Equivalent for 2N3904
Discussion in 'Electronic Components' started by Dave, Feb 9, 2005.
  1. Dave
    Dave Guest
    Could anybody with a copy of towers etc. give me an equivalent for a 2N3904
    TIA
    Dave, Feb 9, 2005
    #1
    1. Advertisements
  2. "Dave" <> wrote in message
    news:...
    2N3904
    BC547 or 2N2222 should work for general purpose work.
    Anthony Fremont, Feb 9, 2005
    #2
    1. Advertisements
  3. Dave Platt
    Dave Platt Guest
    In article <>,
    That part can probably be accurately described as a "jellybean" - it's
    an NPN switching transistor, Ft 300 MHz, good up to an absolute limit
    of 40 volts and 200 mA.
    They're quite common and easy to come by, I believe. If you can't
    find one, then unless there's something exotic about your application
    you can probably substitute a PN2222A. 2N4401 might also work (Ft is
    a bit lower), and I have no doubt that there are a zillion other
    substitutes which would work OK in many circuit applications.
    Dave Platt <> AE6EO
    Hosting the Jade Warrior home page: http://www.radagast.org/jade-warrior
    I do _not_ wish to receive unsolicited commercial email, and I will
    boycott any company which has the gall to send me such ads!
    Dave Platt, Feb 9, 2005
    #3
  4. Dave
    Dave Guest
    Cheers guys,
    Have some 2N2222's kicking around - somewhere!
    Dave, Feb 10, 2005
    #4
  5. "Anthony Fremont" <> wrote in message
    news:qXuOd.32770$...
    > news:...
    > 2N3904
    The BC547 has a bit more gain, and the reverse pinout, but should work
    okay. The 2N2222 is a metal case TO-18 with the different pinout, and
    is a bit higher power. The 2N4124 it almost the same, except the max
    collector voltage is only 25VDC.
    But it seems to me that using the 2N3904 is the best idea, because
    they're as common as dog doo-doo.
    Watson A.Name - \Watt Sun, the Dark Remover\, Feb 11, 2005
    #5
  6. If you do an Ebay search there are currently quite a few 2N3904 transistors
    available for an exact replacement.
    news:...
    2N3904
    > TIA
    > Dave
    Barry & Nikki, Feb 15, 2005
    #6
    1. Advertisements
Similar Threads
  1. pcf
    2N3904
    pcf, Oct 13, 2003, in forum: General Electronics
    1,070
    Robert Baer
    Oct 14, 2003
  2. Lily Bepant
    Common Emitter Amplifier with 2N3904
    Lily Bepant, Jan 10, 2004, in forum: Electronic Basics
    139
    5,586
  3. Newbie
    2N3904 Beginner Question
    Newbie, Feb 4, 2004, in forum: Electronic Basics
    3
    1,889
    Newbie
    Feb 5, 2004
  4. Colin Stirling
    Equivalent or Equivalent Part Numbers for UHF Tuner
    Colin Stirling, Jul 20, 2003, in forum: Electronic Repair
    1,062
    Colin Stirling
    Jul 20, 2003
  5. Hammy
    SMT equivalent or better to the 2n3904?
    Hammy, Oct 7, 2007, in forum: Electronic Basics
    4
    1,027
    Jamie
    Oct 7, 2007
Loading...
Share This Page
