, just that there's a mismatch.
    Start longer and prune for best VSWR. That's as simple as a couple
    of diodes, a meter, and some resistors and/or a pot - maybe a power
    range switch in leiu of the pot and a switch for forwared/reflected
    power. Additionally you'd need some type of directional coupler - 2
    parallel PCB traces... or a piece of insulated 24 AWG wire threaded
    under a length of coax braid... or a torroidal coil with the coax
    running through it. Unless you can get a crossed-needle display,
    you'll have to calculate the VSWR from the fwd/rev readings or just
    prune until the reflection are minimum. Knowing the VSWR would help
    you compare with other antennas.
    Oh, yeah. Is google's server down or something?
    Best Regards,
    Mike
    Active8, Mar 18, 2005
    #2
    1. Advertisements
  3. tom
    Fred Abse Guest
    > one, basically.
    If, by "VSWR meter", you mean the usual directionally sampled line
    arrangement, it won't tell you. What it actually measures is forward and
    reflected *current*, hence power. Whether the mismatched load is
    resistive, capacitive, or inductive, it neither knows nor cares.
    Google for "VHF bridge", and see if that gives you any ideas
    "Electricity is of two kinds, positive and negative. The difference
    is, I presume, that one comes a little more expensive, but is more
    durable; the other is a cheaper thing, but the moths get into it."
    (Stephen Leacock)
    Fred Abse, Mar 18, 2005
    #3
  4. tom
    tom Guest
    I'm not sure I understand your point Mike --- what do you mean by, "Oh,
    yeah. Is google's server down or something?"
    tom, Mar 18, 2005
    #4
  5. tom
    dB Guest
    "tom" <> wrote in message news:<Z3B_d.711235$Xk.444675@pd7tw3no>...
    > one, basically.
    A directional power meter (s.w.r. meter) will not differentiate
    between the two cases.
    dB, Mar 18, 2005
    #5
    1. Advertisements
Similar Threads
  1. Melodolic
    Home brew lab hotplate
    Melodolic, Aug 5, 2006, in forum: Electronic Basics
    20
    1,321
    Melodolic
    Aug 16, 2006
  2. Xanax
    RF Coils SMT or Home Brew
    Xanax, Oct 13, 2003, in forum: Electronic Design
    6
    798
    Tim Shoppa
    Oct 14, 2003
  3. Hammy
    Home brew PCB Advice
    Hammy, Jun 23, 2007, in forum: Electronic Basics
    12
    984
    Bob Masta
    Jun 25, 2007
  4. Replies:
    7
    1,217
    Graham
    Apr 21, 2008
  5. Den
    Home brew pogo pins?
    Den, Jun 20, 2008, in forum: Hobby Electronics
    5
    602
  6. tuppy
    lcd projector lamps, home brew?
    tuppy, Jul 14, 2008, in forum: Hobby Electronics
    3
    556
    Franc Zabkar
    Jul 16, 2008
  7. lynchaj
    home brew S-100 backplane project
    lynchaj, May 7, 2009, in forum: Electronic Design
    35
    1,189
    Ben Bradley
    Jun 12, 2009
  8. Steve
    Heating cable/wire for home brew
    Steve, Feb 16, 2004, in forum: Electrical Engineering
    373
    John Gilmer
    Feb 19, 2004
Loading...
