Hitachi Ultravision Model 50UX26B Intermittent Power Shut Down
Discussion in 'Electronic Repair' started by Angela D'Andrea, Nov 16, 2003.
  1. We have a Hitachi Ultravision Model 50UX26B projection TV that was
    made in July 1996. Lately it has been shutting itself off at random
    times. Hitting the power button on the remote usually turns it back
    on again (you actually need to hit the power button twice; the first
    time you hear the TV click and the second time it comes on).
    I don't think it is heat related because it's done it shortly after
    turning it on sometimes. Other times it will run for a long time
    without problem. The frequency of the intermittent shut downs has
    progressively increased from infrequent to several times an hour. Now,
    we can't power the TV on except occasionally and then it doesn't stay
    on for long. When we hit the power button the TV would click and the
    power light would flash on briefly but wouldn't stay on.
    Does anyone have any ideas what is wrong with our TV and how it can be
    fixed? We'ev found several other posts to Usenet where people have had
    the same problem, however, we haven't seen a definitive fix, and no
    one has followed up to say whether the advised fixes actually worked.
    Of course, we are hesitant to call a repair service and spend a pile
    of money only to have the problem continue...
    Thanks for you help.
    Angela D'Andrea
    Austin, Texas
    #1
    1. Advertisements
  2. James Sweet
    James Sweet Guest
    "Angela D'Andrea" <> wrote in message
    news:...
    > Angela D'Andrea
    > Austin, Texas
    It's probably just a cracked solder joint in the power supply or horizontal
    deflection system, if the picture is good I suggest calling a pro unless you
    have good soldering skills and are able to identify subsystems by looking at
    the boards to know where to look for the bad joints. The repair should be
    fairly straightforward for an experienced tech though.
    James Sweet, Nov 16, 2003
    #2
    1. Advertisements
  3. AP63 Chassis
    Inspect all electrolytic capacitors for leakage and ESR, resolder the common
    areas that are problems. Check for defective components and bad solder
    connections:
    I601
    D936
    Q003
    I901
    I907
    R913
    I401
    T701
    T901
    L708
    and a few dozen more parts. Troubleshooting would narrow it down to the
    problem area more effectively.
    Or call a tech that has some experience with these sets.
    Leonard Caillouet
    "James Sweet" <> wrote in message
    news:JbQtb.169237$ao4.547152@attbi_s51...
    > news:...
    > > Angela D'Andrea
    > > Austin, Texas
    horizontal
    you
    at
    Leonard Caillouet, Nov 17, 2003
    #3
  4. Bob Shuman
    Bob Shuman Guest
    Angela,
    I have the same model manufactured at approximately the same time frame. We
    have not experienced the problem you describe, but I did have the main power
    on/off relay go bad so it had to be replaced. I only mention this since it
    was a pretty easy fix and if you can't find any cold solder joints on the
    main
    power board you may want to check the resistance of the relay contacts
    themselves (mine would stick closed after the set was turned off, but I
    could
    imagine that they could just as easily become resistive and have the
    potential to
    fail in the manner you describe as well).
    After dismissing cold solder and checking the other components Leonard
    cited, I'd look at the relay. Hope you can get this fixed. We still love
    our set. If you need a schematic, let me know as I think I have the service
    manual somewhere.
    news:...
    > Angela D'Andrea
    > Austin, Texas
    Bob Shuman, Nov 17, 2003
    #4
  5. I too have the same model television. It seems this is the most commo
    problem for these units. On mine however, you can hear the tv clic
    when you press the power button. I have removed the back and the fus
    is still good. In fact the red indicator light (on the circuit boar
    inside tv) comes on when you turn the tv on. Neither the outsid
    indicator light or the screen however come on. Its as if the tv i
    turning partially on, but not all the way. Any advice would be helpful
    I just dont see the reason to take it to a repair shop. I'd rather se
    if I can get it fixed myself. And if anyone has the service manual fo
    it... I would appreciate that too. Thanks
    Matt Walker (),
    Lubbock TX
    Bob Shuman Wrote:
    > Angela,
    > frame. We
    > power
    > since it
    > the
    > main
    > I
    > could
    > potential to
    > love
    > service
    > manual somewhere.
    > Bob
    > "Angela D'Andrea" wrote in message
    > news:...-
    > Angela D'Andrea
    > Austin, Texas
    oldskoolplaya806
    oldskoolplaya806, Feb 21, 2006
    #5
  6. This is a common scenario.
    Careful! The main filter caps bite hard on these!
    Text pasted from WinSTIPS 2.0
    http://www.ServiceSoftware.com
    HITACHI 50UX26B
    Shuts Down Randomly. May Take 2 Hours Or 2 Minutes.
    Jeff Stielau : 2/19/03 : Shoreline Electronics
    After Pulling The Chassis & Resolder All Heatsinked Parts & Connectors (
    None Looked Suspicious To Begin With) Problem Still Existed.
    Replacing The Strm6511 (Ici1901) Fixed The Set. Change The 2 Small
    Electrolytics Next To It For Good Measure.
    Jeff Stielau
    Shoreline Electronics Repair
    344 East Main Street
    Clinton,CT 06413
    860-399-1861
    860-664-3535 (fax)
    "oldskoolplaya806" <> wrote in message
    news:eek:...
    > I too have the same model television. It seems this is the most common
    > problem for these units. On mine however, you can hear the tv click
    > when you press the power button. I have removed the back and the fuse
    > is still good. In fact the red indicator light (on the circuit board
    > inside tv) comes on when you turn the tv on. Neither the outside
    > indicator light or the screen however come on. Its as if the tv is
    > turning partially on, but not all the way. Any advice would be helpful.
    > I just dont see the reason to take it to a repair shop. I'd rather see
    > if I can get it fixed myself. And if anyone has the service manual for
    > Matt Walker (),
    > Lubbock TX
    > Bob Shuman Wrote:
    >> Angela,
    >> frame. We
    >> power
    >> since it
    >> the
    >> main
    >> I
    >> could
    >> potential to
    >> love
    >> service
    >> manual somewhere.
    >> Bob
    >> news:...-
    >> Angela D'Andrea
    >> Austin, Texas-
    > oldskoolplaya806
    Shoreline Electronics, Feb 21, 2006
    #6
    1. Advertisements
Similar Threads
  1. rouleau
    Hitachi 31GX31BC H.V. shut down
    rouleau, Aug 8, 2003, in forum: Electronic Repair
    440
    David
    Aug 9, 2003
  2. Michael & Amy Harris
    Hitachi Ultravision convergence
    Michael & Amy Harris, Oct 8, 2003, in forum: Electronic Repair
    1,756
    Leonard Caillouet
    Oct 9, 2003
  3. Hitachi 50UX26B
    , Jan 31, 2007, in forum: Electronic Repair
    4
    895
  4. Pete Dragovich
    Hitachi 50" 50UX26B
    Pete Dragovich, Feb 6, 2007, in forum: Electronic Repair
    490
  5. Chris F.
    Westinghouse TX-52F480S Intermittent Shut Down
    Chris F., Jan 11, 2011, in forum: Electronic Repair
    430
    Chris F.
    Jan 13, 2011
Loading...
Share This Page
