fuse rating question
Discussion in 'Electronic Basics' started by Paul, Feb 2, 2006.
  1. Paul
    Paul Guest
    What is the difference between a 15A 125V and a 15A 32V fuse?
    Microwave broke the other day. I was headed out to the pawn shop to buy
    another. Money is tight. The I remembered to open it up to see if there was
    a fuse. Yep, the fuse went. It was 15A 125V. Now, I suspect that it will
    blow a replacement, but of course I want to check before I buy another oven.
    I have several 15A 32V and several 15A No V listed. I also have 20A 32V, and
    30A 32V.
    Is there any way I can check it out without needlessly buying a new fuse? If
    it does work, I will of course buy the proper fuse before putting her
    together again. But can I test her using 32V 15A, 20A, or 30A?
    Paul
    Paul, Feb 2, 2006
    #1
    1. Advertisements
  2. Ralph Mowery
    Ralph Mowery Guest
    "Paul" <> wrote in message
    news:RLeEf.4632$...
    was
    oven.
    and
    > 30A 32V.
    If
    > Paul
    The current ( 15 A in your case) is the maximum current the fuse will
    normally carry before it opens up. You usually select that based on the
    wire size or current the device the fuse is used in.
    The voltage ( which should be 125 V in your case) is the maximum voltage the
    fuse should be used at. If you put in the 32 V fuse , it is possiable that
    the fuse could blow if the 15 amps is exceeded but instead of opening the
    circuit, it will arc over and be about the same as if it never opened up.
    Do not use any of the 32 V fuses. You can always put in a higher voltage
    rated fues in. That is if you find a 250 volt fuse rated at 15 amps you can
    us it at any voltage less than 250 volts. If you put in a 10 amp fuse , it
    will probably blow and if you put in a 20 or 30 amp fuse, it may not blow or
    if it does there may be major damage or a fire.
    Ralph Mowery, Feb 2, 2006
    #2
    1. Advertisements
  3. Paul
    Paul Guest
    so you are saying what I suspected. That I need to spend the big bucks on a
    fuse to see if it will work.
    tks,
    P
    "Ralph Mowery" <> wrote in message
    news:AWeEf.4636$...
    > news:RLeEf.4632$...
    > was
    > oven.
    > and
    >> 30A 32V.
    > If
    >> Paul
    > the
    > that
    > voltage
    > can
    > it
    > or
    Paul, Feb 2, 2006
    #3
  4. Rich Grise
    Rich Grise Guest
    > a fuse to see if it will work.
    You should be able to get a fuse for pennies. If you know where to shop,
    and how to look pathetic, somebody might even _give_ you one. ;-)
    Good Luck!
    Rich
    Rich Grise, Feb 2, 2006
    #4
  5. Jasen Betts
    Jasen Betts Guest
    32V fuses can't stop 110V, and may explode when pushed to try.
    > 30A 32V.
    a new fuse will be less expensive than replacing/refilling your fire
    extinguisher.
    Bye.
    Jasen
    Jasen Betts, Feb 2, 2006
    #5
  6. Paul
    Paul Guest
    maybe in the good old days, but this here is corporate america. Death to the
    local shop, who's owner you knew by name. I had to buy a pack of 3 for 4 $
    and have not tried it yet.
    P
    "Rich Grise" <> wrote in message
    news:p...
    > Good Luck!
    > Rich
    Paul, Feb 3, 2006
    #6
  7. Paul
    Paul Guest
    she works :))
    news:QbCEf.10898$...
    > the local shop, who's owner you knew by name. I had to buy a pack of 3 for
    > 4 $ and have not tried it yet.
    > P
    > news:p...
    >>> on
    >> Good Luck!
    >> Rich
    Paul, Feb 3, 2006
    #7
  8. Paul
    Paul Guest
    fire ext will be 20 years old this august and still does not need a
    recharge.
    "Jasen Betts" <> wrote in message
    news:...
    >> was
    >> oven.
    >> and
    >> 30A 32V.
    >> If
    > extinguisher.
    > Bye.
    > Jasen
    Paul, Feb 3, 2006
    #8
  9. Ralph Mowery
    Ralph Mowery Guest
    news:DzNEf.11237$...
    > recharge.
    > news:...
    > >> was
    will
    > >> oven.
    32V,
    > >> and
    > >> 30A 32V.
    fuse?
    > >> If
    > > extinguisher.
    Jasen ment that you may have to use the extinguisher to put out the fire the
    wrong fuse may cause.
    Also it may not need it but every so many years the extinguisher should be
    checked and recharged. Not sure what the law or regulations are on this,
    but do know that where I work they are inspected every month ( have to do
    that myself on some of them) and every so often they are taken out and
    replaced with fresh recharged units.
    Ralph Mowery, Feb 3, 2006
    #9
  10. John Fields
    John Fields Guest
    On Thu, 02 Feb 2006 03:11:45 GMT, "Paul"
    >30A 32V.
    Check what's downstream from the fuse. More than likely a rectifier
    in the power supply. If you find a bad one, replace it and try
    again.
    John Fields
    Professional Circuit Designer
    John Fields, Feb 3, 2006
    #10
  11. John Fields
    John Fields Guest
    On Fri, 03 Feb 2006 18:48:03 GMT, "Paul"
    >recharge.
    Maybe the gauge is stuck...
    John Fields
    #11
  12. Phil Allison
    Phil Allison Guest
    "John Fields"
    > again.
    ** BAD ADVICE !!
    Microwave ovens are killers.
    NEVER suggest that a novice meddle with one.
    ......... Phil
    Phil Allison, Feb 3, 2006
    #12
  13. John Fields
    John Fields Guest
    On Sat, 4 Feb 2006 09:21:57 +1100, "Phil Allison"
    <> wrote:
    >"John Fields"
    >> again.
