Filtering noisy 12V to a logic level
Discussion in 'Electronic Design' started by Miles, Sep 23, 2003.
  1. Miles
    Miles Guest
    Hello,
    I built a circuit for a motorcycle which cuts off power to the
    ignition coils for several milliseconds when a switch is pressed to
    fire an air shifter. It works well, but sometimes it triggers for no
    reason (ie. switch was not pressed).
    The circuit is powered by a LM2937 automotive regulator. The timming
    is done with a 555 in one-shot mode. I think the problem is lack of
    filtering on the trigger wire. The trigger wire will be switched from
    an open, to 12V.
    Any ideas on a really solid noise immune way of converting that noisy
    12V line to a 5V logic level for the 555? My revised idea is to use
    the following signal path:
    1. 12V unregulated
    2. 20V TVS
    3. LC low pass filter
    3. Voltage divider (Divide signal by 4)
    4. Pull Down resistor
    5. 5.1V Zener
    6. Schmitt Trigger output to 555 timer trigger pin
    Do you think this will work? What values for my low pass filter
    should I be looking at?
    Thanks for your help.
    Miles, Sep 23, 2003
    #1
    1. Advertisements
  2. On 22 Sep 2003 21:22:31 -0700, (Miles)
    wrote:
    >Hello,
    >an open, to 12V.
    >1. 12V unregulated
    >2. 20V TVS
    >5. 5.1V Zener
    A dedicated 12 volt line leaves your circuit and goes to the switch.
    The signal from your switch goes back into your box. First to a
    pulldown resistor and possibly diodes to VCC and GND to clip any
    spikes, then it passes through a 1K resistor, then there is a 1uF cap
    to ground, and then possibly through another series resistor to
    prevent latchup if using a cmos 555.
    Or just use a coaxial cable to feed the switch and forget all the
    other stuff.
    Stepan Novotill, Sep 23, 2003
    #2
    1. Advertisements
  3. In article <>,
    (Miles) wrote:
    > Hello,
    > an open, to 12V.
    > 1. 12V unregulated
    > 2. 20V TVS
    > 5. 5.1V Zener
    The inputs have a very high impedance. You could probably trigger it by
    swatting a cloth against the wire (electrostatic generation).
    An RC filter and pull-down resistor will do the trick. Of course you
    don't want to pull the trigger higher than pin 8, so your pull-down
    resistor and RC filter might need to combine into a voltage divider.
    switch ---- R --+--+--- Trigger
    R C
    +--+--- GND
    I'm not sure exactly what your regulation is. A simple snubber won't be
    enough. Negative spikes in the input power will trigger the timer too.
    Another RC filter is the simplest solution and it works quite well too.
    Kevin McMurtrie, Sep 23, 2003
    #3
  4. Miles
    Boris Mohar Guest
    On 22 Sep 2003 21:22:31 -0700, (Miles) wrote:
    >Hello,
    Your problem could be the vibration sensitive switch.
    Regards,
    Boris Mohar
    Got Knock? - see:
    Viatrack Printed Circuit Designs http://www3.sympatico.ca/borism/
    Aurora, Ontario
    Boris Mohar, Sep 23, 2003
    #4
  5. Miles
    Terry Guest
    Boris Mohar threw some tea leaves on the floor
    >>Hello,
    It could also be spikes from the ignition, so check that its not
    sensitive to that kind of thing ?
    Kind Regards from Terry
    My Desktop is powered by GNU/LinuX, Gentoo-1.4_rc2
    New Homepage: http://milkstone.d2.net.au/
    ** Linux Registration Number: 103931, http://counter.li.org **
    Terry, Sep 23, 2003
    #5
  6. Miles
    Jim Thompson Guest
    wrote:
    >Hello,
    >an open, to 12V.
    >1. 12V unregulated
    >2. 20V TVS
    >5. 5.1V Zener
    See "NoiseBlank.pdf" on the S.E.D/Schematics page of my website for a
    variety of ways to handle ratty edges.
    ...Jim Thompson
    | James E.Thompson, P.E. | mens |
    | Analog Innovations, Inc. | et |
    | Analog/Mixed-Signal ASIC's and Discrete Systems | manus |
    | Phoenix, Arizona Voice:(480)460-2350 | |
    | E-mail Address at Website Fax:(480)460-2142 | Brass Rat |
    | http://www.analog-innovations.com | 1962 |
    I love to cook with wine. Sometimes I even put it in the food.
    Jim Thompson, Sep 23, 2003
    #6
  7. Miles
    John Fields Guest
    On Tue, 23 Sep 2003 12:33:42 -0700, Jim Thompson
    >wrote:
    >>Hello,
    >>an open, to 12V.
    If that's true, then the first problem is that the 555 doesn't trigger
    on a positive-going edge, but on a negative-going edge, so you're more
    than likely triggering on negative spikes when the switch bounces, and
    every once in a while when the trigger input is driven low by noise.
    The trigger input of the 555 is the floating base of a PNP, so if you're
    not using a pullup on the trigger input, it will normally be off, but
    noise could certainly trigger it.
    >>1. 12V unregulated
    >>2. 20V TVS
    >>5. 5.1V Zener
    Unless you have some overriding need to feed the 555 from a 5V supply,
    there's no reason why you can't power it with +12 and momentarily pull
    the trigger to ground when you push the switch. Do you have a schematic
    you can post so we can see what you're doing?
    John Fields
    John Fields, Sep 23, 2003
    #7
  8. On 22 Sep 2003 21:22:31 -0700, (Miles) wroth:
    >Hello,
    Before you go off and flog the input for noise, try an experiment.
    Make all the connections, power and grounds included, but disconnect the
    signal input wire right at the input to your circuit. Just leave it floating at
    the circuit end but connected at the switch end.
    Then run around for a while and monitor the output of your circuit. If
    you still get random actuation, then you have a "ground loop" problem and even
    the most well designed filter circuit in the world won't do Jack.
    Jim
    James (Jim) Meyer, Sep 24, 2003
    #8
    1. Advertisements
Similar Threads
  1. Winfield Hill
    Re: Driving non-logic level MOSFETs from logic levels?
    Winfield Hill, Jul 10, 2003, in forum: Electronic Design
    1,839
    Winfield Hill
    Jul 10, 2003
  2. M.Joshi
    Unbal. Line-level to Bal. Mic-level
    M.Joshi, Jul 27, 2006, in forum: Electronic Repair
    5
    633
    M.Joshi
    Jul 31, 2006
  3. William E Miller
    † Any suppliers of LCD glass pins?
    William E Miller, Mar 25, 2007, in forum: Electronic Components
    3
    513
  4. Jon Slaughter
    noisy logic
    Jon Slaughter, Sep 23, 2008, in forum: Electronic Design
    5
    341
    Jasen Betts
    Sep 28, 2008
  5. Replies:
    554
Loading...
