GE Microwave popping and crackling
Discussion in 'Electronic Repair' started by Mike L., Jul 1, 2005.
  1. Mike L.
    Mike L. Guest
    I had recently found a GE microwave by the side of the road. It is in a very
    nice looking' condition, date Jan.2002 1 year warranty model #JES831PWF001.
    My second thought was this unit is to nice looking to not have a trouble.
    Well, I was right, when I plugged it in the first thing I noticed was that
    it had to initialize its smart board, ok fine. Then a message came across
    the digital display quoting the word "RESET"(Later I find out what this word
    means). So, now I'm setting the clock and everything seems OK at this point.
    Now here is the fun part of my post. I go to punch in some numbers, you know
    to run the unit and see how it works. The very first number I punch in is
    the 1 pad and the thing starts up, runs automatically. I don't get to pad in
    any other pads, but then after a few seconds of running it starts popping,
    crackling and voltage-current drain through out the house. I quickly unplug
    the unit. (In the inside -cooking area- of the unit is a smart chard area
    about a half inch in diameter around 2 by 4 at the top of the metal plate).
    <----Magnetron
    I haven't taking any reading checks yet at this time. I have opened the case
    and found the service sheet in an envelope. After looking it over I found a
    section that states that the display quote from earlier in my post "RESET"
    means power failure.
    I have several questions, but here is the first one what is a magnetron?
    Stupid question I know! There is RF frequency statement by the model # that
    says RF 2450MHz; will this frequency interfere with my 2.4GHz wireless
    router?
    What is causing the popping, crackling? If I was not in-depth enough please
    let me know.
    I will also scan the service sheet in a day or two in PDF format and post it
    with the same subject heading.
    Thanks for your time that it took to read through my post.
    Mike L.
    #1
    1. Advertisements
    > magnetron? Stupid question I know! There is RF frequency statement by
    > the model # that says RF 2450MHz; will this frequency interfere with
    > my 2.4GHz wireless router?
    This is a troll, right?
    Travis Jordan, Jul 1, 2005
    #2
    1. Advertisements
  3. Inty
    Inty Guest
    "Travis Jordan" <> ha scritto nel messaggio
    news:n_gxe.152973$...
    Why it's a troll ?
    I.
    Inty, Jul 1, 2005
    #3
  4. "Travis Jordan" <> writes:
    If not, I suggest he go read the Microwave Oven Repair Guide at the
    site below, especially the SAFETY info.
    --- sam | Sci.Electronics.Repair FAQ Mirror: http://repairfaq.ece.drexel.edu/
    Repair | Main Table of Contents: http://repairfaq.ece.drexel.edu/REPAIR/
    +Lasers | Sam's Laser FAQ: http://repairfaq.ece.drexel.edu/sam/lasersam.htm
    | Mirror Sites: http://repairfaq.ece.drexel.edu/REPAIR/F_mirror.html
    Note: These links are hopefully temporary until we can sort out the excessive
    traffic on Repairfaq.org.
    ignored unless my full name is included in the subject line. Or, you can
    contact me via the Feedback Form in the FAQs.
    Sam Goldwasser, Jul 2, 2005
    #4
  5. James Sweet
    James Sweet Guest
    that
    > router?
    A magnetron is the vacuum tube which generates the microwave energy. 2.4 GHz
    would certainly interfere if it were not contained but microwaves are
    usually shielded well enough that this isn't a problem. All consumer
    microwave ovens run at this frequency.
    please
    > let me know.
    The paint inside the cavity has been damaged and it's now arcing just as it
    would if you stuck a fork in there. Sometimes this can be repaired if you
    clean it very well, sand off any oxidation and then touch it up with
    microwave oven cavity paint. You'd want to check the condition of the
    waveguide though to make sure it isn't damaged. Microwaves ovens are simple,
    but they can also be deadly to work on, please read the repair FAQ before
    poking around in there.
    it
    > Mike L.
    James Sweet, Jul 2, 2005
    #5
  6. Mike L.
    Mike L. Guest
    Mr. Sweet
    Thank you for your positive input on my original post. I'm a beginning
    repair technician and any help in clarifying my misunderstanding is
    appreciated.(Mr. Sweet)
    (others)
    I have a CET and just because I don't know all the jargon as of yet does
    not mean I don't have feelings. For the one who stated "troll" a simple
    saying to me like "to much side talk just the problem would be fine" : this
    would had been more professional don't you think!
    I do already read through the repair FAQ's and quit frequently I should
    state. It is very well in-depth.
    It is also a start home page on one of my many computers.
    (question to anyone)
    For this troll thing is this just a polite way of saying "screw off, your
    not part of the click so we're not going to help you with your legit
    problem"
    I look forward to coming to this news group reading a lot, I mean a lot of
    these post.
    I am very offended by their "troll" statement so whats up with that?
    Happy 4th to everyone...
    Mike L.
    "James Sweet" <> wrote in message
    news:FRkxe.435$3Y3.147@trnddc09...
    > that
    > > router?
    GHz
    > please
    > > let me know.
    it
    simple,
    post
    > it
    > > Mike L.
    Mike L., Jul 2, 2005
    #6
  7. NSM
    NSM Guest
    "Mike L." <> wrote in message
    news:6ynxe.23814$mC.9780@okepread07...
    > problem"
    Don't post PDFs to this group - it is not a binary group.
    N
    NSM, Jul 2, 2005
    #7
  8. John T
    John T Guest
    Take no notice Mike. These are the morons we normally call cyber bullies -
    they speak and behave in a manner that they don't normally do offline (and
    thank christ for that!).
