Fast zener diode substitute
Discussion in 'Hobby Electronics' started by Yvan, Feb 6, 2010.
  1. Yvan
    Yvan Guest
    I decided to built this:
    http://notes.ump.edu.my/fkee/e-Magazine/Elektor 2004/Articles/E/e04b020.pdf
    It keeps the battery a little bit active, preventing sulphation by
    loading the battery with a hefty current (40 A) for a short interval
    (50 μs) approximately every two minutes.
    But they used a fast zener diode (BZT03 27V) across the FET for
    protection, as rather large voltage spikes can occur when the FET
    switches off.
    I can not find this diode where I am, so can you suggest a substitute? I
    guess I can not just put regular 27V zener diode here?
    ___ ____
    /__/ / \ ** Registrovani korisnik Linuksa #291606 **
    / / \/ /\ \ ** Registered Linux user #291606 **
    /__/\____/--\__\ ** http://counter.li.org/ **
    Yvan, Feb 6, 2010
    #1
    1. Advertisements
  2. Yvan
    Yvan Guest
    Nedavno ian field napisa:
    > Have a look at the data sheet for the TL431 adjustable zener, you put
    > a potential divider (2 resistors or a trimpot) across it with the
    > tap/wiper to the control input to adjust the zener voltage, if you
    > need it to be particularly fast just put a few tens of pF capacitance
    > in parallel with the top leg of the divider.
    I am electronics newbie, this sound complicated :-(
    ___ ____
    Yvan, Feb 6, 2010
    #2
    1. Advertisements
  3. Yvan
    Ban Guest
    "ian field" <> schrieb im Newsbeitrag
    news:iombn.346312$2...
    > "Yvan" <> wrote in message
    > news:hkkrgn$hlo$-september.org...
    > Not at all, search and download the data sheet - it has application
    > examples for you to follow, to speed it up you only need add a small
    > disc-ceramic capacitor from cathode to control pin.
    What happens with that small part if up to 10A want to flow thru it?
    ban
    Ban, Feb 7, 2010
    #3
  4. Yvan
    Yvan Guest
    >>> put a potential divider (2 resistors or a trimpot) across it with
    >>> the tap/wiper to the control input to adjust the zener voltage, if
    >>> you need it to be particularly fast just put a few tens of pF
    >>> capacitance in parallel with the top leg of the divider.
    I've been suggested in another NG to just use any 3-5W 27V zener diode.
    What do you think?
    ___ ____
    Yvan, Feb 7, 2010
    #4
  5. Yvan
    Ban Guest
    news:ZIBbn.19222$2...
    > news:hkloo9$n61$-september.org...
    >> What do you think?
    > The best thing to do is study the data sheet;
    > http://www.ieeta.pt/~alex/docs/DataSheets/BZT03.pdf
    > It mentions that these zeners are suitable for transient suppressors, that
    > might be connected to the idea that these are fast zeners, you could
    > search under transient suppressors and select a substitute from the
    > results.
    The same datasheet states a non repetitive current of 7.9A in transient
    suppression, maybe we dont need that much for the application, but certainly
    a long lead will give some inductive kick when driven with 40A.
    ciao Ban
    Ban, Feb 7, 2010
    #5
  6. Yvan
    Yvan Guest
    > BTW: thanks for the URL - backspacing it found some pretty interesting
    > magazines & e-books.
    Yeah, I noticed that too :)
    ___ ____
    Yvan, Feb 7, 2010
    #6
  7. Yvan
    Yvan Guest
    >> diode. What do you think?
    > This search might be a good starting point;
    http://www.google.co.uk/search?sourceid=navclient&ie=UTF-8&rlz=1T4GZAZ_en-GBGB333GB333&q=p6ke
    I am electronics newbie, are you suggesting that I can just use 27V P6KE
    in place of BZT03 without modifications?
    There are uni-polar and bi-polar P6KE, which one should I use?
    ___ ____
    Yvan, Feb 8, 2010
    #7
  8. Yvan
    Yvan Guest
    > I was suggesting you use that search as a starting point, download the
    > data sheets and compare the spec with the type you want to replace.
    Since I do not know what values to compare, that does not help a lot :-(
    My knowledge in electronics is limited to finding schematics on the
    Internet, drawing a board in eagle, and soldering components to it.
    > I've had a cursory glance at the schematic you plan to build, and I'm
    > a little sceptical about "battery revitalisers" that take pulsed
    > current without incorporating a float charger to replenish the energy
    > taken - if left and forgotten it will eventually discharge the battery
    > and cause sulphation.
    This circuit is not a battery revitaliser as I understand it this is
    sort of sulphation preventer. I am also building battery revitaliser:
    http://home.comcast.net/~ddenhardt201263/desulfator/n_channel_schem.gif
    > It is also possible to do the same job with a much simpler circuit.
    > If you start with a simple current limiting PSU as a float charger,
    > you can add a zero-crossing detector to the rectifier section and use
    > the narrow pulses to switch the MOSFET which then takes pulses of
    > current from the battery as in the Elektor project.
    As I wrote I have (very) limited knowledge in electronics, so unless you
    give me a link to the schematics, this does not help. I have a lot to
    learn, but very little time for that, unfortunately.
    ___ ____
    Yvan, Feb 8, 2010
    #8
  9. Yvan
    Yvan Guest
    > I suggest you make
    > the time to stick your nose in a book and learn some of the basics.
    OK, thanks.
    ___ ____
    Yvan, Feb 9, 2010
    #9
    1. Advertisements
Similar Threads
  1. looking for fast zener diodes
    , Aug 4, 2003, in forum: Electronic Components
    919
    K Wind
    Aug 8, 2003
  2. Ajay
    Zener diode with fast switching
    Ajay, Sep 16, 2004, in forum: Electronic Design
    4
    2,950
    Ken Smith
    Sep 17, 2004
  3. Bicio
    Diode + Diode Zener and Inductive load
    Bicio, May 21, 2008, in forum: Electronic Design
    8
    1,863
    Spehro Pefhany
    May 22, 2008
  4. Yvan
    Yvan, Feb 6, 2010, in forum: Electronic Design
    21
    1,680
  5. Replies:
    18
    910
    Phil Hobbs
    Aug 20, 2013
Loading...
