Freezer to Fridge Conversion project in ReNew
Discussion in 'Hobby Electronics' started by David L. Jones, Sep 28, 2005.
  1. There is a "freezer to fridge" conversion project in this months ReNew
    magazine which claims to convert a freezer into a supper efficient
    0.1kWh/day fridge.
    It's basically a thermostat which switches the freezer mains power off
    and on to regulate its temperature.
    It's a follow up to an existing article which I haven't seen, so
    doesn't have much detail on how it works or how the measurements were
    taken.
    Although I don't know much about fridges or freezers, several things
    raised my "What the?" detector immediately:
    1) 0.1kWh/day is 36.5kWh/year, that's about 1/10th the power
    consumption of a regular fridge. Something ain't right there... what's
    the catch?
    2) The circuit is hardly "micro-power" as claimed, not that it really
    matters.
    3) The use of a battery to power the circuit when the freezer
    compressor is not on. WHY?. Presumably the author thinks it lowers the
    power consumption?. Looks like he's designed a Free Energy device!
    Here is the circuit:
    http://www.alternatezone.com/electronics/images/FreezerConversion.jpg
    Can a freezer be made into a more efficient fridge using this
    technique? My gut feeling is "maybe", but the amount claimed seems very
    unlikely. I suspect the author has goofed the measurements.
    Comments please...
    Dave :)
    #1
    1. Advertisements
    On second thought it is obvious that the author thinks that charging a
    battery and using that instead of having the mains transformer
    permanately powered is going to save some power. Possibly, have to go
    through the numbers I guess. The transformer has losses, but so does
    the battery and charging.
    The obvious thing is that if the battery fails your fridge dies. Then
    when it does die you have manually kick-start the thing again. Seems a
    silly way to go about it just to save some quiescent power.
    Dave :)
    #2
    1. Advertisements
  3. "David L. Jones" <> wrote in message
    news:...
    > 0.1kWh/day fridge.
    > taken.
    > the catch?
    ## I would think the compressor would require just as much power to cool as
    a normal fridge. Perhaps it is the physical design of the freezer, where the
    bucket shape and better insulation holds the cool in better.
    > matters.
    ## Looks like SW1 has two settings - one to run the circuit off mains (to
    charge the battery) and the other to just run off the battery. Probably to
    reduce power consumption by limiting the use of the transformer.
    > Comments please...
    > Dave :)
    How often does he use the fridge? I reckon that is the main factor in fridge
    power consumption. Or pehaps he is comparing a freezer with an efficient
    compressor to a dodgy old kelvinator.
    Ross
    Ross Marchant, Sep 28, 2005
    #3
  4. KLR
    KLR Guest
    On 27 Sep 2005 16:14:27 -0700, "David L. Jones" <>
    >0.1kWh/day fridge.
    >taken.
    >the catch?
    it all depends on the size of the fridge (and this wasnt specified in
    your post), and how good the insulation is on it. The little "beer
    fridge" we have in our workplace (made circa 1987-88) draws 153w
    according to the specifications. I presume that this is the power the
    compressor draws when it is running, so if you assume that even if
    this compressor never turns off - its going to draw .153 Kwh.
    Depending on how often it gets opened, it probably would come close to
    the 0.1 kwh average power over a 12 month period.
    I think what these people are working on is the fact that a typical
    freezer is going to have a MUCH better insulation than a typical
    fridge, so if its run as a fridge (higher temperature than a freezer)
    the temperature will take longer to raise, due to the better
    insulation, and the much less time the compressor will have to run in
    the average day.
    As an added bonus, if they are talking about "tucker box" freezers
    (with the top mounted lid), then when they are opened, very little
    cold will "spill" out, whereas with a standard fridge with the hinged
    front door, the cold air will "pour" out very quickly when opened -
    wasting a lot of energy !
    In a theoretical fridge that had a perfect seal with no heat leakage,
    and perfect insulation that the heat could NEVER pass through, and no
    metal parts going from the inside to the outside (to pass heat inside)
    the fridge would only have to be powered for long enough to bring it
    down to the desired temperature, and then it would stay at that
    temperature eternally, as long as it wasnt opened, and nothing in
    there gave off heat (food eventaully rotting etc)
    >matters.
    no. If they wanted to save power, and just had to have this
    "electronic control" they wouldn't be stepping down a 12vac secondary
    (more like 17vdc when rectified) to +5v via 2 series regulators, and
    they also wouldn't be using a relay (surely a triac would have less
    overall losses ?
    Save running the transformer all day, and all the other lossy crap in
    there. (mentioned above) Whether it saves any significant power is
    debatable though.
