help needed to repair an electric blanket heat selector. Fuse blown?
Discussion in 'Electronics Repair' started by nixy, Jan 26, 2012.
  1. nixy
    nixy
    Jan 26, 2012
    Hi all. I'm hoping that someone on here might be able to help me out with the repair of my new electric blanket heat selecter. I bought the blanket just before Christmas. I've not used it much but last night it died. Normaly I'd just give it back but I've lost the recipt.
    I suspect it has overheated and blown a fuse on the circiut board. I have checked for power to the switch and done a continuity test on the blanket it's self with my meter which is ok.
    so it must be the board. Apart from that the selector has 4 heat settings.
    Can anyone help me with this?
    Jeff
    nixy, Jan 26, 2012
    #1
    1. Advertisements
  2. (*steve*)
    19,490
    1,150
    I suspect that "something" between the two resistors covered in all the white gunk.
    Does it look like a fuse?
    Does it have continuity?
    (*steve*), Jan 27, 2012
    #2
    1. Advertisements
  3. shrtrnd
    shrtrnd VIP Member
    Jan 15, 2010
    2,696
    217
    Arizona
    Yeah, I'd check under the white gunk, but what little I can see of it, makes me think
    it's another resistor.
    You shouldda taken the thing back to the store even without a receipt and taken a
    shot at returning it.
    How do the connector pins/sockets from the controller to the blanket look?
    Did your washing maching maybe break a connection to the heating elements in the
    blanket?
    Are any of those wires fusible links?
    The diodes and resistors on the board are easy to check for resistance, I'm just trying
    to think of what else might be causing the problem, if the board looks ok to your meter.
    Any suspicious kinks in the wiring to the board, that might be breaks in the wire?
    shrtrnd, Jan 27, 2012
    #3
  4. nixy
    nixy
    Jan 26, 2012
    Hi and thanks for your help so far. I can report that the blue things under the white gunk work with a continuity test. However with the same test a few of those little black things pass don't and a few do not. Could it be these? What are they?
    No it's never been washed and the cable/control detach anyway. The controler is a slider with 4 stops. I haven't done any resistance testing. I do have a meter but dunno how to read off the values
    BTW. I got a flat no way from the store when i asked for help.
    nixy, Jan 28, 2012
    #4
  5. (*steve*)
    19,490
    1,150
    Those black things are diodes and they should "pass" the continuity test one way but not the other way.
    Other elements in the circuit may conspire to affect the readings though.
    (*steve*), Jan 28, 2012
    #5
  6. shrtrnd
    shrtrnd VIP Member
    Jan 15, 2010
    2,696
    217
    Arizona
    You can check that slider switch for continuity too.
    Maybe an open circuit there?
    shrtrnd, Jan 30, 2012
    #6
  7. JMW
    JMW
    Jan 30, 2012
    80
    Why are you trying to fix a brand new product? You will void the warranty, if you haven't already. In general, I have found if a product works for 90 days, it will function for a good period of time, unless abused.
    JMW, Feb 2, 2012
    #7
  8. shrtrnd
    shrtrnd VIP Member
    Jan 15, 2010
    2,696
    217
    Arizona
    There's a possibility.
    The store refused you, but if you've still got the paperwork that came in the package
    with the blanket (and even if you don't), maybe you can contact the manufacturer
    and try to get the blanket fixed or replaced.
    The store warranty is very limited, but the blanket manufacturer warranty should be
    much longer.
    shrtrnd, Feb 2, 2012
    #8
    1. Advertisements
Similar Threads
  1. Eric R Snow
    Running electric blanket on DC?
    Eric R Snow, Dec 3, 2004, in forum: Electronic Basics
    13
    1,353
    Eric R Snow
    Dec 9, 2004
  2. mike
    680
  3. Man-wai Chang
    Fuse: fast blown vs slow blown
    Man-wai Chang, May 31, 2011, in forum: Electronic Basics
    59
    6,369
    Winston
    Jun 4, 2011
  4. Man-wai Chang
    Man-wai Chang, May 31, 2011, in forum: Electronic Repair
    50
    3,196
    Winston
    Jun 4, 2011
  5. CDuncan
    Electric Blanket Repair - Perfect Fit Controller
    CDuncan, Dec 25, 2012, in forum: Electronics Repair
    5,726
    Valerie Lathrop
    Jan 12, 2014
Loading...