    >** BAD ADVICE !!
    How do you think that novices get to be experts?
    By listening to your whining advice about what they should and
    shouldn't do?
    I don't think so, ya goddam pussy.
    Just think, would us humans have actually walked on our moon if
    you'd have been in charge of the mission?
    No. Probably because Mum would have told you that it was _much_ too
    dangerous and _no one_ should try it, and you never really got to
    cut the cord.
    If the fuse is gone, then to find out whether it's the fuse's fault
    or not, _passively_ probe what's downstream from the fuse. If you
    find something that's obviously bad, replace it, fit a new fuse and
    fire it up. If it blows the fuse again, then there's more to it
    than a novice can be expected to contend with and the effort should
    be relegated to more competent hands. Or, as seems to be the trend
    lately, throw it away and get a new one.
    In any case, bugger you, you ignorant piece of shit.
    John Fields
    #13
  14. Phil Allison
    Phil Allison Guest
    "John Fields
    "Phil Allison"
    >>> again.
    >>** BAD ADVICE !!
    ** First of all, by staying alive !!
    You fucking ** CRIMINAL IDIOT ** !!!!
    > shouldn't do?
    ** Fields - YOU are one GROSSLY irresponsible ASS !!!!!
    A real " Texas Cowboy " with shit for brains.
    ** Buggery is YOUR speciality - isn't it ???
    Cowboy.
    " John Fields
    Professional Fuckwit "
    ** Now it reads just right.
    .......... Phil
    #14
  15. Paul
    Paul Guest
    > the
    I realized that.
    Paul, Feb 4, 2006
    #15
  16. John Fields
    John Fields Guest
    On Sat, 4 Feb 2006 10:48:29 +1100, "Phil Allison"
    <> wrote:
    >"John Fields
    > "Phil Allison"
    >>>> again.
    >>>** BAD ADVICE !!
    In your case, it seems, by listening to Mum and taking no risks
    whatever, which certainly doesn't qualify you as an expert on
    anything but sucking tit.
    Yawnnnn...
    Got some evidence?
    If not, you need to shut up unless you're prepared to go technical.
    Pretty scary, huh?
    Since you don't know what you're talking about, in the first place,
    your advice to anyone who asks for technical help is, always,
    "Forget it, it's too dangerous".
    Is seems to me that that's the battle cry of the legion of cowards,
    of which you seem to be a founding member.
    >> shouldn't do?
    If I subscribed to your prattle, I would be.
    However, since your rhetoric has proven its underlying logic to be
    fault-ridden and your stance to be less than that of, let's say, a
    dog bitch looking for a meal, it's not likely that you'll be taken
    seriously.
    > Cowboy.
    Actually, no.
    I just thought I'd interject something you'd be familiar with in
    order to keep the thread going.
    >" John Fields
    How clever of you to be able to edit a dotsig...
    Just think, if you can somehow pull it off, all of everyone else's
    pithy sayings will be attributed to you, even if you can't fathom
    their meanings.
    John Fields
    John Fields, Feb 4, 2006
    #16
  17. Phil Allison
    Phil Allison Guest
    CRIMINAL ADVICE
    "John Fields" = RECKLESS ASSHOLE
    ** BAD ADVICE !!
    NEVER suggest that a *novice* meddle with one.
    John Fields IS a GROSSLY irresponsible ASS !!!!
    ** A CRIMINALLY RECKLESS IDIOT ** !!!
    " John Fields
    Should be marked on his tombstone - ASAP.
    ......... Phil
    Phil Allison, Feb 5, 2006
    #17
  18. Don Bowey
    Don Bowey Guest
    Re: CRIMINAL ADVICE
    On 2/4/06 10:28 PM, in article , "Phil Allison"
    > ** BAD ADVICE !!
    > " John Fields
    > ........ Phil
    Your posts are..... Insightful.
    Don Bowey, Feb 5, 2006
    #18
  19. John Fields
    John Fields Guest
    Re: CRIMINAL ADVICE
    On Sun, 05 Feb 2006 09:27:47 -0800, Don Bowey <>
    >> ** BAD ADVICE !!
    >> " John Fields
    >> ........ Phil
    "Inciteful" is closer to the truth.
    John Fields
    John Fields, Feb 5, 2006
    #19
  20. Paul
    Paul Guest
    ok, so now my microwave works, as I already posted.
    I have been using it with the cover off. I just noticed 4 1/4 holes on the
    top of the heating cavity. They are not arraigned symmetrically. This was
    made overseas, but they are between 6 and 7 mm in size. So, when I cook
    something, I am pushing microwaves into my atmosphere. How far can they
    travel? And can I out run them?
    P
    Paul, Feb 5, 2006
    #20
    1. Advertisements
Similar Threads
  1. Fuse with voltage rating , why ?
    , Jul 3, 2005, in forum: Electronic Basics
    3
    2,634
  2. Brian Logan
    Fuse Rating on a Motor
    Brian Logan, Nov 26, 2003, in forum: Electronic Design
    20
    1,949
    Brian Logan
    Nov 28, 2003
  3. Al
    B & C coffee maker heat fuse rating?
    Al, Feb 24, 2004, in forum: Electronic Repair
    4
    1,684
    Jerry G.
    Feb 25, 2004
  4. -Alex
    Fuse T4E 250V What is AMP rating??
    -Alex, Jul 21, 2005, in forum: Electronic Repair
    5
    5,864
    -Alex
    Jul 21, 2005
  5. alpha_uma
    Fuse Rating for Automotive Application
    alpha_uma, Jun 14, 2005, in forum: Beginner Electronics
    3
    944
    Landon
    Jun 19, 2005
Loading...
Share This Page
