GE Microwave switch
Discussion in 'Electronic Repair' started by Chris, Apr 27, 2004.
  1. Chris
    Chris Guest
    Greetings,
    I am in the midst of troubleshooting a GE microwave, which appears to
    have a bad switch in the protection circuitry. The switch is marked
    VP-533A-OF. It appears that there is a hole melted in the switch and it
    will only work when partially pressed down but it opens when fully engaged.
    This results in the microwave exciter and fan not operating, but the timer
    counts down normally and the light comes on. I was curious if simply
    replacing the switch should correct the problem (or will it fail again?),
    and where I might be able to find one at a reasonable price. I am willing
    to go online or look locally (Cincinnati/Dayton/Columbus) if that is
    possible as well.
    Chris
    Chris, Apr 27, 2004
    #1
    1. Advertisements
  2. "Chris" <> writes:
    > Greetings,
    > possible as well.
    See if there's a blown fuse to the microwave exciter. I'm guessing that
    switch is there to short across the line and blow the fuse if the
    interlocks aren't activated in the correct sequence. In your case,
    the switch may have failed first though. Is there a circuit diagram
    inside?
    --- sam | Sci.Electronics.Repair FAQ Home Page: http://www.repairfaq.org/
    | Mirror Site Info: http://www.repairfaq.org/REPAIR/F_mirror.html
    Important: The email address in this message header may no longer work. To
    contact me, please use the feedback form on the S.E.R FAQ Web sites.
    Sam Goldwasser, Apr 27, 2004
    #2
    1. Advertisements
Similar Threads
  1. Replies:
    422
  2. Information on microwave transfer switch
    , Sep 12, 2005, in forum: Electronic Components
    343
  3. Replies:
    3
    370
    Richard the Dreaded Libertarian
    Sep 13, 2005
  4. Information on microwave transfer switch
    , Sep 12, 2005, in forum: Electronic Equipment
    424
  5. Soyrunner
    Samsung Microwave & GE Microwave oven
    Soyrunner, Sep 20, 2004, in forum: Electronic Repair
    5
    1,989
    Sam Goldwasser
    Mar 15, 2005
Loading...
Share This Page