    If they are that worried about power wastage, then why not stick to
    the standard mechanical thermostat (used for decades without
    problems), and simply modify it (if needed) to achieve the desired
    temperature range ! it uses ZERO electrical power to operate !!
    There are millions of fridges out there at recycling centres, that you
    could take the thermostats from for this project, if the existing
    freezer one cant be set high enough.
    >Comments please...
    I think it could be, but NOT because of the electronics used.
    If you are going to do this, I would start with the most efficient
    freezer you can buy, not some old thing.
    >Dave :)
    KLR, Sep 28, 2005
    #4
  5. > ------------------
    I agree, in fact why not have both 'stats installed with a changeover
    switch?
    Or I guess by using the 'off' setting on the freezer 'stat, the changeover
    switch would not be neccessary.
    Regards ......... Rheilly Phoull
    Rheilly Phoull, Sep 28, 2005
    #5
    > >0.1kWh/day fridge.
    > >taken.
    > >the catch?
    Yeah, a small fridge might I guess.
    My fridge (500L or whatever) is rated at 500kWh/year, that's
    1.36kWh/day, and that is one of the lowest consumption ones on the
    market for that size.
    > the average day.
    Very true.
    > >matters.
    > overall losses ?
    > debatable though.
    Even if it does, it's a naff way to do it. Dead battery = lost food.
    Sounds like the go.
    > >Comments please...
    Gotta agree!
    No plans to do it myself.
    I figure it's all probably a load of bollocks in a practical sense. To
    get any sort of direct comparison figure you'd have to have a fridge
    and freezer of the same size and construction, being opened the same
    amount of time every day.
    If freezer mechanisms were somehow more efficient then every
    manufacturer would be using then in fridges.
    The electronics in the article is doing nothing a normal fridge
    thermostat doesn't do (except waste some extra power).
    The idea of converting a chest freezer might have some merit if you
    were going to store long term stuff in there for instance. Bit useless
    for practical day to day use though.
    A job for Mythbusters!
    Dave :)
    #6
  7. Mark Harriss
    Mark Harriss Guest
    One possible efficiency boost a chest freezer would have over
    a fridge is you retain most of the cold air inside when you
    open the lid, opening a fridge door would lose nearly all of
    the cold air inside.
    It remains to be seen just how much BTU's can be removed from
    room temp air with a given humidity.
    Mark Harriss, Sep 28, 2005
    #7
  8. Mark Harriss
    Mark Harriss Guest
    Assuming a 500L air volume at room temp I get a figure of 600
    Joules per degree. So assuming that's correct 600 x 25= 15 Kj
    (30 deg ambient) lost each time you open the door.
    #8
  9. Rick Measham
    Rick Measham Guest
    I haven't seen either of these issues of ReNew, but my guess is that the
    battery is there because the owneer uses solar panels for most of his
    power, but is on the grid if he needs it (and isn't using one of those
    two-way meters that means he's always on the grid). That way, he can use
    the solar panels, via the battery, for most of the time. But his lettuce
    doesn't go mushy if the solar panels/battery fail as he can switch the
    fridge back to the grid.
    Cheers!
    Rick Meaham
    Rick Measham, Sep 28, 2005
    #9
  10. quietguy
    quietguy Guest
    Just thought I'd mention that Silicon Chip Mag desribed a similar project -
    turning a fridge or freezer into a wine 'celler' I think - but same
    principal, different temps - might be worth a look
    David
    > >0.1kWh/day fridge.
    > >taken.
    > >the catch?
    > the average day.
    > >matters.
    > overall losses ?
    > debatable though.
    > >Comments please...
    > >Dave :)
    quietguy, Sep 29, 2005
    #10
  11. John Dunkley
    John Dunkley Guest
    This kit is available from JAYCAR. Kit number is KC-5413 and actually looks
    pretty good!
    Is a revamp of the ReNew project.
    JD
    "quietguy" <> wrote in
    message
    news:...
    > project -
    > David
    >> >0.1kWh/day fridge.
    >> >taken.
    >> >the catch?
    >> the average day.
    >> >matters.
    >> overall losses ?
    >> debatable though.
    >> >Comments please...
    >> >Dave :)
    John Dunkley, Sep 29, 2005
    #11
    1. Advertisements
Similar Threads
  1. Marvin Moss
    Convert frosty freezer to frost-free freezer??
    Marvin Moss, Oct 15, 2003, in forum: Electronic Repair
    5
    1,969
    Marvin Moss
    Oct 17, 2003
  2. Replies:
    1,696
  3. Joe
    Broken Fridge Freezer?
    Joe, May 9, 2005, in forum: Electronic Repair
    33
    1,711
  4. Replies:
    14
    960
  5. larry
    11
    591
    Oldus Fartus
    Dec 10, 2003
Loading...
Share This Page
