fusible resistor substitute
Discussion in 'Electronic Repair' started by captainvideo462002@yahoo.com, Jun 25, 2006.
  1. Guest
    I just worked on a set that had a shorted diode that took out the 1.5
    ohm 7 watt fusible resistor. I have a 10watt resistor in stock but I
    really don't want to use it in place of a 7. In general it seems that I
    never seem to have the correct size of these things around when I need
    them. I was wondering if there is any reason that I couldn't substitute
    an appropriate size fuse for this application? The current in theory to
    open the resistor would have to exceed 3.24 amps. So I was thinking
    perhaps a 4 amp fuse would do. Anyone have any thoughts on this?
    Thanks. Lenny Stein, Barlen Electronics.
    , Jun 25, 2006
    #1
    1. Advertisements
  2. Simoc Guest
    How did you calculate that? P=I^2R --> I=sqrt(P/R) -->
    sqrt(7W/1.5ohm)=2.16A
    > So I was thinking
    2 amps, rather :) and I wouldn't use one with any higher rated current
    than "the original one (the resistor)" had...
    It depends on that did the resistance of the resistor have any purpose,
    or was it just to heat it up so that it will work as a fuse. That is of
    course highly possible in case of such low resistance...if you can tell
    it, your idea might work, although it sounds a little crazy :)
    Simoc, Jun 25, 2006
    #2
    1. Advertisements
  3. Franc Zabkar Guest
    On 25 Jun 2006 09:41:06 -0700, ""
    <> put finger to keyboard and composed:
    I've always wondered about how fusible resistors were rated.
    Here is the datasheet for Vishay's CMF fusible 0.25W/0.5W metal film
    flameproof fusible resistors:
    http://www.vishay.com/docs/31031/cmffuse.pdf
    The average fusing time for the 0.25W versions is 1 sec at 15W, 16s at
    5W, and 24s at ~4W. That's a lot slower than a typical glass fuse. The
    fusing specs also state that lower resistance parts take longer to
    fuse than higher resistances.
    Here is the datasheet for the LCA...SI carbon fusible resistor series:
    http://www.vishay.com/docs/20137/lcasi.pdf
    The LCA0207SI has a power rating of 0.25W but requires a 4A overload
    before it will fuse. At this current the maximum time to fuse is 15
    secs. So it seems that the equivalent circuit is ...
    o---- R ---- F ----o
    1/4W 3A ???
    I'm conFUSEd ...
    - Franc Zabkar
    Please remove one 'i' from my address when replying by email.
    Franc Zabkar, Jun 25, 2006
    #3
  4. Jim Land Guest
    Franc Zabkar <> wrote in
    news::
    > I'm conFUSEd ...
    Use a SLOW BLOW fuse. They have the same characteristic you're describing,
    blowing faster for bigger currents.
    Jim Land, Jun 26, 2006
    #4
  5. Guest
    Lenny:
    If it were me and I was able to pinpoint the exact fault that caused
    the 7 watt resistor (like a shorted semiconductor or capacitor,etc.) to
    burn out I would without hesistation use a 10 watt replacement (forget
    the fuse substitute) and let the set run for an hour or so and test for
    overheated components and excessive current through the resistor.
    Usually this type and value of low ohm resistor is used for current
    limiting and/or inrush current control and in light of another drastic
    fault condition, the 10 watt resistor would perform it's task and open
    up just as the original value did.
    electricitym
    snipped:
    , Jun 26, 2006
    #5
  6. Franc Zabkar Guest
    On Mon, 26 Jun 2006 08:03:00 +1000, Franc Zabkar
    Oops, that should be 4W, not 4A, so the fusing current is 4x rated
    current.
    >secs.
    - Franc Zabkar
    Franc Zabkar, Jun 26, 2006
    #6
  7. Franc Zabkar Guest
    On Mon, 26 Jun 2006 02:30:58 -0000, Jim Land
    <RrrrFfffTttt(NO)@(SPAM)hotmail.com> put finger to keyboard and
    composed:
    >news::
    >> I'm conFUSEd ...
    True, but it would have to be a *very* slow fuse.
    For instance, these slo-blo fuses require only 0.6 sec before they
    rupture at 4x rated current:
    http://www.littelfuse.com/data/en/Time_Curve/385_multipletccurve.pdf
    OTOH, the fusible carbon resistors require 15s to rupture at 4x rated
    current.
    - Franc Zabkar
    #7
  8. <> wrote in message
    news:...
    I think I'd look for a 1 ohm 5 watt fusible resistor. The lower resistance
    will roughly accout for the lower wattage rating - yet still give the
    protection.
    Mark Z.
    Mark D. Zacharias, Jun 26, 2006
    #8
  9. M Berger Guest
    This might be a liability issue for a commercial servicer.
    wrote:
    > Lenny:
    > electricitym
    M Berger, Jun 26, 2006
    #9
  10. Guest
    Thanks for all the responses. I found a .82 ohm7W fusible and used it.
    It is not getting hot as I'm sure this device is only to address as
    others have said inrush current. I ran the set for a few hours and it
    seems fine. I'll have to add some of those fusibles to my next parts
    order. Thanks again. Best regards. Lenny.
    > wrote:
    > > Lenny:
    > > electricitym
    , Jun 26, 2006
    #10
  11. Simoc Guest
    Franc Zabkar wrote:
    > I'm conFUSEd ...
    The explanation to that confusing thing might be that the fusibility of
    fusible resistors is intended just for preventing fire hazard if the
    res is overloaded, rather than to protect other components on the
    circuit. So the only thing that matters is that the "fusing point" is
    below the resistor's ignition point :)
    Simoc, Jun 27, 2006
    #11
    1. Advertisements
Similar Threads
  1. Brian Maupin
    Replacing a fusible resistor on a laptop...?
    Brian Maupin, Oct 7, 2003, in forum: Electronic Repair
    9
    2,720
    Brian Maupin
    Oct 17, 2003
  2. Russ_Verdon
    Fusible resistor selection
    Russ_Verdon, Apr 15, 2006, in forum: Electronic Repair
    6
    1,146
    Tom MacIntyre
    Apr 16, 2006
  3. Dave
    fusible resistor source
    Dave, May 23, 2007, in forum: Electronic Components
    608
  4. N_Cook
    WR overlay designation for a fusible resistor?
    N_Cook, Apr 23, 2008, in forum: Electronic Repair
    11
    763
  5. N_Cook
    Fusible resistor characteristics query
    N_Cook, May 27, 2008, in forum: Electronic Repair
    4
    888
    N_Cook
    May 29, 2008
Loading...
