Hitachi TV keeps switching itself off
Discussion in 'Electronic Repair' started by John, Oct 14, 2003.
  1. John
    John Guest
    Hi, I have a 4 year-old Hitachi C28W511TN widescreen TV. Recently, and only
    75% of the time, when I switch it on, it turns itself off about a minute
    later.
    Strangely it doesn't make the familiar click and fizz inside the box that I
    hear when I turn it off with the remote, it almost switches the tube off
    'silently' (like a PC monitor going into blank screensaver mode) and there
    appears to be a brief moment just before it does this when it 'thinks about
    it' as the picture rapidly disappears once, then reappears, then switches
    off (I think! - it's all very fast).
    When I press ON on the remote, it doesn't 'click' on, the picture just comes
    back silently without a standard 'I'm turning on' click.
    It then turns off again 30 seconds later!
    I repeat this 2-7 times, then it stays on for the rest of the night until I
    choose to turn it off. It's like it gives up fighting with me and just
    stays on, displaying a perfect picture.
    It's not an IR issue as when I turn off with IR, I hear a click and fizz in
    the box.
    Any ideas? Help much appreciated. I'm tech-savvy and would like to attempt
    a home repair if you can advise a simple part I need to replace.
    John
    John, Oct 14, 2003
    #1
    1. Advertisements
  2. John
    David Guest
    Could be a failing capacitor high in ESR, start by checking electrolytics
    with your ESR meter in critical circuit areas like the power supply, scan
    derived voltages, etc. Also look for failing connections.
    David
    John <> wrote in message
    news:ENYib.4$...
    only
    > later.
    I
    about
    comes
    I
    in
    > the box.
    attempt
    > John
    David, Oct 15, 2003
    #2
    1. Advertisements
  3. John
    John Guest
    Hmm, thanks, but I'm not THAT tech savvy! :( Anything simply I could
    replace that would definitely be the cause of this?
    "David" <> wrote in message
    news:...
    > David
    > news:ENYib.4$...
    > only
    > > later.
    that
    > I
    there
    > about
    switches
    > comes
    until
    > I
    > in
    > > the box.
    > attempt
    > > John
    John, Oct 15, 2003
    #3
  4. John
    Jerry G. Guest
    This can be too complex, and it can be one or several of many parts.
    Usually the capacitors in the power supply and scan circuits can cause this.
    You would have to troubleshoot the set to locate the defective parts. The
    use of an ESR meter will find the bad caps to start with.
    If you are not trained, and equipped to service TV sets, I would suggest you
    call in a service centre that can do a proper safe repair. There are many
    safety issues when servicing TV sets. You can be badly injured, and or cause
    a fire hazard if you don't know what you are doing.
    Greetings,
    Jerry Greenberg GLG Technologies GLG
    WebPage http://www.zoom-one.com
    Electronics http://www.zoom-one.com/electron.htm
    "John" <> wrote in message
    news:1h8jb.7377$...
    news:...
    > David
    > news:ENYib.4$...
    > only
    > > later.
    that
    > I
    there
    > about
    switches
    > comes
    until
    > I
    > in
    > > the box.
    > attempt
    > > John
    Jerry G., Oct 15, 2003
    #4
    1. Advertisements
Similar Threads
  1. Geoff
    TV keeps putting itself into standby mode
    Geoff, Jun 8, 2004, in forum: Electronic Repair
    941
    Jerry G.
    Jun 8, 2004
  2. Hitachi turns itself off
    , Aug 6, 2005, in forum: Electronic Repair
    9
    1,301
    Thirsty
    Aug 20, 2005
  3. Brett Pierce
    KDS VS-7e 17" CRT keeps turning itself off
    Brett Pierce, Jan 16, 2006, in forum: Electronic Repair
    543
    Bob Shuman
    Jan 16, 2006
  4. edsolo
    Matsui TV switching itself off
    edsolo, Jan 31, 2011, in forum: Electronics Repair
    3
    2,633
    shrtrnd
    Feb 11, 2011
  5. steve75
    3
    497
    elebish
    Jan 9, 2015
Loading...