    As someone else stated, microwaves can be a rather dangerous thing to work
    on. Your best bet if you really want one would be to get one new. If you
    just wanna tinker with it, by all means, but exercise some caution.
    Welcome to the group anyway.
    John
    John T, Jul 2, 2005
    #8
    > bullies - they speak and behave in a manner that they don't normally
    > do offline (and thank christ for that!).
    I'm not a cyber bully, and I speak and behave virtually the same manner
    (no pun intended) online and offline. Google on my posts if you doubt
    that.
    I seriously thought the OP was a troll. After all, who would ask in a
    sci.* newsgroup "I have several questions, but here is the first one
    that says RF 2450MHz; will this frequency interfere with my 2.4GHz
    wireless router?"
    A few minutes with Google would answer both these questions without
    wasting the newsgroup's bandwidth.
    Travis Jordan, Jul 2, 2005
    #9
  10. John T
    John T Guest
    Hi Travis,
    Yep, understood, and certainly valid points in your post. All I'm saying is
    that we should give 'em a go every once in a while, instead of an NG full of
    people ready to pounce on someone who, granted, probably *should* have
    checked Google prior to posting.
    No offence meant, and I'm certainly not trying to be disrespectful to you,
    so apologies if it sounded like that.
    John
    John T, Jul 2, 2005
    #10
  11. Inty
    Inty Guest
    news:wEwxe.61141$...
    He doesn't know what's it : why he can't ask ? If you hate questions of this
    type, please don't read them, but don't read, and don't reply. I don't think
    you are a bullie, because I lurked this newsgroup for months and seen your
    replyes that aren't replyes from a bully but serious replyes !
    > wireless router?"
    Eheh, this is a ROTFL question ! If the microwave goes on 2.45Ghz and the
    router goes on 2.4Ghz it's obvioua that a non-shielded owen makes
    interference. But because *all* the owens are shielded, there isn't any
    problem !
    Only 3k. What's 3k ?
    I.
    Inty, Jul 2, 2005
    #11
  12. John T wrote:
    > Hi Travis,
    > saying is that we should give 'em a go every once in a while, instead
    > of an NG full of people ready to pounce on someone who, granted,
    > probably *should* have checked Google prior to posting.
    > you, so apologies if it sounded like that.
    No problem, John...and no apology required. Thanks for the follow up.
    Have a great 4th.
    Travis
    #12
  13. On Fri, 1 Jul 2005 22:07:39 -0500, "Mike L." <>
    wrote:
    >Mr. Sweet
    >(others)
    Respectfully...how did you get a CET without knowing what a magnetron
    is?
    Tom
    Tom MacIntyre, Jul 2, 2005
    #13
  14. On Fri, 01 Jul 2005 19:40:03 GMT, "Travis Jordan" <>
    Asking an electronics repair question on an electronics repair group?
    How does that make it a troll?
    Tom
    #14
  15. On Sat, 02 Jul 2005 13:29:00 GMT, "Travis Jordan" <>
    >that.
    >wireless router?"
    By this logic most posts here are wasting bandwidth.
    Tom
    #15
  16. Inty
    Inty Guest
    "Tom MacIntyre" <> ha scritto nel messaggio
    news:...
    > is?
    If you read Mike's first post he said that the CET was found in an envelope
    putted in the owen ;-)
    I.
    Inty, Jul 2, 2005
    #16
  17. NSM
    NSM Guest
    "Inty" <> wrote in message
    news:QTyxe.104886$...
    > news:...
    > > is?
    envelope
    Perhaps it was an envelope full of microwave popcorn? Explaining the
    'popping and crackling'?
    N
    NSM, Jul 2, 2005
    #17
  18. NSM
    NSM Guest
    "John T" <> wrote in message
    news:42c676cd$0$20027$...
    None of which changes this into a binary newsgroup.
    N
    NSM, Jul 2, 2005
    #18
  19. Mike L.
    Mike L. Guest
    > news:...
    > > is?
    envelope
    > I.
    Ok, that statement had me gut rolling on the floor. I'm even having a hard
    time typing.
    First off, if all I had to do was google it then why would there be such a
    need for a newsgroup of this nature?
    Second, in my OP I also stated that I was a beginning repair tech(lookin'
    for supportive help).
    Third, also in my OP I gave some hopefully useful information on what the
    "RESET" meant.
    OK I'm done with this numbering thing, it's getting boring.
    As for the CET it has been a while since I took that test, but I don't be or
    recall a question on magnetron.
    Anyways, you all I didn't mean to bother anyone. I really have a hard time
    some times. I get frustrated,
    angry, let down( by myself)all because I want to understand everything and
    there is so much information to electronics and the industry.
    I originally went to school for my A+ , but this other stuff was part of it
    CET, FCC lic, Diploma.
    Any more posting would be a waste of BW, right
    Mike L.
    #19
  20. NSM
    NSM Guest
    news:jWAxe.24538$mC.1414@okepread07...
    > time typing.
    Your question was too similar to, "How do the pictures get down that wire
    thingy into my TV. Doesn't the metal block them?"
    N
    NSM, Jul 2, 2005
    #20
    1. Advertisements
Similar Threads
  1. Jeffrey Landgraf
    Crackling and Hissing Yamaha
    Jeffrey Landgraf, Aug 5, 2003, in forum: Electronic Repair
    3
    756
    Bill Webb
    Aug 6, 2003
  2. Tim
    1,178
  3. davidlaska
    9
    1,311
    davidlaska
    Jun 6, 2008
  4. Bob F
    4
    2,447
    Leonard Caillouet
    May 11, 2009
  5. aussiblu
    1,889
    aussiblu
    Jan 27, 2012
Loading...
Share This Page
