Help in opening LCD monitor
Discussion in 'General Electronics Chat' started by softdown, Jan 26, 2009.
  1. softdown
    softdown
    Jan 26, 2009
    4
    How can I open a LCD monitor (model Belinea 101920) ?
    After unscrewing all the visible screws, I could remove the "foot" but the case still doesn't open.
    On the net, sometimes a case opening key is mentioned. Indeed, there is a hole in the back of the case with a "K" inscription (maybe stands for "key").
    Where do I buy such a key ? I tried Google, but without success ?
    #1
    1. Advertisements
  2. softdown
    softdown
    Jan 26, 2009
    4
    No replies ? :(
    No one ever opened a LCD monitor ?
    #2
    1. Advertisements
  3. softdown
    ccm
    Nov 23, 2009
    I hope you already fixed your monitor by now.
    Anyway, the little K and lock symbol has nothing to do with opening up the back panel. the lock symbol indicates the hole may be used for security. for instance, at a school or library, the hole will be used to pull a wire through it and secure it to a table or lock.
    As for opening the monitor, I have not done that before, BUT, I frequently read that after the screws are removed, you just have to carefully pry it open using a flathead screwdriver. Wedge the flathead into the seams.
    Look for clips along the seams.
    ccm, Nov 23, 2009
    #3
    1. Advertisements
Similar Threads
  1. Tom
    Opening a Sony G500 Monitor
    Tom, Jul 12, 2004, in forum: Electronic Repair
    627
    aplus@optonline.net
    Jul 13, 2004
  2. Tom
    523
  3. herb_k@mail.com
    opening KDS monitor case
    herb_k@mail.com, Nov 21, 2006, in forum: Electronic Repair
    4
    696
    Shawn D'Alimonte
    Dec 13, 2006
  4. zorgdroid
    1,987
    zorgdroid
    Feb 17, 2008
  5. (*steve*)
    Help opening Acer AL1916 monitor
    (*steve*), Feb 5, 2010, in forum: Electronics Repair
    14
    8,128
    (*steve*)
    Apr 21, 2010
Loading...
