Hf filter for ballast
Discussion in 'Electronic Design' started by JohnS, Oct 17, 2006.
  1. JohnS
    JohnS Guest
    Hi Guys
    Anyone point me in the right direction. I am playing with a 300 watt ballast
    for an amalgam UV lamp and the screened cable from ballast to lamp is
    radiating excessively in the region 30-40MHz. I have tried the usual ferrite
    beads at the ballast O/P but have not had much success. Can anyone suggest a
    reasonable low pass filter cutting off at about 20MHz that can handle lamp
    currents of 3A, or a good site with some design data to give say 12db
    attenuation. I am more used to LC filters in lf range with equal impedances.
    JohnS
    JohnS, Oct 17, 2006
    #1
    1. Advertisements
  2. Joerg
    Joerg Guest
    Hello John,
    Here is a free (ad-supported) program to calculate LC filters in the HF
    range:
    http://www.aade.com/filter.htm
    Have you considered common mode measures? For example, looping the cable
    as a whole a few times through a big #43 ferrite toroid at each end?
    Regards, Joerg
    http://www.analogconsultants.com
    Joerg, Oct 17, 2006
    #2
    1. Advertisements
  3. JohnS
    JohnS Guest
    Hi Joerg
    Yes, I tried individual ferrites and common mode, it seemed to change the
    points at which the radiation peaked but did not suppress over the range.
    Just about also to try a foil and braid screened cable, as teh original was
    just braid, but it seems that hf ballast manufacturer's in general are not
    paying much respect to EMC on the output of their ballasts. It is annoying
    bacause I was paying for test house time.
    Thanks for the web site suggestion
    JohnS
    "Joerg" <> wrote in message
    news:BL9Zg.18723$...
    > Hello John,
    >> ballast for an amalgam UV lamp and the screened cable from ballast to
    >> lamp is radiating excessively in the region 30-40MHz. I have tried the
    >> usual ferrite beads at the ballast O/P but have not had much success. Can
    >> anyone suggest a reasonable low pass filter cutting off at about 20MHz
    >> that can handle lamp currents of 3A, or a good site with some design data
    >> to give say 12db attenuation. I am more used to LC filters in lf range
    > range:
    > Regards, Joerg
    JohnS, Oct 17, 2006
    #3
  4. Joerg
    Joerg Guest
    Hello John,
    That's what happened to most (new) clients of mine, blowing through the
    first EMC lab visit and fail. But not all is lost because then you have
    the baseline plots. You can rent an antenna set and possibly an analyzer
    if there is none in the lab and experiment on your own until you reach
    enough margin. There is never a guarantee but this greatly increase the
    confidence level for the next round at the EMC lab.
    Shielding will help but only if there is a tight shield connection at
    the generator, ballast and preferably at least the frame of the load.
    For the ferrites make sure it's indeed #43 material or similar. #77
    looks deceptively similar. Unfortunately what I find a lot during visits
    is that all the ferrites have been placed in bins and after a few trial
    and error sessions the cores of same sizes are often mixed. The only way
    to re-separate is an inductance meter, some wire and lots of time.
    Regards, Joerg
    Joerg, Oct 17, 2006
    #4
  5. Jake
    Jake Guest
    On Tue, 17 Oct 2006 21:19:27 GMT, Joerg
    For what it is worth.
    Buy some cans of spray enamel and paint them after sorting. Do the same
    with new stock.
    Small beads and cores can be strug on wire and dipped in a thinned mix from
    a can of paint.
    You can even use this for threaded cores.
    Jake.
    Jake, Oct 18, 2006
    #5
  6. Joerg
    Joerg Guest
    Hello Jake,
    > with new stock.
    > a can of paint.
    I usually write the material code onto them with a silver or gold
    indelible ink pen. Then I don't have to remember colors. But those pens
    dry out quite quickly.
    Nail polish works as well but my wife wouldn't appreciate that ;-)
    Regards, Joerg
    Joerg, Oct 18, 2006
    #6
    1. Advertisements
Similar Threads
  1. eeh
    T LP filter and RC LP filter
    eeh, Apr 1, 2005, in forum: Electronic Basics
    622
  2. Tom Becker
    PLL input filter vs. loop filter
    Tom Becker, Apr 9, 2006, in forum: Electronic Design
    44
    2,431
    Tom Becker
    Apr 19, 2006
  3. Pedro
    Using a fluro ballast as a Filter choke?
    Pedro, Nov 1, 2004, in forum: Electronic Repair
    968
    jhill
    Nov 3, 2004
  4. KeeperOfLogic
    Volume (decibel) Low-pass filter (NOT frequency filter)
    KeeperOfLogic, Oct 21, 2006, in forum: Electronic Basics
    9
    1,565
    Bob Masta
    Oct 22, 2006
  5. mercer7
    10
    2,170
    Homer J Simpson
    Nov 27, 2006
Loading...
