Equalizer slider cleaner
Discussion in 'Electronic Repair' started by Marko, Aug 2, 2003.
  1. Marko
    Marko Guest
    Roger: Some pots have grease in them that dries. GC electronics make a
    cleaner called JifAction. It is cheap so you can flood the pots and not run
    up too big of a cleaner bill. Spray them. Let them sit a while and clean
    them again. Keep flooding them out. Might want to soak the mess up with
    rags while the unit is standing on its' side.
    If that doesn't work, as a last resort, use Brake rotor Cleaner from an auto
    parts store. This stuff eats plastic so be frugal. Blow the pots out with
    compressed air to dry the rotor cleaner out. I don't know if it eats the
    carbon or not. I have used it many times, it is very powerful. Vent the
    room good. It is degreaser for brake rotors.
    Afterward clean and lube with conventional control cleaner for electronics.
    JifAction works very well. Good Luck MH (top post)
    "Engineer" <> wrote in message
    news:...
    > By an oversight and a serious lack of attention (happens to
    > us all!), I acquired a used stereo equalizer some time ago.
    > Predictably, darn it, the slider pots are either dirty or
    > shot - the measured gain at the various centre frequencies
    > jumps as various sliders are moved, and an ohmmeter also
    > jumps on passive measurements.
    > Slider replacement is out (parts too expensive.) So it's
    > try to clean or throw out (perhaps cannibalize.) Does
    > anyone have a recommendation for a potentiometer cleaner
    > that won't actually dissolve whatever carbon is left on the
    > tracks? I've tried "Power up" switch cleaner to little
    > effect.
    > Cheers,
    > Roger
    > Roger Jones, P.Eng.
    > Thornhill, Ontario,
    > Canada.
    > "Friends don't let friends vote Liberal"
    Marko, Aug 2, 2003
    #1
    1. Advertisements
  2. BOB URZ
    BOB URZ Guest
    > effect.
    > Cheers,
    > Roger
    > Roger Jones, P.Eng.
    > Thornhill, Ontario,
    > Canada.
    Only one choice: caig labs. D5 or Pro gold.
    Not cheap, but worth every penny,
    BOB
    -----= Posted via Newsfeeds.Com, Uncensored Usenet News =-----
    http://www.newsfeeds.com - The #1 Newsgroup Service in the World!
    -----== Over 80,000 Newsgroups - 16 Different Servers! =-----
    BOB URZ, Aug 2, 2003
    #2
    1. Advertisements
  3. Engineer
    Engineer Guest
    effect.
    Cheers,
    Roger
    Roger Jones, P.Eng.
    Thornhill, Ontario,
    Canada.
    Engineer, Aug 2, 2003
    #3
  4. JURB6006
    JURB6006 Guest
    DeOxit
    JURB6006, Aug 5, 2003
    #4
    1. Advertisements
Similar Threads
  1. dansawyeror
    hp slider switch replacement or recyclers
    dansawyeror, Apr 21, 2007, in forum: Electronic Repair
    9
    489
  2. Mad Scientist Jr
    building a pitch bend slider like on old moog snyths?
    Mad Scientist Jr, May 18, 2007, in forum: Electronic Components
    4
    604
    Lostgallifreyan
    May 21, 2007
  3. Clifford Heath
    Slider pot for Janome controller?
    Clifford Heath, Sep 22, 2006, in forum: Hobby Electronics
    579
    Don Richmond
    Sep 22, 2006
  4. Fonz
    Slider Pots
    Fonz, Nov 12, 2007, in forum: Hobby Electronics
    6
    1,218
    swanny
    Nov 13, 2007
  5. micky
    7
    6,277
    William Sommerwerck
    Aug 27, 2011
Loading...
